ozzimark Posted June 27, 2010 Report Share Posted June 27, 2010 Note: This is what information I could find, and cannot guarantee that it is all correct, but I believe it is. If you know of anything I said in here that isn't correct, let me know and I will edit it. To make this post sensible, I am organizing into several sections, Overview/history, Block/Internal info, Head/Cam info, and finally, some additional reading that is related to the RN engine. Overview and history Over the last couple weeks, I have been scouring the internet for everything I can find on the Revision N whiteblocks, or RN for short. A quick background for those who aren't familiar with RN, when Volvo originally introduced the modular whiteblock engines, they were also known as the "N series". Over the years, Volvo made lots of incremental changes, adding then removing EGR and SAS, changing the Motronic version, switching timing belt tensioners, going to a dual mass flywheel, along with a few other things. However, the basic internals of the engine stayed the same until around the turn of the millennium In 1999, the first of the RN engines made their appearance. According to this PR piece from Volvo, which I believe to be from '99, states that "They are now also available in the naturally-aspirated engines in the Volvo S40, Volvo V40, Volvo S70, Volvo V70 and Volvo C70 Coupe and, within the space of the next one to two years, these engines will also be introduced in most of the turbocharged models." From this, arises some confusion. The '99 and up T5 engines have VVT on the exhaust, which implies that they are RN engines, but some differences, such as modified coolant paths in the cylinder head don't arrive until '00. Simply put, my understanding on when the the different engine models changed to the RN series is unclear, but I do know that by 2001, all 5 and 6 cylinder engines are the Revised version. Engine Block and Interals Now we can get down to the nitty gritty stuff that I wish there was better documentation on, but the people who know the answers tend to keep it to themselves On the inside, there were a lot of changes. RN engines got longer rods in 2002, with a few exceptions, increasing the length from 139.5 mm to 147mm. The engines that went into the S60R and V70R got thicker rods that are 143mm long. To match the change in rod length, the pistons got a shorter compression height and shorter skirts. To balance the change in reciprocating weight, they also got a lighter crank and smaller gudgeon pins for less weight and friction, for a total weight savings of 3.5-4.5kg (7.7-10lbs). The increased rod length improves the atrocious rod/stroke ratio, helping the engine develop a bit more torque, and allowing it to rev a little higher before destroying the pistons. Combined with the shorter skirts, the friction is reduced. To improve windage in the crankcase, windows were added (See images in post #19). All RN blocks have oil squirters to help cool the pistons, not just turbos. There have been rumors of issues with harmonics at high power levels due to the lighter crank, although I cannot find good evidence or reports of this, and it may only apply to the 2.5L blocks. Take with a grain of salt until I can confirm or deny this According to Jan at Wurthrline, the turbo engines got new (stronger) rods and pistons in 2002, which seems redundant, given the changes that were just made a few years prior. My suspicion is that it is similar to what happened in the late model redblocks, when the rod size changed from 9mm to 13mm, but the length of the hardware remained the same. It is unclear if the '01-04 engines use the same rods as the '05+ engines. The stroke increases from 90 to 93.2mm when going from the B5234T3 to the B5254T3, bore changes from 81mm to 83mm. Both connecting rods are 143mm in length, center to center. For reference, the rods from the 05+ B5254T3 weigh 644 grams each Cylinder Head and Cams Possibly the most important changes were made to the head. In the late '99 time frame, Volvo started changing the heads over from hydraulic to solid valve lifters. The heads with solid lifters have approximately 20% larger intake ports, modified coolant and oil passages, and should bolt up to the previous revision blocks. The base circle on the cam increased 2mm. In addition the valve stem diameter changed from 7mm to 6mm. Intake and exhaust valves remained constant at 31mm and 27mm diameters, respectively. Over the years, VVT was introduced in varying configurations. For single VVT setups, turbos got VVT on the exhaust, N/A got VVT on the intake. A rough breakdown for the turbo 5cyls: 1999-2000 99 2.3 T5 Single VVT 99 2.4 LPT Single VVT 00 2.4 R Single VVT 2001-2004 2001-2004 2.3 T5 Single VVT 2001-2004 2.4 LPT Single VVT 2005-2009 2.4 T5 Dual VVT 2003-2009 2.5 LPT Dual VVT 2004-2009 2.5 R Dual VVT Other things besides VVT also changed: Valve length and lift from Hydro to Solid lifter heads If anyone has duration numbers, I'd love to complete this chart!! Intake Exhaust Length Lift Duration Length Lift Duration -98 B5244 N/A 8.45 250 8.45 252.6 (Note: some '93, and maybe '94, N/A engines got more aggressive cams) 1999 B5244 N/A 104.05 8.65 103.30 8.80 2001 B5244 N/A 104.25 8.65 103.30 8.80 -99 B5234T3 104.05 7.95 242 103.30 7.95 243.5 2001 B5234T3 104.25 8.40 103.30 9.05 2001 B5244T3 104.25 8.45 103.30 9.05 There have been anecdotal reports of the solid lifter heads flowing much better than the hydraulic lifter heads, even after the older heads have been modified: the later solid lifter head flows more stock then my hydraulic lifter head with full gasket match and port and polish. If you use a head with VVT with an ECU that doesn't normally control the VVT, Lucky posted up a great tip on how to drive the VVT solenoid. If you don't drive the solenoid, be sure to block off the solenoid port, or the VVT will adjust itself He also posted some info on using the new style head on an older engine. Here's what I can add. Latest version R head gasket is MLS (multi layer steel) like a Cometic, this is the stock replacement. I got mine from Victor Reinz. The cooling ports are different, they are staggered and will provide better cooling. Oil feed and crankcase drain ports are all compatible. If you use a non CVVT head with the MLS gasket you'll have to drill a few ports into the cooling passages in the head to get adequate cooling. So this means a CVVT head will bolt onto a non CVVT block. You cannot to my knowledge put a non CVVT cam in place of a cam that was CVVT. The journals are significantly different, this is true for any potentional non CVVT cam be it earlier 870 style or later P2 style. Obviously modification could be made to the head but it's not a drop in. You can run a CVVT system on a car that didn't come equipped with it but you'll need a controller. To control the CVVT solenoid you only have to vary the duty cycle - on time. The frequency is fixed at 250 hz. Acceptable duty cycle ranges from 20% to 95%. The easiest way to control it is by setting up a 555 timer to trigger a TIP120 power transistor off a boost pressure sensor. 555 fixes the frequency at 250hz and the change in boost pressure (resistance change) will retard/advance the cam as load (boost) is increased. Basic knowledge of electronics and IC is required to implement. Setting up a proper advance/retard setting depends on mods but for a free flowing engine with aftermarket exhaust, downpipe, intake, intercooler, etc.. added overlap can be beneficial while stock engine will be better off with less overlap. Additional Reading Why Build? Cylinder Head Question What cylinder head to use for best performance with 2.3L block? Upgrade NA cams, intake only or both? Exact cam specifications "2nd Gen" Whiteblock? Link to comment Share on other sites More sharing options...
95 854 t-5 Posted June 29, 2010 Report Share Posted June 29, 2010 No replies to this thread that's sad Bump for a ton of good info that could be pinned in a "so you wanna build" thread Link to comment Share on other sites More sharing options...
bum2kev Posted June 29, 2010 Report Share Posted June 29, 2010 good info. good to see our work in the past is being put in one place... anyone thats thinking of "building" an engine should look at this first. Link to comment Share on other sites More sharing options...
scandalo Posted June 29, 2010 Report Share Posted June 29, 2010 I found that most useful info on this site gets overlooked, very rarely stickied, and therefore lost. This is some kick ALL GLORY TO THE HYPNOTOAD info. Especially if you want to seriously modify your engine. The head swap info is very interesting. Link to comment Share on other sites More sharing options...
Burn-E Posted June 29, 2010 Report Share Posted June 29, 2010 Note: This is what information I could find, and cannot guarantee that it is all correct, but I believe it is. If you know of anything I said in here that isn't correct, let me know and I will edit it. However, the basic internals of the engine stayed the same until around the turn of the millennium In 1999, the first of the RN engines made their appearance. According to this PR piece from Volvo, which I believe to be from '99, states that "They are now also available in the naturally-aspirated engines in the Volvo S40, Volvo V40, Volvo S70, Volvo V70 and Volvo C70 Coupe and, within the space of the next one to two years, these engines will also be introduced in most of the turbocharged models." From this, arises some confusion. The '99 and up T5 engines have VVT on the exhaust, which implies that they are RN engines, but some differences, such as modified coolant paths in the cylinder head don't arrive until '00. Simply put, my understanding on when the the different engine models changed to the RN series is unclear, but I do know that by 2001, all 5 and 6 cylinder engines are the Revised version. This is not entirely correct since the C70 NEVER came with an N/A engine - at least not in North America. It was always either LPT or HPT. So if they were correct in including it that would lead me to believe that the RN engine was available in the 1999 C70 turbo charged version. Link to comment Share on other sites More sharing options...
ozzimark Posted June 29, 2010 Author Report Share Posted June 29, 2010 Thanks guys, I've put a lot of effort into trying to collect and organize all this information. It's still pretty incomplete though. This is not entirely correct since the C70 NEVER came with an N/A engine - at least not in North America. It was always either LPT or HPT. So if they were correct in including it that would lead me to believe that the RN engine was available in the 1999 C70 turbo charged version. I believe that the Volvo PR that you're quoting applies to the entire world, not just our little corner. According to SIDAV the Coupe came in N/A form in '99, and the convertible in '00. However, You're right in the sense that as long as I've been obsessed with Volvos, I have never seen an N/A C70 Does anyone know if the '99 C70 got solid lifters, or hydraulic? As far as the modifications to the head go, with respect to engine building, I really can't see any reason why someone would want to use the older style head, especially considering the Why Build? thread that Johann posted, with the stock 2003 B5234T3 block making ~450 crank hp. I know Aaron didn't post flow numbers, but I would love to know just how much better the new head flows. Also take particular note of the 2001 B5244T head, from the 2.4T, the intake cam has slightly more lift than the HPT intake cam, and I would suspect it has a longer duration as well. I know what head I want for my project B) Link to comment Share on other sites More sharing options...
mdlimy Posted June 29, 2010 Report Share Posted June 29, 2010 yea i noticed that vadis shows an NA c70. I agree that alot of this important stuff NEVER gets stickied and its a real shame because people are dumping money into old 2.3 blocks when much more gains are to be had out of the newer motors. there is alot of good info in that cylinder head thread of Hussein's also, lets get it all together and get it STICKIED! STICKY STICKY STICKY STICKY STICKY STICKY STICKY Link to comment Share on other sites More sharing options...
harleyhv Posted June 29, 2010 Report Share Posted June 29, 2010 STICKY STICKY STICKY STICKY STICKY STICKY STICKY +1 learned quite a lot in this thread Link to comment Share on other sites More sharing options...
greekone Posted June 29, 2010 Report Share Posted June 29, 2010 Vote #3 to sticky! Link to comment Share on other sites More sharing options...
Mogatu'r Posted June 29, 2010 Report Share Posted June 29, 2010 +1 learned quite a lot in this thread same here, why hasn't someone done it already. This thread should be in the sticky section. kudos to the OP! Link to comment Share on other sites More sharing options...
Spanky Posted June 29, 2010 Report Share Posted June 29, 2010 Great thread Ozzie!!! Any more info on the cam swap for non VVT head to a VVT head? Link to comment Share on other sites More sharing options...
ozzimark Posted June 29, 2010 Author Report Share Posted June 29, 2010 Great thread Ozzie!!! Any more info on the cam swap for non VVT head to a VVT head? The best info I've found on that is posted by Johann, here: http://volvospeed.com/vs_forum/index.php/topic/127747-upgrade-na-cams-only-intake-cam-or-upgrade-both-intex-on-my-850-t5-r/page__st__80__p__1709858#entry1709858 Unless you're talking about swapping the whole head, not just the cams. Swapping the cams seems to be a relatively challenging undertaking, due to the differences in cam seals :ph34r: Link to comment Share on other sites More sharing options...
the commissar! Posted June 29, 2010 Report Share Posted June 29, 2010 I have read those threads many many times...It would be wonderful to have this pinned. Thanks for gathering it all together ozzimark! Link to comment Share on other sites More sharing options...
NEU Posted June 29, 2010 Report Share Posted June 29, 2010 I've read Wizard Al post about VVT cams in one of the threads and can't figure out what is the best cam to run in VVT heads? It sounds like NA cam out of '03 on the intake but I'm not sure what to run on the exhaust. Does anyone know the specs and what cams would be the best choice for intake and exhaust? Link to comment Share on other sites More sharing options...
mune237 Posted June 29, 2010 Report Share Posted June 29, 2010 This is great!!! THX ozzi Link to comment Share on other sites More sharing options...
