Very nice, a little bit of knock, but just a bit.
What is up with the knock % column?
Knock Enrichment as Piet surmised.
How did the car feel during this pull?
Feels Great!
After removing less than a degree up top, I did another quick pull, this time in 4th instead of starting in 3rd. AFR's are about 1 point leaner! Peak recorded boost 25.7psi.
Forgot to include air flow column - (4th gear) 4.84v @ 6840rpm = 2007.88 Kg/hr
Also, when in 5th part throttle, too lean & got some knock. Have to tweak those full load cells.
Knock fuel enrichment does have a serious effect, abcense of it makes a difference of 1 point AFR apparently.
The results look great in my opinion.
Personally I would lower AFR to 12.3 ish, to be more on the safe side.
What a difference with a 19T regarding AFR b.t.w. I have to lower AFR to 11.8 to avoid excessive knock.
Great pulls you have there Hussein! :)
Would it be a terrible idea to have Matt Farah from the smoking tire drive your wagon? I think it would be so awesome for everyone to see all the hard work you've put into this monster. Some Volvo love.. per say.
