FlntRoc Posted April 29, 2009 Report Share Posted April 29, 2009 hmmm flintrocs Saff = baller I hope someone got some better pics fo that . maybe some strut and bag pics .... I can only wish Here are what I have2nd pic is the 1st set of struts I had 3rd pic is my rear bag which prob does anyone no good1st pic is an extra bag I have on my coffee table so you can see the top mountIf anyone can give me the part number for the (Koni?) single & double adjustable strut inserts that someone has used that are really short to make homemade coilovers I will buy a pair & make another new set so I can see if it will handle better. Bilstein makes shocks that are made specifically for aftermarket air-ride equipped vehicles but I think there is only like 2 or 4 to choose from & none of them will work for us. I'm too lazy / don't have time to look for the info on the adjustable inserts but I've FINALLY got a few bucks to spend & I would be happy to finally get a nice ride so that I could recommend or help other people out. I very rarely use the bags @ shows cause I haven't done anything to the car in years so I don't really like showing it off too much unless people ask Link to comment Share on other sites More sharing options...
magicaljake Posted April 29, 2009 Report Share Posted April 29, 2009 sick pictures!nice cars.volvos are so freaking cool Link to comment Share on other sites More sharing options...
Chilled man Posted April 29, 2009 Report Share Posted April 29, 2009 Here are what I have2nd pic is the 1st set of struts I had 3rd pic is my rear bag which prob does anyone no good1st pic is an extra bag I have on my coffee table so you can see the top mountIf anyone can give me the part number for the (Koni?) single & double adjustable strut inserts that someone has used that are really short to make homemade coilovers I will buy a pair & make another new set so I can see if it will handle better. Bilstein makes shocks that are made specifically for aftermarket air-ride equipped vehicles but I think there is only like 2 or 4 to choose from & none of them will work for us. I'm too lazy / don't have time to look for the info on the adjustable inserts but I've FINALLY got a few bucks to spend & I would be happy to finally get a nice ride so that I could recommend or help other people out. I very rarely use the bags @ shows cause I haven't done anything to the car in years so I don't really like showing it off too much unless people askAwsomeness and no your rear pics would help me out alot considering I want to get ride of my nimovats in my 98R and I already have most of the stuff needed 2 Viair 380cc Aircompressors, 5gall tank , trainhorns I would at least like to do the rears then make my way to the fronts. from the looks of it you use a standard front strut and just remove the spring second and shock and inserted the airbag ? and the rear just built mounts and went ? again I am all over this just need some pointersI forget whos airbags you suggest thou Link to comment Share on other sites More sharing options...
cr854r Posted April 29, 2009 Report Share Posted April 29, 2009 whos was the first car?... what did he have done? Link to comment Share on other sites More sharing options...
FlntRoc Posted April 29, 2009 Report Share Posted April 29, 2009 Awsomeness and no your rear pics would help me out alot considering I want to get ride of my nimovats in my 98R and I already have most of the stuff needed 2 Viair 380cc Aircompressors, 5gall tank , trainhorns I would at least like to do the rears then make my way to the fronts. from the looks of it you use a standard front strut and just remove the spring second and shock and inserted the airbag ? and the rear just built mounts and went ? again I am all over this just need some pointersI forget whos airbags you suggest thouThreadjacking but here it goes lolFor the rear if you compare mine to a stock one, I cut off somewhere between 1/2"-1" of the subframe that is mere hair thickness from touching the bag. At one spot there is a hole in the middle where you can see the body, I had to trim so much. As for the front, my plan is to cut down the stock struts to the height I need, weld my bottom mount on, insert the struts & secure them, then bolt my bag to the strut. I also need the inserts to have the same size rod in order for it to work with my current upper mounts. I have firestones in mine, I would like to use Slam Specialties but because of the way they compress they will cause more rubbing issues. I'm not sure if a 4ply bag would work any better than a standard 2 ply. It would be stiffer but that is not always better. If you ever need help you just need to continually harass me. I'm pretty unreliable lol. Always trying to do too many things & stretching myself thin. If I don't get back witihin a day or 2 it means I've forgotten & need a friendly reminder. Link to comment Share on other sites More sharing options...
Chilled man Posted April 29, 2009 Report Share Posted April 29, 2009 baller , any pics you can post would help out , I want / need to do this with mine as soon as carlisle is over this year mines going on jackstands to finish it out :) Link to comment Share on other sites More sharing options...
Zappo Posted April 29, 2009 Report Share Posted April 29, 2009 C'mon guys, it's pretty bad when guys drive all the way down from Seattle and you guys are less then an hour away and can't even show up for support Yup, that is what I was saying last week. A lot of the "locals" never show up. Sacramento is local because that is where we stayed the night before the show. San Francisco is local, even if you guys don't think it is. I have photos that I will post up in the next day or so. Also have a few from the track day and video from inside my car. Link to comment Share on other sites More sharing options...
T-5Bandit Posted April 29, 2009 Report Share Posted April 29, 2009 ....If you ever need help you just need to continually harass me. I'm pretty unreliable lol. Always trying to do too many things & stretching myself thin. If I don't get back witihin a day or 2 it means I've forgotten & need a friendly reminder.He is not kidding about this. Is this why you forgot to get back to me about something Shawn? :lol: Link to comment Share on other sites More sharing options...
B1Gtime Posted April 29, 2009 Report Share Posted April 29, 2009 Nice pics, and some schweeeeet rides wish I was dere. Hate the Ford GT/Viper/Mustang stripes on the S60R :angry: Link to comment Share on other sites More sharing options...
volvie! Posted April 30, 2009 Report Share Posted April 30, 2009 Hi Everyone,I have also posted some pictures and links to photo topics on our 2009 Past Events page:http://www.sacvolvoclub.org/Home/events/2009-past-events#M4bIf you have any pictures of the event you would like to share (and have posted on the Sac Volvo Club website), please let me know:webmaster at sacvolvoclub dot orgAnd, the People's Choice 850 winner was Blue850T5!Related topic:http://volvospeed.com/vs_forum/index.php?showtopic=116371Take care,volvie! Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted April 30, 2009 Report Share Posted April 30, 2009 Hi Everyone,I have also posted some pictures and links to photo topics on our 2009 Past Events page:http://www.sacvolvoclub.org/Home/events/2009-past-events#M4bIf you have any pictures of the event you would like to share (and have posted on the Sac Volvo Club website), please let me know:webmaster at sacvolvoclub dot orgAnd, the People's Choice 850 winner was Blue850T5!Related topic:http://volvospeed.com/vs_forum/index.php?showtopic=116371Take care,volvie!Can we get winners from all of the categories? Link to comment Share on other sites More sharing options...
JoshV70 Posted April 30, 2009 Report Share Posted April 30, 2009 Did Carson not track his car? Link to comment Share on other sites More sharing options...
Zappo Posted April 30, 2009 Report Share Posted April 30, 2009 Did Carson not track his car?No, since he didn't drive down. He rode down with me. Link to comment Share on other sites More sharing options...
volvie! Posted April 30, 2009 Report Share Posted April 30, 2009 Can we get winners from all of the categories?Hi dmelvi007,I don't know all the winners off hand, but I know that the:-P1900 won Best in Show -242 GT won in the 240 categoryI just sent an e-mail to CJ and Jeff asking for the complete list.One of us should post back shortly...Take care,volvie! Link to comment Share on other sites More sharing options...
blu92in99 Posted May 1, 2009 Report Share Posted May 1, 2009 Hi dmelvi007,I don't know all the winners off hand, but I know that the:-P1900 won Best in Show -242 GT won in the 240 categoryI just sent an e-mail to CJ and Jeff asking for the complete list.One of us should post back shortly...Take care,volvie!My old 1991 Coupe (780 Bertone) won in the 7xx/9xx category. Congrats to her new owner...who didn't do sh*t to the car but fix the paint and upholstery. Link to comment Share on other sites More sharing options...
