1998 V70 Xc From The Beginning... to the End
  • 4 weeks later...
  • 1 month later...
Enkei something-or-others I don't recall the model #. I went with 225/50x17's, which is not good with a lowered chassis. Wheels fit over BBK's with no spacers.
The nice thing about the plastidip is that you can just peel it off. I did it mainly cos I didn't like the crack that had developed over the grille area. Not about to shell out another few hundred to repaint again.
I just spent the last 2 hours reading this thread. Absolutely insane. I love my Volvo, but I can't imagine doing half the work you did...Scratch that...not even 10% of your build.
Looks great.
BTW is that pic in Letchworth Village too? I got married at Patriot Hills in Stony Point.
  • 2 weeks later...
Looks great. BTW is that pic in Letchworth Village too? I got married at Patriot Hills in Stony Point.
Thanks! Yes, that is on the grounds of Letchworth - there are any number of unused buildings boarded up. They are gradually re-purposing many.
Still don't have a backup car for DD, so the fuel mods are still on hold. In the meantime, I followed TMM9, Simply Volvo, Justus, and some others to use TunerPro & tune my own setup. This Wikia outlines the process. You need to download a tune file (BIN) an XDF and an ADX to read, adjust and log data from the tune.
This also means I have a backup ECU in the event of a failure of either setup - hasn't happened yet, but when I drove to Quebec & Montreal last summer in the wagon I did think about the fact that I would be screwed if something failed on route.
I bought an Ostrich 2.0, and with Simply Volvo's help, got the components (DIP, DIP-PLCC, 32pin cable) required to connect the Ostrich with the ECU motherboard after removing the existing chip.
Made a custom short USB male/female adaptor to bring the port flush with the casing. Built in the wiring for the TT COP connection.
A VAG-COM cable is required for communication/logging, so I built mine into the ODBII cable & have it stashed under the console with the port inside the armrest stow area. An LED to indicate activity and an interrupt switch to disable the VAG-COM is added to allow the port to be used for code reading, Logworks, etc.
Some of the advantages include being able to fine tune cold start & warmup settings, timing and RPM settings for idle, MAF rescaling, all of which need adjustment from stock settings on my build. I can now alter cooling fan onset to take advantage of the lower temp thermostat (167f) These can be dealt with to some extent with TTusb, but require getting help from them with modified files, or in the case of MAF settings, coarse adjustments to the entire fuel/ign maps to compensate.
Logging window based on a setup from TMM9 - I'm not logging Boost thru TunerPro yet, so that display value doesn't reflect reality - this screenshot was in 4th gear
Screenshot2014-03-05150732_zps9be02ed7.p
  • Upvote 3
  • 1 month later...
Minor stuff.
Converted shifter to late push & rotate style - using C30 M66 leather/aluminum knob
1970563_10151929045961370_2094507013_n_z
1979674_10151929046476370_703812114_n_zp
Built 4" OD inlet piping -not ready to switch yet - have to rescale MAF table to use it.
10170759_10151931795191370_218847377_n_z
1977270_10151931795196370_2099180450_n_z
Converted vent fittings from 1/2" copper to Fragola AN10 3000 series reusable. Some left over from when I tried the AN10 turbo drain
1508623_10151904681056370_2144950292_n_z
1901117_10151904681051370_56745800_n_zps
Simply amazing Hussein. I've just gone through the whole thread and the whole setup is crazy. This should be pinned, every time I see any of your reply in a technical thread I almost automaticly say to myself : "yup this guy is right". Cant wait to finish my setup so it's 1/10 as complete as yours haha ! Cheers !
  • 3 weeks later...
Thank you.
Worked on the fuel delivery upgrade this week, when it wasn't freezing or snowing out... Today I did some cosmetic work - added vinyl 'carbon' wrap to the ABM taillights, covering the area I had painted black. painted the very top silver to follow the trim line and the vinyl wrap I put on the D pillar last year.
Found a Silver 98 R in the parking lot when we went to the pet supply store today....
Thank you.
Your car looks like it's gonna lean over and just eat the VR in one gulp T-rex status
Amazing work! Your skills and abilities are inspiring, and your ability to present your work so we can learn from it is equally impressive! Thank you!
Dan
