Afr'S
project_850
What are your WOT AFR's?
24 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Mine seems to start at 12, settle at 11, then when the boost fades, drop under 11. I put 11-11.9?
Mine is on a progressive curve from lean at low loads to 12.1 at WOT in every gear. That was recorded on a RR. I see better AFRS on the street.
FWIW I found a minor boost leak of approx 1psi (that I only noticed up in the higher rpms, the tune was hitting 17+ in the lower rpms). It seemed to raise my afr's about 0.5. The tune I have (RICA stage 2) seems like it is setup to run 17 psi @ 12 afr, but the afrs get richer as I get up there in the RPMs and the boost fades.
Also, I had good vacuum of about 20 before I found the leak. Vaccuum is just slightly better and I can barely tell on my analog guage.
At some point I'm going to talk to a shop about smoke testing and see if I can find any others.
Long story short, the first place I would look is a boost leak.
I draw 20 in HG too @ idle, 24HG @ decel. Pressure tested, no leaks. But I'm only running 10 psi at this point so that could be why. Gonna check the MAF tonight.
Are you running stock ECU?
Just cleaned the MAF. Running at 11's now :lol: Yes I'm running the stock 225 R ECU for now--I wanted to see how the car would react seeing as how it came from the factory with white injectors. With boost set at only 10psi, it definitely runs pig rich. Not gonna be turning it up until I receive my revised Stage III tune in the mail.
