What Cylinder Head To Use For Best Performance With 2.3L Block?
lookforjoe
Austen i am surprised your flow numbers are that low actually- a stock Volvo 16v flows about 230cfm and a stock 'Yota 2jZ head flows about 250cfm (valves are about 2mm larger than stock Volvo RN valves).
Have you talked to RSI at all about head development?
I seem to recall they were getting north of 300cfm from late rn castings when thye were playing with them (I want to say 310 @ 28").
I don't know what sort of port volumes/velocities they were ending up with though.
  • Replies 284
Do tell more!
God...talking about heads makes me so horny.
I think the figures for my head are very good as the coefficient is 0.62 for the valve size which as good as your going to get unless you spend another 100 hours to get that extra 0.02
I suppose it all depends on what flow bench you run, what pressure, what bore size etc
Yes I've been speaking alot with the guys who did all the development at TWR for the British touring cars
Mine was run with 25" on an 81mm bore at 0.5 inch lift
Yes I'm running my engine N/A
I'm amazed by the flow figures of the head above
My head is exactly the same running larger valves with a flow coefficient of 0.62 which is about at its max for an OEM casting
The British touring car head was 0.67 efficiency with a £15'000 custom head, that ran 325bhp at 8500rpm
I'm amazed you managed 290cfm with smaller valves than me, 50cfm is a huge difference for the same head at similar pressures
Can you post up flow results
That is not my motor, it is one built by a guy in Sweden. I have asked for the flow sheet.
I found out the cams have a lift of 11.8mm and 290 degrees
This is picture I found a while back from a thread
Is this your head?
The error they have made when flow testing this head is to use a 3.4 inch bore which is 86.36mm
I dont know of any Volvo 5 cyl running that size bore
Either 81mm or 83mm else it will show inflated figures as the valves are deshrouded which is not a real world tests in my opinion
Riddle me this - who makes valves/where can you get larger valves for the late (P2) turbo heads?
I believe he is doing 9K 9200 RPM on that engine. Could be that the belt starts to wobble. Polestar is using the same setup on their 8750 RPM NA engine.
I see. Must be an NA head - he's got the block-off plate on the intake side, also. Guess it doesn't matter, if you're swapping out all the valves anyway...
  • 7 months later...
... a stock 'Yota 2jZ head flows about 250cfm (valves are about 2mm larger than stock Volvo RN valves).
the only 2jz numbers i have ever seen are more like ~220cfm @ .5" lift and 28" of water.
so honestly, 240 @ the same lift and 25" sounds not-too-shabby imo.
