lookforjoe Posted December 10, 2010 Report Posted December 10, 2010 Yes, replaces the existing cover, and spliced with the wiring for the side markers. Cool! I'll buy them now :D 1 Quote
550 Posted December 11, 2010 Report Posted December 11, 2010 TT and k24 , could be hard to come across. I can tell you that you can run 18-19psi on stock block. Just make sure that you will not exceed 10psi before 3500 rpms. Work with fuel map . Timing has a pretty good map that comes preloaded with tt. Ummmmmmmmmmm I hate to burst the bubble but I have been in the 15 range at 2500 with out issue. Just don't be a dumbass. I try to wait till 3k before I really get on her. (2.4 higher CR block) 1 Quote
ErikS Posted February 4, 2011 Author Report Posted February 4, 2011 Edit ... (This is Trent's 854TGA+ intake manifold test fitted on my car) 1 Quote
DesertFox Posted February 4, 2011 Report Posted February 4, 2011 very nice add to the engine, are you adding a atech cooler or moving for a FMIC 1 Quote
lookforjoe Posted February 4, 2011 Report Posted February 4, 2011 Nice! Is that from Aaron? The runners look shorter & more elevated of an angle than the one he pictured..... 1 Quote
Falcone Posted February 4, 2011 Report Posted February 4, 2011 Now thats slick Erik. You do know you just cant post that pic and not give away the specs/details. That would just be mean. Awesome ride Erik. Cheers 2 Quote
ErikS Posted February 4, 2011 Author Report Posted February 4, 2011 very nice add to the engine, are you adding a atech cooler or moving for a FMIC A 3'' core front mount. Nice! Is that from Aaron? The runners look shorter & more elevated of an angle than the one he pictured..... Yep! Now thats slick Erik. You do know you just cant post that pic and not give away the specs/details. That would just be mean. Awesome ride Erik. Cheers I'm going with a 00'R head, so specs and details will be forthcoming ... Looking good Erik. Loving the manifold Thanks! 1 Quote
Mesoam Posted February 4, 2011 Report Posted February 4, 2011 where are the new seats holmes? you going to do a harness bar too? 1 Quote
ErikS Posted February 4, 2011 Author Report Posted February 4, 2011 where are the new seats holmes? you going to do a harness bar too? On there way ... and I probably won't do a harness bar right away. Finishing the engine build comes first. Quote
the commissar! Posted February 4, 2011 Report Posted February 4, 2011 TT and k24 , could be hard to come across. I can tell you that you can run 18-19psi on stock block. Just make sure that you will not exceed 10psi before 3500 rpms. Work with fuel map . Timing has a pretty good map that comes preloaded with tt. I'm running 18 psi on my 18T with stock internals (for now). Im running a Hallman Pro MBC in parallel to an IPD HD-TCV to help keep me out of trouble. I've been tweaking the fuel map but am not satisfied with it yet. I'm afraid to just romp on her but I rarely see >12 psi under 3600 rpm. I probably would if I just floored it but I want to keep her in great running order so I ease into high boost. Using base performance ignition timing map and it seems quite good so far. I'm interested to hear more about your (and everyone elses) TT adventures. 1 Quote
ajhehr Posted February 4, 2011 Report Posted February 4, 2011 manifold is at 20%, the same as the intake port. runners are the same length as nicks. long(er) runners on the way... 1 Quote
magicaljake Posted February 5, 2011 Report Posted February 5, 2011 well first of all that manifold is sex your stance is sex your car in general is sex 2 1 Quote
ErikS Posted February 18, 2011 Author Report Posted February 18, 2011 long(er) runners on the way... 2 Quote
