VulvaS40T4 Posted September 29, 2015 Report Posted September 29, 2015 I drove with my earlier engine 35000km with power level from 500-600hp on 1.878cc 16v white block engine. :) No problems. ;) Quote
dougy Posted September 29, 2015 Report Posted September 29, 2015 Wow...amazing ...i'm sure those were smooth trouble free kms. F1 could use your expertise...; ) Quote
lookforjoe Posted September 29, 2015 Author Report Posted September 29, 2015 I agree. If it were residual damage resultant from detonation in the process of tuning or something, that would be more understandable. But if in fact the break is due to cylinder liner wear, I don't know that the wear would be that accelerated with say an average of double the stock output.I also put 40k on a car in a year sometimes, so for me it's hard to imagine a properly conceived and clearanced setup like that to just reach end of life at that type of mileage. It is really hard to believe the problem was bore sizing. We went with Wiseco's spec on that, and the measured wear when I took it apart was not much over that. I can see 40K being OK in terms of life span in some situations, however the skirt breakage seems abnormal. I'm planning on sending them up to Trent if my guy has no word from his Wiseco rep. 1 Quote
blkaplan Posted September 29, 2015 Report Posted September 29, 2015 It is really hard to believe the problem was bore sizing. We went with Wiseco's spec on that, and the measured wear when I took it apart was not much over that. I can see 40K being OK in terms of life span in some situations, however the skirt breakage seems abnormal. I'm planning on sending them up to Trent if my guy has no word from his Wiseco rep.Did you post what the clearance was? Quote
lookforjoe Posted September 30, 2015 Author Report Posted September 30, 2015 (edited) Did you post what the clearance was? Specified bore ID per Wiseco was 3.209" (81.5086mm)After 40k, & broken pistons flapping around, I had wear of .03 - .05mm over specified bore. Edited September 30, 2015 by lookforjoe Quote
lookforjoe Posted December 7, 2018 Author Report Posted December 7, 2018 Working on fixing the pics - starting from the beginning. 3 Quote
BlackT5 Posted December 7, 2018 Report Posted December 7, 2018 That's going to be a job a half! If only you had left your photobucket images, they would now still show.. just with the watermark Quote
lookforjoe Posted December 8, 2018 Author Report Posted December 8, 2018 3 hours ago, BlackT5 said: That's going to be a job a half! If only you had left your photobucket images, they would now still show.. just with the watermark Yeah, ain't that a bitch :( Quote
NotanR Posted October 20, 2020 Report Posted October 20, 2020 On 5/29/2014 at 10:20 PM, rbodor3 said: Trimmed up the quote a bit. Since the volume of fluid has increased the volume of expansion also increases. I didn't measure the fill volume so I don't know how much I added, but I think it's 10-20% more with the torque converter cooler no longer required (MT swap) as well as the increased core depth, by about inch/2. If you haven't had any issues it makes me curious if I'm having a different cooling issue. I assume the PN on the reservoir is common between MT/AT. Wanted to clarify this post (years later) that I found a hairline crack on the expansion tank cap shortly after this post, and a hairline crack on the reservoir itself a year-or-so later. These had both been causing me to overflow coolant. There is no expansion issue that I've found, as-supported by others' findings. 1 Quote
