dougy Posted March 11, 2012 Report Share Posted March 11, 2012 it's not better than K&N in my opinion but size wise gives you more room on the inside. http://www.ebay.com/itm/3-x-6-S-B-AAF-Power-Stack-RED-cone-air-filter-/280748613990?pt=Motors_Car_Truck_Parts_Accessories&hash=item415debe166&vxp=mtr Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 11, 2012 Author Report Share Posted March 11, 2012 Dougy, I don't need links to cheap filters. I already have that brand new 3" ID inlet filter The extreme has the pleated inlet cone, and this version also has deeper pleating for more filer surface area, I'm all good with this. Quote Link to comment Share on other sites More sharing options...
dougy Posted March 11, 2012 Report Share Posted March 11, 2012 oh i know, you should try it...I have one set up on my 850, it's pretty good...but nothing beats Apexi which includes K&'sN deeper pleating is your custom aluminum radiator same as 850? I was thinking about getting one for 850. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 11, 2012 Author Report Share Posted March 11, 2012 oh i know, you should try it...I have one set up on my 850, it's pretty good...but nothing beats Apexi which includes K&'sN deeper pleating is your custom aluminum radiator same as 850? I was thinking about getting one for 850. I think you're mistaken about the Apexi - the last one I bought was definitely not as good as the K&N, not bad enough to throw out, so I cleaned & re-oiled it for use on my X1/9. The x70 rad design is the same as 850. The design/drawings I gave them has no coolers, so you would have to either delete yours, or get a quote with them added. Quote Link to comment Share on other sites More sharing options...
dougy Posted March 11, 2012 Report Share Posted March 11, 2012 well, apexi is a dry filter, i can tell you on my s60r which is more sensitive than yours or 850's K&N will throw a code and so does that other one , but not my APEXI.. ever...i dont have any cooler running though my radiator anymore, but is it the same or does anyone carry it that you know of? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 12, 2012 Author Report Share Posted March 12, 2012 well, apexi is a dry filter, i can tell you on my s60r which is more sensitive than yours or 850's K&N will throw a code and so does that other one , but not my APEXI.. ever...i dont have any cooler running though my radiator anymore, but is it the same or does anyone carry it that you know of? Hmm... maybe I shouldn't have oiled it then I don't know anyone who carries a 3" core custom 870 radiator, if that's the question. Howe Racing made it to my specification. They said they keep the drawings, but even if they don't I have them in my thread.... Quote Link to comment Share on other sites More sharing options...
Brad850 Posted March 12, 2012 Report Share Posted March 12, 2012 You're attention to detail inspires me hussein. Quote Link to comment Share on other sites More sharing options...
Volvo5.0 Posted March 13, 2012 Report Share Posted March 13, 2012 A lot of talk about the '04 and later engines having "better" internals. I know your using RSI rods for your build, and I would too considering your goals, but could you post a picture of the stock rod from the '04 engine next to the stock rod from the '98. Do they really have more "beef" to them, or is it just a myth? Quote Link to comment Share on other sites More sharing options...
andyb5 Posted March 13, 2012 Report Share Posted March 13, 2012 The rod is longer, but the main difference and improvement in strength is due to the composition of the rod. See Wizzard_Al for a bit of a more detailed explanation. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 13, 2012 Author Report Share Posted March 13, 2012 A lot of talk about the '04 and later engines having "better" internals. I know your using RSI rods for your build, and I would too considering your goals, but could you post a picture of the stock rod from the '04 engine next to the stock rod from the '98. Do they really have more "beef" to them, or is it just a myth? I have both stock rods here at home. I'll take pics tomorrow. The machine shop reckoned they looked better than the old rods, but I can't recall specifically what he said about them. Worked on the WG this afternoon - arrow indicates clearance off of header cleaned up the inside porting have to add EGT ports - one underneath by #4 the other on the WG dump tube I also need a 3/16 EBP port somewhere on there... Overall arrangement will now be something like this 3 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 15, 2012 Author Report Share Posted March 15, 2012 Worked on the Aluminium version of my existing secondary can Drain will be in the front lower dropped section. Support bracket underneath bolts to old airbox mounting point rear support bracket goes to old coil bolt location new air box should fit in like this 1 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 17, 2012 Author Report Share Posted March 17, 2012 Finished the CC box today figured out the angle I need the vent pipes to exit at all welded while I was at the machine shop, he had a baffled catch can he built for a 1000HP race car.... peterson check valves on the breathers to maintain vacuum @ idle 1 Quote Link to comment Share on other sites More sharing options...
Rsterns Posted March 17, 2012 Report Share Posted March 17, 2012 H, Haven’t been over here in a while, and just caught up with your thread. I don’t know if you’ve assembled the bottom end yet, but if not, as a minimum, IMHO, get the pistons, rings, and bearings Cryo treated. Shipping on the light parts is nothing compared to the benefits. When I did my first build, I was stupid and used OEM rods, which I bent. I had Cryo treated everything. At work, I have access to very accurate measuring equipment, and I had mapped the head surface prior to my first assembly. End to end it was flat within .0002, when I pulled the head after 40K miles, to start over again, it mapped at .0004 end to end. So not only do things run cooler, due to the created micro grain structure, this confirms to me that the head was for the most part completely stress relieved. The biggest issue that I see with cryo treatment is the lack of empirical data to support it. Obviously I’m a believer, and I’d think with what you’re building, you’d be looking for any benefits you can find. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 18, 2012 Author Report Share Posted March 18, 2012 ^ Thanks. I checked into cryo treatment around here. The closest, in Long Island, would end up costing more than another short block :( Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 20, 2012 Author Report Share Posted March 20, 2012 A lot of talk about the '04 and later engines having "better" internals. I know your using RSI rods for your build, and I would too considering your goals, but could you post a picture of the stock rod from the '04 engine next to the stock rod from the '98. Do they really have more "beef" to them, or is it just a myth? Here's pics of the 147mm & 139.5mm rods, and the pistons Quote Link to comment Share on other sites More sharing options...
