ozzimark Posted January 5, 2011 Report Share Posted January 5, 2011 Putting the VVT cam in the place of a non-VVT cam won't require any blocking on the head, because there is nothing to be blocked on the head, they don't machine the sealing surface and oil passages when VVT isn't needed: As for the hub itself, it should get pulled to it's fully retarded position during operation if there is no pressure on the VVT gear, but I haven't messed with an intake cam with VVT to know for sure. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2011 Author Report Share Posted January 5, 2011 That's all good news! I must have misinterpreted Johann's post on the cam differences. The only bug-bear of all this will be adjusting the valve lash if you swap cams on a solid lifter head. If you get a used cam, you better get all the lifters in order (to hopefully minimize the need for adjustment) with it, otherwise you may end up buying a full set of solid lifters in order to adjust clearances. Link to comment Share on other sites More sharing options...
Captain Bondo Posted January 5, 2011 Report Share Posted January 5, 2011 non vvt late style cams will fit in a vvt head no problem assumingt yuou have the solenoid ports blocked off. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted January 5, 2011 Report Share Posted January 5, 2011 The only bug-bear of all this will be adjusting the valve lash if you swap cams on a solid lifter head. If you get a used cam, you better get all the lifters in order (to hopefully minimize the need for adjustment) with it, otherwise you may end up buying a full set of solid lifters in order to adjust clearances. I'm sure you'll get a valve job done on the head you're getting. When they cut the seats your valve lash may change anyway (get tighter). My machine shop was able to adjust the valves for me by cutting the top of the valve stems to get the proper clearance. Didn't need to buy any new tappets. If you got a used cam and the valves are too loose then yes you probably would need to change tappets. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2011 Author Report Share Posted January 5, 2011 I'm sure you'll get a valve job done on the head you're getting. When they cut the seats your valve lash may change anyway (get tighter). My machine shop was able to adjust the valves for me by cutting the top of the valve stems to get the proper clearance. Didn't need to buy any new tappets. If you got a used cam and the valves are too loose then yes you probably would need to change tappets. That's the approach my guy said he would use for adjusting the valves if needed - that won't work for people who already have a head installed - which is what I assumed was Neu's situation. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted January 5, 2011 Report Share Posted January 5, 2011 that won't work for people who already have a head installed - which is what I assumed was Neu's situation. True, I wasn't even thinking about people that were just changing cams. My bad :monkey: Link to comment Share on other sites More sharing options...
Fishey Posted January 5, 2011 Report Share Posted January 5, 2011 Still intrested in late Turbo cam Duration anyone have it? Link to comment Share on other sites More sharing options...
ozzimark Posted January 5, 2011 Report Share Posted January 5, 2011 Still intrested in late Turbo cam Duration anyone have it? Which ones? There are a few different turbo cam PNs. I have 9207943 and 9207944 sitting next to me for measurement later today. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2011 Author Report Share Posted January 5, 2011 Still intrested in late Turbo cam Duration anyone have it? That's what we're trying to find out (and lift of course). Link to comment Share on other sites More sharing options...
ozzimark Posted January 5, 2011 Report Share Posted January 5, 2011 I'm making a table of what engines had what cams on specific years. There will be a list of all the cam part numbers that indicates lift and duration, once we find that info.. If anyone spots any errors (there must be some ), or has PNs for the spots I am missing, post them up! Edit: deleted out of date image :lol: Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2011 Author Report Share Posted January 5, 2011 I'm making a table of what engines had what cams on specific years. There will be a list of all the cam part numbers that indicates lift and duration, once we find that info.. If anyone spots any errors (there must be some ), or has PNs for the spots I am missing, post them up! Add the '05 B5254T2 cam #'s to the 03-04 columns did you take info from the post where I included the pn's? Link to comment Share on other sites More sharing options...
ozzimark Posted January 5, 2011 Report Share Posted January 5, 2011 The first post, no, because it didn't make any sense. The second post, yes. Just measured up my cams: intake duration @ lift 275º @ 0.001" 222º @ 0.015" 153º @ 0.050" exhaust duration @ lift 286º @ 0.001" 236º @ 0.015" 168º @ 0.050" I wish I knew what lift the duration on the old turbo and NA cams are measured at... Edit: these cams. If it's measured at 0.001, the VVT cams certainly have a lot more duration NA Intake cam: 250º, 8.45 mm Exhaust cam: 252.6º, 8.45 mm Turbo Intake cam: 242º, 7.90 mm Exhaust cam: 243.5º, 7.90 mm Link to comment Share on other sites More sharing options...
Fishey Posted January 5, 2011 Report Share Posted January 5, 2011 Duration is usually measured at .006 lift. Can you measure the cams at that lift? You using a degree wheel + Dial indicator? I don't have time or access to my later heads ATM so if you could give more details on what year the cams are from that be cool. -Your Pal Fishey Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2011 Author Report Share Posted January 5, 2011 The first post, no, because it didn't make any sense. The second post, yes. Dual VVT B5254T4 (V70R,S60R) & B5244T5 (T5) intake cam 3063410 B5254T2 intake cam 8670354 B5254T2/T4 & B5244T4/T5 exhaust cam 8642712 Single VVT B5234T3 Intake cam -01 9207943 Intake cam 02- 6900044 Exhaust cam -01 9207944 Exhaust cam 02-04 9497822 Exhaust cam 05- 8642712 NA Intake Cam (VVT) for reference All B5244S/S2/S6 intake cam -02 9497735 intake cam 03- 8627280 Is that better? Link to comment Share on other sites More sharing options...
ozzimark Posted January 5, 2011 Report Share Posted January 5, 2011 Well, there is no 05+ B5234T3, they stopped making 2.3l engines after '04 They did, the C70 got them. I'm not agreeing with your PNs based on my version of VADIS. For example, I'm seeing that 6900044 was used in 03+ B5234T9. Unfortunately, I forgot to bring a copy of that excel chart home with me to make changes. Duration is usually measured at .006 lift. Can you measure the cams at that lift? You using a degree wheel + Dial indicator? I don't have time or access to my later heads ATM so if you could give more details on what year the cams are from that be cool. -Your Pal Fishey Thanks Fishey. I'll check them out at 0.006" tomorrow. That is from a 2002 B5234T3. Link to comment Share on other sites More sharing options...
