RobT5M Posted July 10, 2012 Report Posted July 10, 2012 Will the T4's work? I will have to find the link, otherwise youd have to dig thru the guys website. I messaged him on Ebay and he linked me to his website. Quote
erikv11 Posted July 10, 2012 Report Posted July 10, 2012 I don't think the T4 will work, because the base is too large. It won't fit in the back of the switch. The dimensions of 3, 4 and 5 bases are in the link from IPD Cameron, that is what I am going by here. NEO3 and T3 are the same, 8 mm, etc. I know, the 25 degree seems like a pretty narrow beam. The ones from superbrightleds are supposedly 120 degrees. Will the guy put just one LED in an envelope for like a buck, so you can try it in the switch? Quote
RobT5M Posted July 10, 2012 Report Posted July 10, 2012 Yeah I actually just went ahead and bought some. He sells them 2 at a time. 1.50 + 80 flat shipping no matter how many. So when they come in ill see. He also sells them in SMD that have the 120degree. Guess I could have picked up a set of those as well. Oh well we will see how these come out. I pm'd you the link. but for the hell of it. http://www.wardenjp.com/stores/neowedge.html Quote
RobT5M Posted July 20, 2012 Report Posted July 20, 2012 Those bulbs work great, .75 ea and .80 for shipping. Just ordered 8 more :) Quote
TaskMule Posted July 20, 2012 Report Posted July 20, 2012 I've bought lots of leds from wardenjp.com over the last few years, through his ebay store. Never a problem. Quote
mune237 Posted October 6, 2012 Report Posted October 6, 2012 How do you get to the INFO switch bulb? I didn't want to break the circuit board, but the bulb needs to come out from behind Quote
RobT5M Posted October 6, 2012 Report Posted October 6, 2012 it looked like someone cut a piece of the board on my switch. iirc billy had blue leds in my switches before he sold me the car. Quote
NEU Posted October 7, 2012 Report Posted October 7, 2012 Just cut the white plastic behind that bulb to install the LED. Quote
T5power Posted October 7, 2012 Author Report Posted October 7, 2012 Just cut the white plastic behind that bulb to install the LED. bingo. Quote
mune237 Posted October 7, 2012 Report Posted October 7, 2012 (edited) For those that were successful, how did you cut the white plastic? Going to get a small metal blade for my Dremel UPDATE: I just used a small end mill in my Dremel, I took out just enough to get the bulbs in and out. Edited October 8, 2012 by mune237 Quote
TaskMule Posted October 8, 2012 Report Posted October 8, 2012 I nipped the corner off with micro side cutters. Ugly but works. Quote
hasbeen179 Posted August 4, 2013 Report Posted August 4, 2013 I read through - couldn't find an answer - I've successfully replaced almost all the interior lights with leds. My one issue is the courtesy lights over the rear driver's and passenger side doors. I've used the "right" bulb, rotated them around re: polarity, even grabbed a couple new assemblies on my last trip to the u-pull. Tried different bulbs of the same type, just in case. Nothing, except the stock incandescent, works. Can someone dumb this down for me? Thanks in advance! Quote
MattyXXL Posted August 5, 2013 Report Posted August 5, 2013 Try the ones in serge's kit.. they are bright as whit and work perfectly 3 Quote
revolvolution09 Posted August 5, 2013 Report Posted August 5, 2013 Anybody make LED gear selector bulb 107931 or 115602 for x70? Quote
T5power Posted August 17, 2013 Author Report Posted August 17, 2013 Anybody make LED gear selector bulb 107931 or 115602 for x70? from the look of the connector, it looked like it was a volvo only part. from what i remember of it anyway. so i just rigged it so the pins were connecting to the socket and i never had an issue. just had to keep it in there. easy! Quote
