dublin14 Posted November 17, 2012 Report Share Posted November 17, 2012 (edited) Have you had the car on the dyno yet Edited November 17, 2012 by dublin14 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 17, 2012 Author Report Share Posted November 17, 2012 Have you had the car on the dyno yet No. No dyno's in my area. I'll have to consider going over to CT - Will, Ben & I went to one in Stamford years ago that did AWD. I'm looking at replacing the last hotside with 3", and the inlet with all aluminum 3.25", including the MAF housing. Just posting layout pics to look at the overall setup again Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 22, 2012 Author Report Share Posted November 22, 2012 Aluminum version of my 3.25" MAF housing arrived today waiting on the rest of the piping. 3rd & 4th gear logs. added a degree of timing in the 6800 & 7200 cells, I'm not seeing any pull, so I think it's safe to add. Ordered a super-atomizing CM10 nozzle. I've been using am Aquamist .8mm, can't be flowing more than 300cc/min, if that. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 24, 2012 Author Report Share Posted November 24, 2012 Installed the FoMoCo pump from Nathan today. First I tried running the pump outlet back into the main breather can this put slight positive pressure on the two cam cover vent inlets (didn't try it under load), so I made a "Y" pipe & plumbed the pump outlet into the vent line to the catch can So, with my setup, I only see about 1 inHg vacuum draw on the crankcase breather (measured from a fitting about 5 inches before the pump). If I remove & cap the two cam vents, it goes up to about 2 inHg, but there is no point in that. After testing with a old school vac gauge, I hooked the line up to the MAP I use for logging EBP. I don't know that the gauge is scaled correctly, it didn't register even as much vacuum as I saw on the gauge, but it stayed very constant even when I wound the motor up around 8500. The main benefit seems to be heat extraction from the crankcase - the breather lines & can get very warm to the touch now. Should help with preventing condensate formation in the breather lines, if nothing else. Pump is just tie-wrapped to the inlet plumbing for now. Fits nicely just above the shifter linkage. For the time being it's wired to continuously run, I don't want a restriction on the main breather line that could occur through the pump, not running. I do need to switch the relay power supply to a accessory (15) so that it doesn't run whilst cranking. Quote Link to comment Share on other sites More sharing options...
B Mac Posted November 24, 2012 Report Share Posted November 24, 2012 I have never seen someone cram more crap into an engine bay. Nice work H. Did you look into Lugtronic for tuning at all? 2 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 24, 2012 Author Report Share Posted November 24, 2012 I have never seen someone cram more crap into an engine bay. Nice work H. Did you look into Lugtronic for tuning at all? I am starting to run out of room... I haven't looked into Lugtronic yet, it's gonna be the spring before I get to the conversion, I need to do it right which does mean allowing for extended downtime as I transition. I'm thinking about going back to that dyno in Stamford we went to years ago with Will, just to see what I have now. Quote Link to comment Share on other sites More sharing options...
maciekb2002 Posted November 25, 2012 Report Share Posted November 25, 2012 I am starting to run out of room... I haven't looked into Lugtronic yet, it's gonna be the spring before I get to the conversion, I need to do it right which does mean allowing for extended downtime as I transition. I'm thinking about going back to that dyno in Stamford we went to years ago with Will, just to see what I have now. yes You are !!!! Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 26, 2012 Author Report Share Posted November 26, 2012 Hi Maciek! Where have you been? Tied up with work? I rewired the vac pump using a Volvo AC delay relay (1363449); this way, there is no power to the pump relay until the alternator is charging, and then there is a 10sec delay before it switches current to the pump. spliced into the D(+) wire in the right side harness conduit (soldered & wrapped), ran the wire through the loom over the fan shroud & to the relay Quote Link to comment Share on other sites More sharing options...
maciekb2002 Posted November 27, 2012 Report Share Posted November 27, 2012 Hi there I was here and There 5 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 27, 2012 Author Report Share Posted November 27, 2012 Nice! You bought a 240 & put the 16V w/K24 in it? I worked on the 3" Hotside last night & this afternoon... gentler transition from the compressor to the crossover section in place Quote Link to comment Share on other sites More sharing options...
Brad850 Posted November 28, 2012 Report Share Posted November 28, 2012 That things massive :tup: Quote Link to comment Share on other sites More sharing options...
fischmama Posted November 28, 2012 Report Share Posted November 28, 2012 Welcome to the world of 3" IC piping. ;) Quote Link to comment Share on other sites More sharing options...
JCviggen Posted November 28, 2012 Report Share Posted November 28, 2012 (edited) Any particular reason to go that big H or just feeling bored? I've always considered 2.5" about ideal considering it'll be plenty for well over 600hp. Otherwise it's just bringing velocity down and delaying boost ever so slightly. Are you shooting for 1000 ? :D Edited November 28, 2012 by JCviggen Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 28, 2012 Author Report Share Posted November 28, 2012 Any particular reason to go that big H or just feeling bored? I've always considered 2.5" about ideal considering it'll be plenty for well over 600hp. Otherwise it's just bringing velocity down and delaying boost ever so slightly. Are you shooting for 1000 ? Maybe a bit of both. Can't do anything with the VEMS install until the spring. Looking for ways & areas to streamline, and I didn't care so much for the harsh transition I had on the compressor outlet. The vacuum pump is helping draw condensate through all the breather vent hoses, so that's a good thing. I'll do some more logging & see if there is any difference in boost onset or temps. I didn't feel any thing negative in the quick romp around the block last night. Quote Link to comment Share on other sites More sharing options...
JCviggen Posted November 28, 2012 Report Share Posted November 28, 2012 No I don't expect it to have any noticeable effect, that's why I was wondering :) Quote Link to comment Share on other sites More sharing options...
