fischmama Posted July 24, 2012 Report Share Posted July 24, 2012 Do you know why the timing is so low on idle? I have my timing set MUCH higher than that for idle. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 24, 2012 Author Report Share Posted July 24, 2012 Do you know why the timing is so low on idle? I have my timing set MUCH higher than that for idle. I have higher values specified in the map, makes no difference to idle timing. As soon as the throttle position changes, the timing advances appropriately. This is close to my current map, except the 1st three columns are 400 800 1000: Are you referring to TT or MS? Have you logged your actual timing? Quote Link to comment Share on other sites More sharing options...
fischmama Posted July 24, 2012 Report Share Posted July 24, 2012 I have higher values specified in the map, makes no difference to idle timing. As soon as the throttle position changes, the timing advances appropriately. This is close to my current map: Are you referring to TT or MS? Have you logged your actual timing? I was referring to my MS set up. Haven't run the TT in a while. I will check it though when I go and see doug this weekend (he is running my TT). What I meant to ask is any guesses why Volvo/Motronic keeps the timing so low at idle? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 24, 2012 Author Report Share Posted July 24, 2012 I was referring to my MS set up. Haven't run the TT in a while. I will check it though when I go and see doug this weekend (he is running my TT). What I meant to ask is any guesses why Volvo/Motronic keeps the timing so low at idle? Emissions? I don't think this applies to ME4.3. The stock ME4.4 TT ign map has much less timing (than the ME4.3) in the no/light load cells. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 25, 2012 Author Report Share Posted July 25, 2012 front kit came today. Volvo (SKF) 3530341 bearing in modified seat I'll take pics as I install them, probably tomorrow & start a separate thread. 1 Quote Link to comment Share on other sites More sharing options...
fischmama Posted July 25, 2012 Report Share Posted July 25, 2012 Those top mounts are just fucking sexy.... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 25, 2012 Author Report Share Posted July 25, 2012 Also picked this up off a '93 850 ECU box with vent fan & piping. Now I have to figure out if it's worth the time hooking it up. Those top mounts are just fucking sexy.... I know - it''s a shame to hide them under the sheet metal, really. Quote Link to comment Share on other sites More sharing options...
B Mac Posted July 25, 2012 Report Share Posted July 25, 2012 Ecu box looks pretty cool! Damn I just crack myself up. Quote Link to comment Share on other sites More sharing options...
blkaplan Posted July 25, 2012 Report Share Posted July 25, 2012 (edited) Did you order those aftermarket or for from the dealer? When I bought the bearings for measurement i got them at the dealer and they were INA brand. Edited July 25, 2012 by blkaplan Quote Link to comment Share on other sites More sharing options...
Mesoam Posted July 25, 2012 Report Share Posted July 25, 2012 the 93 ECU box has a fan built into it? My 06 has the fan as well, runs for a few min once the car goes off, it also does not have a fresh air hose. Quote Link to comment Share on other sites More sharing options...
Martijn_B Posted July 25, 2012 Report Share Posted July 25, 2012 Very nice topmounts! How do you by the way get this table? Do you export it out of logworks? (how?) Cheers! Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 26, 2012 Author Report Share Posted July 26, 2012 Did you order those aftermarket or for from the dealer? When I bought the bearings for measurement i got them at the dealer and they were INA brand. I usually buy wholesale from WorldPac. The fit in your mount is perfect - no play. Very nice topmounts! How do you by the way get this table? Do you export it out of logworks? (how?) Cheers! Yes, export from Logworks - File>Export>Export current session> CSV format the 93 ECU box has a fan built into it? My 06 has the fan as well, runs for a few min once the car goes off, it also does not have a fresh air hose. Yes, I was unaware that early models had it. I presume they did away with it just because of cost of manufacture - once they figured out the fan really isn't necessary for 99% of the markets.. Ecu box looks pretty cool! It is - just not sure I want to reroute the ECU harness to make it work - the entire casing & ECU aluminum base plates all have to be used... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 27, 2012 Author Report Share Posted July 27, 2012 Re-did the M66 cable bracket on the trans yesterday. I used a 700 adjuster bracket to make a slider to adjust the cable length. Still have a problem when hard shifting under WOT from 1st-2nd, so next step is to rework the shifter ball base - the spaceball shifter has a larger pivot buffer (oring on collar beneath pivot ball) & I don't think it has been aligned properly since I made the hybrid shifter in '09 larger sweep area from top view Have to do the cam & crank sensors tomorrow never did replace these, mine have 150K on them now. Put these in today Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 28, 2012 Author Report Share Posted July 28, 2012 Looks like this is a problem area - the indicated corner prevents the lever from going back smoothly Redid the shifter bucket - cut the guide trough off the spaceball housing reattached in my housing - plastic welded around the edges to fill in the gaps Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted July 28, 2012 Author Report Share Posted July 28, 2012 After I did the front setup, I took the rears apart to check travel & ride height. Found that the spacer pressed through the upper mount due to lack of free travel (held upside down in pic) Bumps stops mashed Ben has sent me shorter spacers to put on top of the shock mount instead of below but I ended up following his other suggestion of rethreading the rod to the base (shoulder is 11mm, so he suggested threading to 7/16-20UNF), and doing away with the spacers altogether clearance now at normal ride height- before the shock body was touching the bump stop. Quote Link to comment Share on other sites More sharing options...
