mags98c70 Posted April 26, 2014 Report Share Posted April 26, 2014 I like what you do with peeling the plasti dip in sections. Its crazy to see the difference between yours and the stock R. Quote Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted May 8, 2014 Report Share Posted May 8, 2014 Dyno this year? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 11, 2014 Author Report Share Posted May 11, 2014 On 5/8/2014 at 10:09 AM, CHARGER69O1 said: Dyno this year? Once the fuel delivery mods are complete, I will be able to run over 21 psi boost without running out of volume, so, yes, I will be (AWD) dyno'ing to see what I'm making at 24psi (should be right around 500wheel), maybe higher if the tuning feels right. finishing up the sender unit lines & fittings upgrade to 3/8" from stock 5/16". Not going to finalize install until after Carlisle, to avoid jinxing myself... Quote Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted May 12, 2014 Report Share Posted May 12, 2014 Nice! So no dyno at Carlisle this year. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 12, 2014 Author Report Share Posted May 12, 2014 Nice! So no dyno at Carlisle this year. They haven't had a Dyno available the past two years anyway :( Quote Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted May 13, 2014 Report Share Posted May 13, 2014 They haven't had a Dyno available the past two years anyway I heard they were having one this year. I saw there was none last year, but the year before wasnt there one that required having to take the wheels off to dyno? Something weird I thought.... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 14, 2014 Author Report Share Posted May 14, 2014 I heard they were having one this year. I saw there was none last year, but the year before wasnt there one that required having to take the wheels off to dyno? Something weird I thought.... If there is one, I'll consider yanking the DS. The one the year before was Audi/VW only - it was one of those pita bolt to the hub jobs. He (the tuner) cooked a motor on it. Quote Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted May 14, 2014 Report Share Posted May 14, 2014 I remember that. I hear there is going to be a dyno there. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted August 12, 2014 Author Report Share Posted August 12, 2014 Forgot to add the Aerocatch Hood latches modified stock brackets for the pins Waiting for the Ishihara-Johnson crank scraper/windage tray kit. Cieka 6pot rear brakes with integral eBrake setup ordered after much back & forth to determine if it will clear with the limited clearance. X1/9 hopefully back on the road soon, so I can then take the wagon apart to finish the fuel delivery upgrades. 2 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 26, 2014 Author Report Share Posted November 26, 2014 A few updates. Fuel system upgrades were finished a couple of months ago. AN-08 Fuel inlet to rail Left sender access All lines uprated to 12mm. All fittings on senders now 3/8", with 3/8" tubing replacing stock 5/16" SS LGSpeed Header to replace the mild steel version that rotted out at the collector Revised SS DP to go with SS intermediate section with Magnaflow 14419 resonator I will redo the tail section in mandrel bend SS when I replace the Magnaflow 14834's with the longer body (quieter) Magnaflows. No I have the TIG, I can do it all myself. Now running onboard COP instead of TTCOP - I added the connector for TTCOP inside the ECU, so I can switch if needed. A friend gave me this light table, which made soldering the resistors much easier Once I have the confirmed all my coil pack issues are behind me, I will get back to the dyno CEIKA rear BBK finally installed. 330mm, 6 piston calipers. GM D585 Coil packs going in next Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 13, 2015 Author Report Share Posted July 13, 2015 Minor updates to keep the thread from being archived. GM coils have been on & off. I haven't been able to resolve the breakup over 21psi boost that occurs with them. I ran them to Carlisle, and again to Ithaca in the hopes that I could do on the road adjustments to resolve the problem, but it doesn't seem to be dwell time at the root of it, at least not specifically. Having LS9 coil pack tested by Piet (many thanks) to determine ideal dwell table for those. They have a base dwell time much closer to the Bosch setup. Trent used them on his previous setup. The driving force behind the coil switch, is that fro whatever reason, I have random coil failure with the Bosch coil packs. It's never the same cylinder, and without any COP diagnostics, I can't tell which cylinder has failed without switching out all five, then reinstalling the removed ones one at a time, to determine which cyl is failing under high load. That gets old real fast. With revisions to the TunerPro tuning capabilities of M4.4 (thanks to Piet,Venderbroeck, et al), we are now able to properly map load up to 24.48ms instead of the factory 12.24, and record RPM up to 11k, instead of the built in 7650 cut off. This means that I'm no longer running at the max load values from about 25% throttle on up. As a result, I can dial in more timing and more accurate fueling, with the revised AFR based VE mapping. Ostrich2 inside case max load set to 16.99, that is slightly over the peak load I recorded @ 26psi As a result of all this, I am now achieving high torque values. The downside is that I have reached the rated limit of the AP Racing clutch (440ft/lb) 60-100 just over 4sec, with 2-3 shift. some timing adjustments made after this. Avoided clutch slip by winding it out in 2nd, instead of doing a straight 3rd pull. I will be reinstalling the Spec Stage III+ full face setup, with a Spec flywheel. I also wore out my used AWD components - I never bought new parts until now - so I bought a new left Volvo (manual) axle, new Angle Gear, PdV higher rated spline coupler, and a Colorado DS 2000MY version driveshaft. The new 31256008 spline coupler I had installed with the AP clutch was shagged, and the AG splines along with it. It exhibited itself as a nasty vibration under load. I also installed the Ishihara- Johnson Crank Scraper & Windage screen kit I bought last fall. New Volvo TTY crank carrier bolts used. test fit for clearance final fit with shaved teflon haven't driven it enough since install to see if it makes any difference to oil consumption due to reduced oil clouding around the crank. Also modified the heater hoses at the firewall (thanks Matt for the idea). I reduced the length of the elbow offset, reusing the stock barb & firewall insert removing old revised in place this was necessary to get clearance for the 4" lower inlet piping - I had previously used a 3.5" section with a step to the 4" MAF housing section, due to the interference with the heater hoses. Now the 4" just clears. I also moved the dump valve section of piping back to the upper section, as this makes access to the shifter cables & wiring etc over the trans easier to service Thanks to VulvaS40, at some point last year I determined the air filter I was using was insufficient in terms of flow capacity for the PTE6262 at the projected boost levels. So, I had to revise that. Now using RU5045. See page 150 of my main thread for more detail. Previous filters... The problem is that my airbox doesn't work anymore, and there is no room as it is for a larger housing. So, I will be relocating the battery to the cargo area, and building a new box using the current battery location space. EDIT: forgot - I also figured out a way to use the CEIKA rear hydraulic eBrake setup. adaptor plate to fit hydraulics placement brake hose routing basic cable adjust no more shoes! I was able to discard the drum & all the junk related to the shoes. Much cleaner install. I'm happy. 1 Quote Link to comment Share on other sites More sharing options...
Blockpartie Posted July 13, 2015 Report Share Posted July 13, 2015 What's the advantage of the '00 style driveshaft? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 14, 2015 Author Report Share Posted July 14, 2015 What's the advantage of the '00 style driveshaft?Larger carrier bearing & cage Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted August 15, 2015 Author Report Share Posted August 15, 2015 Installed the new AWD parts & the Spec clutch over the past few weeks. Installed on 7/30/2015 at 192,990k miles Also switched to the P1 style shifter & cables to see if the shift is more precise under hard use. Have to finish bedding the new clutch before I get aggressive with it. Moved the battery to the cargo area. Wiring was a bit of a PITA, but it's all good now. I bought the hydraulic crimp tool to work with the 0/1 AWG crimp connectors. With that out of the way, I looked at the space in terms of fitting the larger filter diagonally in a new box. It's so larger that it would fill the entire space, and require an offset to the MAF housing that just seemed plain awkward. So, I made a diverter tray to fit under the filter in it's current location, with a air funnel feed from the left side bumper grille. I used the plastic tray insert from the cargo area space saver tub to make it & the cover. Then I made a cover that encompasses the upper air feed in the stock location. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted September 19, 2015 Author Report Share Posted September 19, 2015 The build has come to it's end. All five Wisecos are cracked, one lost the rear skirt. Car is being parted out. Intake, Turbo, Cams, IC, Injectors, NRG mount & OMP strut brace are under consideration now, everything else is available if you're interested LMK via email so I can track whoever asks for what on a first come basis. husseinholland AT gmail.com 1 Quote Link to comment Share on other sites More sharing options...
