550 Posted March 1, 2010 Report Share Posted March 1, 2010 Yeah I was pretty fricken amazed. Hopefully the k24 will break me into the 13's. I would be happier then. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 1, 2010 Report Share Posted March 1, 2010 Do want K24, but i have my eye on a 50 trim i want Link to comment Share on other sites More sharing options...
magicaljake Posted March 1, 2010 Report Share Posted March 1, 2010 I know theres a few of us that run 13's with our t5m's on stock turbos, i only made 265whp and 380ft lbs. I'm holding off swapping the new turbo on til i break 12's hopefully before carlisle because i want to put the new turbo on before may i was knocking on 13's door with only a mbc @ 13 psi... now i should have no problems :) Link to comment Share on other sites More sharing options...
550 Posted March 1, 2010 Report Share Posted March 1, 2010 Regardless of what turbo you have there, it looks to be WAY faster than mine. I'm running 14 psi with the k24. I mean I would have to say even at 17psi on my car you would still be a head. I need to get my water injection back on so I can advance timing a bit. Stupid winter. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 1, 2010 Report Share Posted March 1, 2010 i was knocking on 13's door with only a mbc @ 13 psi... now i should have no problems Hopefully not, but moar power yields more wheelspin, i'm really suprised you hook up as well as you do in 2nd Link to comment Share on other sites More sharing options...
magicaljake Posted March 1, 2010 Report Share Posted March 1, 2010 Hopefully not, but moar power yields more wheelspin, i'm really suprised you hook up as well as you do in 2nd i know right? 195 65 15 hakka 2's ftw i need to buy new tires for my pegs this summer.... i may swing for something nicer for tractions Link to comment Share on other sites More sharing options...
S8ET6 Posted March 1, 2010 Author Report Share Posted March 1, 2010 For a chance at 500 bucks? I ran a 13.2 on street tires, you should come to carlisle with Val and them from Ohio 13.2 on street tires, with a 16T? impressive. Can you post the time slip? I'm considering coming to Carlisle with Leroystew and the rest of the Chicago caravan Link to comment Share on other sites More sharing options...
Snabb T5M Posted March 7, 2010 Report Share Posted March 7, 2010 Yes, I'm finally back from New Zealand. Ok, I'll bite, I'm in for the call out. Let's pick a date, maybe next Sunday. I'm shocked that there isn"t a call-out page on VolvoSPEED used to post friendly, (legal) speed challanges - so this here's one! Leeee Roy. Come out and play-yay ! Beginning 3/7, US41 is open every Sunday @ noon for test/tune and grudge match racing. I expect to beat you thru the 1/8th, but with your trap speed, I also expect you to begin reeling me in somewhere around the 1/8th marker. It's just a question of do you have enough HP to get in front before the ¼ is over. Let's set something up and find out. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 12, 2010 Report Share Posted March 12, 2010 Yes, I'm finally back from New Zealand. Ok, I'll bite, I'm in for the call out. Let's pick a date, maybe next Sunday. You went to new zealand? i'm a born and raised Kiwi, moved to the united states 12 years ago, i was born just outside of auckland in manuakau/papatoetoe area Link to comment Share on other sites More sharing options...
L8 APEKS Posted March 12, 2010 Report Share Posted March 12, 2010 You went to new zealand? i'm a born and raised Kiwi, moved to the united states 12 years ago, i was born just outside of auckland in manuakau/papatoetoe area So...you say your car made 380 tq at the wheels?! Wow. Are you sure the dyno was accurate? I looked up about 10 dyno threads in the Performance section, and the ONLY one I saw that broke 300 was Leroy...at 308 tq... 1998 S70 T5M; 100K+ miles; IPD Stage I ECU; 16T with extra large angled flange; EST RIP; R manifold; EST 3" DP; IPD 2.5" exhaust with TME muffler; MSD coil; EST air intake; balanced crank with LGSpeed rods; 3 angle valve job; Stylin Motors silicone hoses; IPD HD TCV; VIVA CBV; Koni struts; IPD springs/IPD sway bars; 302mm rotors; SS brake lines; SPEC III clutch, 17" IPD Pegs; Sconeman short shifter and delrin shifter bushings; TurboSmart Eboost2; ----14.08 @ 105.89 mph I'm not sure what it is about the S70 T5M that makes so much more TQ than the 850 auto, but for comparison, with an 18psi tune on the 15G and a 3" turbo back, I put down 263 tq - or 117 lb/ft less than your car. Is it in the trans? Something about the engine or cams? The difference in dyno numbers is huge. S70 manual makes way more power, mod for mod, than an 850 auto, according to all the dyno threads I've been reading. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 12, 2010 Report Share Posted March 12, 2010 Its a torque spike, since i'm internally gated, and i had a bad o2 sensor and a failing maf, i was only holding 13psi at 5200rpms, i have another dyno around here somewhere... i now run 20psi and hold 17psi - redline in 3rd and 4th gear and 5th are 22psi and 20psi redline Bad dyno So...you say your car made 380 tq at the wheels?! Wow. Are you sure the dyno was accurate? I looked up about 10 dyno threads in the Performance section, and the ONLY one I saw that broke 300 was Leroy...at 308 tq... 360 on this dyno and 380 is the best i ever made, 265whp is the best i ever made on a dyno You can see in the dyno graph that at 5k my torque is only at 300 and continues to die off I used to run 24-26psi and hold 22psi but its way out of the efficiency range off the turbo Link to comment Share on other sites More sharing options...
L8 APEKS Posted March 12, 2010 Report Share Posted March 12, 2010 That makes sense then! I was at 239whp with the chipped 15G/exhaust and auto. All of the Mitsus on our cars are internally gated...do you know what's causing that spike?? Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 12, 2010 Report Share Posted March 12, 2010 That makes sense then! I was at 239whp with the chipped 15G/exhaust and auto. All of the Mitsus on our cars are internally gated...do you know what's causing that spike?? not running a bcs or mbc, wastegate doesn't react fast enough Link to comment Share on other sites More sharing options...
S8ET6 Posted March 12, 2010 Author Report Share Posted March 12, 2010 So...you say your car made 380 tq at the wheels?! Wow. Are you sure the dyno was accurate? I looked up about 10 dyno threads in the Performance section, and the ONLY one I saw that broke 300 was Leroy...at 308 tq... 380ft/lbs of torque could result in low 13s - assuming that it wasn't a torque spike. I'm still waiting to see a 13.2@106 timeslip. I'm not sure what it is about the S70 T5M that makes so much more TQ than the 850 auto, but for comparison, with an 18psi tune on the 15G and a 3" turbo back, I put down 263 tq - or 117 lb/ft less than your car. Is it in the trans? Something about the engine or cams? The difference in dyno numbers is huge. S70 manual makes way more power, mod for mod, than an 850 auto, according to all the dyno threads I've been reading. drive-train loss from an auto trans accounts for a significant reduction in power compared to a manual trans, but in the rpm range where your TC stallspeed is, (where dyno pulls aren't usually started), torque convertors actually multiply the motor's torque output significantly edit: sorry, I started this reply then took a call. Coral had commented on the torque spike by the time I posted this reply Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted March 12, 2010 Report Share Posted March 12, 2010 380ft/lbs of torque could result in low 13s - assuming that it wasn't a torque spike. I'm still waiting to see a 13.2@106 timeslip. drive-train loss from an auto trans accounts for a significant reduction in power compared to a manual trans, but in the rpm range where your TC stallspeed is, (where dyno pulls aren't usually started), torque convertors actually multiply the motor's torque output significantly edit: sorry, I started this reply then took a call. Coral had commented on the torque spike by the time I posted this reply Yea sorry i've been working real long hours, i haven't had a chance to look, if anything i'm going to run at the track next week, and i'll make sure to get High Def videos and time slips, that 13.7 i posted was me letting off at the 1000' mark too. Link to comment Share on other sites More sharing options...
