Hussein's 1998 V70 Xr : The Force Awakens
lookforjoe
Pulls today after revised timing - had a touch of knock in 5th (steep uphill run) where the load drops & AFR's climbed, so I need to check that out , otherwise looks good in terms of AFR's and 'feel'.
It held the timing values I entered nicely, and that brought the AFR's just back into what seems the optimum range for my setup 12- 12.5 pretty much.
A couple of part load rich areas that I can lean out a touch, and up top I can reduce the WOT slider settings to lean it a touch in the 7300- up range. I ran it up to 7600 in 4th.
Screenshot2015-01-29161540_zps51b3adf8.p
Screenshot2015-01-29161822_zpsbf529233.p
Some VE changes - part load over 5K 16.129-16.212sec too lean, 4.127 - 4.911 too rich
Did some further part throttle/load tuning - found I was able to further increase timing rather than pull fuel in a few areas based on the rich AFR's (below 12) found
3rd Part throttle
4th Part throttle - increase fuel
same areas needing more fuel in 3rd WOT (over 72 TPS)
4th WOT
tables:
There is still some minor breakup/blowout not showing up in any logs - in the higher rpm/load ranges, so I'm going to try reducing the dwell times a small percentage. I can "feel" it & some sooting occurs (not sure if the sooting is everytime - I don't make it a habit of looking in the rearview at those levels)
Bad weather today - spent hours removing snow from the driveways. Almost got run over by an idiot in a minivan who clipped my calf/ankle as I was moving the snow blower at the end of my driveway. Why he was driving so close to a pedestrian I cannot fathom. Another inch or two over & he would have broken my leg (again) at the very least.
Last couple weeks
10408101_10152503550516370_5301173331657
10411180_10152506471076370_6867158454569
10500341_10152516222671370_6738133072133
Anyway, I was able to get a short run in to check overall state with dwell reduction. Felt good overall.
Screenshot2015-02-02184122_zpsed48c5e0.pScreenshot2015-02-02184134_zps27cea12a.pScreenshot2015-02-02184146_zps7e4fa2f3.p
Made some additional changes; pulled some WOT values, increased timing and fuel in a couple spots to try & level out the AFR's around 12.
H, wagon looks like it's moving properly fast now!
You should submit a couple pictures for this: http://www.speedhunters.com/2015/02/iamthespeedhunter-its-wagon-appreciation-time/
Agreed, you should absolutely enter your car in that!
Agreed. Hussein, put in for that... would be good to see a P80 chassis in that mix
Thanks, guys. I entered a submission today. Tried to keep it brief & to the point. Including a couple of my legal pad drawings ;)
EDIT: Definitely a glitch in the logging time on some pulls - it's can't believe it's possible for me to have 3sec 80-120 times. 60-100 is always around 4sec, so around 7 sec seems more likely. I'll set up my camcorder & get an alternative realtime video. The weather is not conducive for safe pulls at the mo, so as soon as possible.
  • Upvote 3
Dude I just saw the post about you getting clipped, you alright dude? did the cocksucker even stop???
Yeah, I'm fine. The wife would have called the cops on him if I wasnt. He did stop, mostly seemed concerned that he wasn't in trouble vs. any actual concern that I might be injured. Since I had no injury, I didn't see any point in calling the popo & filing a report. Brushed my ankle/calf and hip with the front fender of his minivan. Couple inches over and it would have been a different outcome for sure.. I think in retrospect, I should have called the cops anyway, since he clearly wasn't paying attention to his driving. Anyway, no point dwelling on it, I'm OK.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
