You Mr H., are so lucky to have a personal closed air strip to tune on.
You're correct - seasonal use though - once the weather warms up, availability becomes spotty ;)
Made more changes today - hit lower load cells in 1-2-3 pulls & little lean in some part load spots .
Dropped timing just a touch in a few spots
Did some lower gear pulls just to work on the lean areas that have arisen with the compound curve MAF table - found a few spots that were just not good.
Fattened up the top three rows over 4600K & pulled a little timing here and there.
then some more in the 3600 -4200 part load range
Screenshot2015-01-23152801_zpsa2446b56-1
AFR conversion - not sure it means much - I don't see those values in actual logging
short lower speed pull, steep uphill in 3rd, didn't get into WOT before 60. Tweaked the timing in that knock area
Finished clearing out the residual crap from my Innovate Logging hardware. Made a space for my new LogBox
043EF875-1044-4504-B583-DB61F9EF91FF_zps
Provision for 16 channels input to TunerPro
1D90A6B8-2ED6-41B4-AD89-F5FAED3A0BD3_zps
Dashboard setup
Finally developed the dash creaking I've heard others complain of. I'll have to yank the dash when the weather warms to fix it. >Found the nice writeup on here.
I have that dash creaking too. I'am trying to find where it comes from for over a year now.
Still couldn't find what's causing it.
Didn't know that it's a common complaint.
It sounds like it's coming from somewhere in the left corner.
Take a look in the writeup I linked - the common failure is the 4 tabs that are part of the dash, accessed from under the wiper cowl. Sometimes the lower side screws just come loose - I had that - but mine has definitely progressed beyond that. I'm sure the stiffer suspension combined with the horrible road conditions in my neighbourhood over the past couple of years while the drainage and improvement plan has been in progress haven't helped.
DId another short pull today before the blizzard comes in. They're expecting 1-2' of snow, maybe more.
Screenshot2015-01-26120605_zpseb8c6648.pScreenshot2015-01-26120622_zps16514715.pScreenshot2015-01-26120741_zps9e260704_1
Added more fuel again, and reduced timing a smidge where the AFR's looked good, but knock was still present
  • Upvote 1
H, have any current video's of your car?
Yeah I almost asked this other day, it would be cool to see like 2-3 gear pull, just the cluster if it's easier.. It's been a while I believe...
I will make an effort to do this soon, when I'm not logging data of course.
Aha thanks!
That must be it, don't know why I never thought of that, while I do have some experience in removing a dasboard;
But that's a whole other story.
http://www.volvo850forum.nl/index.php/topic,63339.0.html
(sorry for the hjjacking won't do it again, just couldn't resist :) )
Nice! I'll have to check it out using Chrome.
Very nice looking logging setup! :)
Thank you - it's a bit of a PITA to setup the 'gauges'
Run today - felt pretty flat. AFR's are down in the 11's with the last changes I made. No knock or pull, so, I'm going to try raising the timing values back up a touch instead of lowering the VE map values
Screenshot2015-01-28211918_zps481e9a62.p
Highlights are the revised timing values
Guest
Reply to this topic...
  Only 75 emoji are allowed.
