Jack8745 Posted April 24, 2009 Report Share Posted April 24, 2009 i just took out my headliner. removed the old fabric. the foam is falling appart in some places. what do i do with it, just remove it or what ?also am i missing something, took it out through the trunk and it was super tight, the edges definitely rubbed. headliner is fine but i don't want to damage it while putting it back it. ThanksJack Link to comment Share on other sites More sharing options...
Dave 54 Posted April 24, 2009 Report Share Posted April 24, 2009 Yup, layed mine out and took a broom to it and ll that old foam came right off. I got actually headliner mareial from Joann fabrics and it had foam on the back.Just make sure you use the right glue. Link to comment Share on other sites More sharing options...
Быстров Posted April 24, 2009 Report Share Posted April 24, 2009 i just took out my headliner. removed the old fabric. the foam is falling appart in some places. what do i do with it, just remove it or what ?also am i missing something, took it out through the trunk and it was super tight, the edges definitely rubbed. headliner is fine but i don't want to damage it while putting it back it. ThanksJack had the same problem your in now. yes you have to remove all the old foam. best way to do it would be take an air gun and get some latex gloves, apply air and brush it all ways with your palm, it should come off easy. after that, since you want best result take it to a shop, (the headliner that is) and have them redo it in any material you want, usually if you take the old stuff off, they wont charge you for it and it would be way cheaper, shop not too far away applied new foam and glue for 60 bucks black suede material included, and these guys do restoration on hot rods. Deff money well spent, since if you try to fix it your self your prob going to fudge it up the first time around. have the pros do it man. -alex Link to comment Share on other sites More sharing options...
Chilled man Posted April 24, 2009 Report Share Posted April 24, 2009 ehh stock headliner stuff Just remove all the old foam down to the silver stuff and then apply your fabric of choice and only use 3m adhesive spray glue Black with purple top in a spray can Link to comment Share on other sites More sharing options...
Dave 54 Posted April 24, 2009 Report Share Posted April 24, 2009 It's not that difficult as long as you use the right adhesive.and only use 3m adhesive spray glue Black with purple top in a spray canYup that be the stuff Link to comment Share on other sites More sharing options...
Jack8745 Posted April 24, 2009 Author Report Share Posted April 24, 2009 heard that super 77 works also. what about the way to get it back in, is it just that tight?redoing it in black suade Link to comment Share on other sites More sharing options...
Cal3thousand Posted April 24, 2009 Report Share Posted April 24, 2009 heard that super 77 works also. what about the way to get it back in, is it just that tight?redoing it in black suadeDon't go 7788 at the least. And 90 is the shizzle... pretty sure Justin is referring to the same can. Link to comment Share on other sites More sharing options...
Dave 54 Posted April 24, 2009 Report Share Posted April 24, 2009 Yup it will go back in the same, tight as stuff. Link to comment Share on other sites More sharing options...
Jack8745 Posted April 24, 2009 Author Report Share Posted April 24, 2009 taking it to the upholster in an hour. 45 he said. used wire brush to remove the old foam. for that much i'll be dumb not to take it to him Link to comment Share on other sites More sharing options...
850R Ridah Posted April 24, 2009 Report Share Posted April 24, 2009 To those thinking of tackling this: Whatever you do, don't try to re-glue existing headlining material - that does not work because it is the foam backing that has disintegrated. Most of the foam should scraped off with a blunt scraper dragged across the surface, leaving the original adhesive as a 'primer' for the new adhesive. This is less porous than the backing board alone, and generally you want to avoid separating the adhesive from the backing board, as that will leave noticeable ridges in the finished result. It's not worth trying to use a solvent - that risks breaking down the backing board. The foam backing I used comes in two thicknesses - I found the thinner of the two is sufficient. The 3M spray headliner adhesive is perfect for the job if you can find it, but there are many spray adhesives out there now. Glue the headlining material on before you attempt to cut any holes - pretty obvious, but you can't be too careful - as it is quite stretchy. You only get one 'go' with the adhesive, so it's important to get the material straight. Both of out Volvo's headliner's are fine for the moment. My experience came from doing a few Alfa Romeo headliners. Sincerely, Gee.P.S. Start at the back edge. Link to comment Share on other sites More sharing options...
