mdlimy Posted January 8, 2010 Report Share Posted January 8, 2010 Is it possible to use a distributor cap with the newer head? Also, is there a way to modify a newer type inlet manifold with use of an normal inlet(mechanical)? In short I need: <99 head Block plate for solenoid Headgasket <99 head Modified Camshaft sensor NA inlet cam/Turbo exhaust cam Inlet manifold Upper engine mount That's it? htownturbobrick used a distributor on his 00 R motor in his s70. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted January 8, 2010 Report Share Posted January 8, 2010 Spanky = newer engine :lol: :lol: :lol: :lol: Link to comment Share on other sites More sharing options...
dongle Posted January 8, 2010 Report Share Posted January 8, 2010 Is it possible to use a distributor cap with the newer head? Also, is there a way to modify a newer type inlet manifold with use of an normal inlet(mechanical)? In short I need: <99 head Block plate for solenoid Headgasket <99 head Modified Camshaft sensor NA inlet cam/Turbo exhaust cam Inlet manifold Upper engine mount That's it? If you are using a 99-00 head I'm pretty sure you just need to modify the rear of the intake cam for the distributor. I'm not sure about swapping the cams entirely or if thy mount up on the newer heads. I'm not sure you need to modify the cam sensor, I don't think Aaron mentioned anything like that. Also, the new style manifolds suck. It's pretty easy to find the older style for almost nothing anyway. Edit: You have no sig. I can only assume that you're swapping into an x70. Link to comment Share on other sites More sharing options...
mdlimy Posted January 8, 2010 Report Share Posted January 8, 2010 If you are using a 99-00 head I'm pretty sure you just need to modify the rear of the intake cam for the distributor. I'm not sure about swapping the cams entirely or if thy mount up on the newer heads. I'm not sure you need to modify the cam sensor, I don't think Aaron mentioned anything like that. Also, the new style manifolds suck. It's pretty easy to find the older style for almost nothing anyway. Edit: You have no sig. I can only assume that you're swapping into an x70. when you say "new style manifold" are you comparing the <98 manifolds to the 99- ETM manifolds. or do the 03 and up motors have a new style manifold? Link to comment Share on other sites More sharing options...
nickk. Posted January 8, 2010 Report Share Posted January 8, 2010 Mean the old manifold to the newer '99 ETM manifold. Best should be an <2001 and later head, but I dont know of they will work with old style ignition(distributor cap). Sign is not important. Has build an underblock already, but with a little luck I can sell it for a good price, so I can start over with a newer type crankshaft, all balanced with flywheel to use with higer RPM with new type head. Link to comment Share on other sites More sharing options...
dongle Posted January 9, 2010 Report Share Posted January 9, 2010 when you say "new style manifold" are you comparing the <98 manifolds to the 99- ETM manifolds. or do the 03 and up motors have a new style manifold? Sorry. Old = -98. New = 99+ And no, you wouldn't want to put a '99+ manifold on a 4.3/4.4 car. Link to comment Share on other sites More sharing options...
