maciekb2002 Posted November 30, 2014 Report Share Posted November 30, 2014 Do I see AN fitting ? I am so proud of You !!! 1 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted November 30, 2014 Author Report Share Posted November 30, 2014 Do I see AN fitting ? I am so proud of You !!! INDEED - AN fittings all over the place - Quote Link to comment Share on other sites More sharing options...
maciekb2002 Posted November 30, 2014 Report Share Posted November 30, 2014 Good!!! Home depot pluming department will go out of business now. BTW before Carlisle I need to make you a "nice header heat shield" Quote Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted November 30, 2014 Report Share Posted November 30, 2014 Good!!! Home depot pluming department will go out of business now. BTW before Carlisle I need to make you a "nice header heat shield" And a skid plate for me ... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted December 5, 2014 Author Report Share Posted December 5, 2014 Did a 3rd-4th pull today to 8K. TunerPro only goes to 7650rpm. First hard pull since switching the onboard COP. About 25psi boost, 10 sec 60-138mph. Have some work to do on the timing map. AFR's look good. Quote Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted December 5, 2014 Report Share Posted December 5, 2014 Very nice, a little bit of knock, but just a bit. What is up with the knock % column? Quote Link to comment Share on other sites More sharing options...
Piet Posted December 5, 2014 Report Share Posted December 5, 2014 (edited) Very nice indeed, 60-138mph is real fast! The %knock column looks like the knock fuel enrichment ? Edited December 5, 2014 by Piet Quote Link to comment Share on other sites More sharing options...
venderbroeck Posted December 5, 2014 Report Share Posted December 5, 2014 How did the car feel during this pull? Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted December 5, 2014 Author Report Share Posted December 5, 2014 Very nice, a little bit of knock, but just a bit. What is up with the knock % column? Knock Enrichment as Piet surmised. How did the car feel during this pull? Feels Great! After removing less than a degree up top, I did another quick pull, this time in 4th instead of starting in 3rd. AFR's are about 1 point leaner! Peak recorded boost 25.7psi. Forgot to include air flow column - (4th gear) 4.84v @ 6840rpm = 2007.88 Kg/hr Also, when in 5th part throttle, too lean & got some knock. Have to tweak those full load cells. Quote Link to comment Share on other sites More sharing options...
Piet Posted December 5, 2014 Report Share Posted December 5, 2014 Knock fuel enrichment does have a serious effect, abcense of it makes a difference of 1 point AFR apparently. The results look great in my opinion. Personally I would lower AFR to 12.3 ish, to be more on the safe side. What a difference with a 19T regarding AFR b.t.w. I have to lower AFR to 11.8 to avoid excessive knock. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted December 10, 2014 Author Report Share Posted December 10, 2014 Another pull yesterday - this time peak boost was 26.3 psi - it was a tad lean... I moved the 100% load cell values back to the pre-dyno settings after this. Max flow 2100kg/hr @ 7650rpm. Quote Link to comment Share on other sites More sharing options...
hotpantslovebug Posted December 10, 2014 Report Share Posted December 10, 2014 (edited) Would it be a terrible idea to have Matt Farah from the smoking tire drive your wagon? I think it would be so awesome for everyone to see all the hard work you've put into this monster. Some Volvo love.. per say. Edited December 10, 2014 by hotpantslovebug 3 Quote Link to comment Share on other sites More sharing options...
S70-R Posted December 10, 2014 Report Share Posted December 10, 2014 Great pulls you have there Hussein! Would it be a terrible idea to have Matt Farah from the smoking tire drive your wagon? I think it would be so awesome for everyone to see all the hard work you've put into this monster. Some Volvo love.. per say. '> Quote Link to comment Share on other sites More sharing options...
Piet Posted December 10, 2014 Report Share Posted December 10, 2014 (edited) Hoping he won't crash the car Edited December 10, 2014 by Piet Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted December 11, 2014 Author Report Share Posted December 11, 2014 Another pull to check the upper load cells. Still lean. Hitting max load under 30% throttle. tweaked the involved load & WOT cells, see how that goes 2124 kg/hr @ 7620 rpm Quote Link to comment Share on other sites More sharing options...
