lookforjoe Posted May 29, 2014 Author Report Share Posted May 29, 2014 Read about your breather problem. I use S60R breather with 25mm (1") line to under the car. No crankcase pressure problems even on 660hp / 660nm / 2.5bar / 8000rpm rev limit. Also i have oil restrictor on my holset hx40 which is 2.5mm (0.100"). Also use 1liter less oil in engine so oil level should be on halfway mark on you oil dipstick. Also revving only to 8000rpm is helping alot compared to 9000rpm... Good to know 'm not the only one running under full oil capacity Good idea to increase the box vent to 1". I haven't had breather issues with my current build (25K miles now), however since I have the setup developed & working I didn't see any reason to remove it, even if it is fairly complex. Quote Link to comment Share on other sites More sharing options...
boxpin Posted May 29, 2014 Report Share Posted May 29, 2014 Read about your breather problem. I use S60R breather with 25mm (1") line to under the car. No crankcase pressure problems even on 660hp / 660nm / 2.5bar / 8000rpm rev limit. Also i have oil restrictor on my holset hx40 which is 2.5mm (0.100"). Also use 1liter less oil in engine so oil level should be on halfway mark on you oil dipstick. Also revving only to 8000rpm is helping alot compared to 9000rpm... I tried to put a S60R breather but it does not fit on the early models. How or what did you use to add the 1" vent? More pictures? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 30, 2014 Author Report Share Posted May 30, 2014 I tried to put a S60R breather but it does not fit on the early models. How or what did you use to add the 1" vent? More pictures?Until he responds - you can drill & tap the fibre housing - I used 3/8" NPT (drilled out to 5/8 ID) for my cam vent - you could easily tap it out to 1/2" NPT or larger & fit an elbow. I use the same box - under a stock manifold you need the IPD phenolic spacer, and move the cam vent back as shown in my pic. Don't forget to buy the can vent hose also - it's a different shape since the port location does not match the old style- cam vent is rotated around to left side VS. Right side in old style ] Instead of external cap for the old outlet, cut it down and tap & insert a plug (3/8 NPT), since that is the area where you will hit the manifold underside. Quote Link to comment Share on other sites More sharing options...
NotanR Posted May 30, 2014 Report Share Posted May 30, 2014 What type of rad do you have? There is no reason a larger expansion tank would be required - there is no change in expansion rate of the coolant... I am using Evans Waterless since last August, but didn't see any increase in coolant expansion in the reservoir with the 3" core and standard coolant prior to that... Trimmed up the quote a bit. Since the volume of fluid has increased the volume of expansion also increases. I didn't measure the fill volume so I don't know how much I added, but I think it's 10-20% more with the torque converter cooler no longer required (MT swap) as well as the increased core depth, by about inch/2. If you haven't had any issues it makes me curious if I'm having a different cooling issue. I assume the PN on the reservoir is common between MT/AT. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 30, 2014 Author Report Share Posted May 30, 2014 If you haven't had any issues it makes me curious if I'm having a different cooling issue. I assume the PN on the reservoir is common between MT/AT. Reservoir is the same either way - I'm using the '99-on unit - and my system holds substantially more than stock with the full 3" core vs. stock 1.25" unit. I keep my reservoir about an inch below the full marker, and once hot, it is level at the full marker. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted May 30, 2014 Report Share Posted May 30, 2014 I use custom intake manifold. With stock manifold s60r wont fit without lookforjoes style modifications. Quote Link to comment Share on other sites More sharing options...
boxpin Posted May 30, 2014 Report Share Posted May 30, 2014 I currently have a 1" copper tap on mine. I like the white elbows, would you happen to have a link where you bought them? Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted May 30, 2014 Report Share Posted May 30, 2014 I currently have a 1" copper tap on mine. I like the white elbows, would you happen to have a link where you bought them? From here: http://www.autosiliconehoses.com/plastic-hose-joiner-90-degree-elbow-3mm-to-25mm-choose-your-size.html Quote Link to comment Share on other sites More sharing options...
boxpin Posted June 1, 2014 Report Share Posted June 1, 2014 I was expecting something threaded. Did you just drill it and pop it in with some silicone? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted June 2, 2014 Author Report Share Posted June 2, 2014 PVC elbows can be had from Home Depot for under a buck ..if you want to go that route. I prefer the NPT tap fittings.. Quote Link to comment Share on other sites More sharing options...
s_moneh Posted June 2, 2014 Report Share Posted June 2, 2014 does the fact that the pcv box is bigger help in general? i'm having more pcv smoke problems i like how that 1"vent it straight down Quote Link to comment Share on other sites More sharing options...
Brad850 Posted June 2, 2014 Report Share Posted June 2, 2014 Wishing I didn't sell my ipd spacer right now. Quote Link to comment Share on other sites More sharing options...
laird Posted June 2, 2014 Report Share Posted June 2, 2014 What type of rad do you have? There is no reason a larger expansion tank would be required - there is no change in expansion rate of the coolant... I am using Evans Waterless since last August, but didn't see any increase in coolant expansion in the reservoir with the 3" core and standard coolant prior to that... My wagon at Carlisle On the way down You should think about blacking out the front pilars completely ala Range Rover Evoque. Having said that, the car looks amazing! Quote Link to comment Share on other sites More sharing options...
floggingmike Posted June 2, 2014 Report Share Posted June 2, 2014 He already did at one point but couldnt decide on a good angle to let the top portion off at iirc Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted June 2, 2014 Author Report Share Posted June 2, 2014 does the fact that the pcv box is bigger help in general? i'm having more pcv smoke problems i like how that 1"vent it straight down If you have a N block - it has no windows between the cylinders, and with a stock box you are more likely to develop positive pressure. If you are VTA, using stock size outlets, it's just too small. The larger box helps, and having an outlet of 1" (2x stock) should allow for unrestricted blowby passage. Quote Link to comment Share on other sites More sharing options...
