gotboost Posted January 7, 2010 Author Report Share Posted January 7, 2010 You're correct, no length change required if you space off all body to suspension connection points. A bit more work though. If I ever get my hands on another XC70 I might just build another lift for it and send the wife off to the grocery store Cool. Thanks for the clarification Lucky. So what exactly did you end up doing for the front upper strut mounts on the car you did? Link to comment Share on other sites More sharing options...
Ipd Posted January 7, 2010 Report Share Posted January 7, 2010 Had two pieces of steel plate cut that was the same shape as the upper mounting plate on the factory setup. Then took a 5 inch diameter section of tube and cut a 4 inches peice. Welded the tube between the two laser cut plates and install between body and strut. Link to comment Share on other sites More sharing options...
gotboost Posted January 7, 2010 Author Report Share Posted January 7, 2010 Had two pieces of steel plate cut that was the same shape as the upper mounting plate on the factory setup. Then took a 5 inch diameter section of tube and cut a 4 inches peice. Welded the tube between the two laser cut plates and install between body and strut. Genius...That sounds super simple. Don't have any spares of those laser cut plates around, do ya'?? :D Link to comment Share on other sites More sharing options...
