Keaton85 Posted June 8, 2012 Report Share Posted June 8, 2012 For the rear O2 sensor? Quote Link to comment Share on other sites More sharing options...
Yellow95 Posted June 8, 2012 Report Share Posted June 8, 2012 It's called a Zener diode. but easier to delete in the software And solder it where? Quote Link to comment Share on other sites More sharing options...
TaskMule Posted June 8, 2012 Report Share Posted June 8, 2012 ^ what he said ^ Quote Link to comment Share on other sites More sharing options...
ct98saffv70r Posted June 16, 2012 Report Share Posted June 16, 2012 Can anyone point out where the exact vacuum line that needs to be plugged is with a diagram? Quote Link to comment Share on other sites More sharing options...
ct98saffv70r Posted June 16, 2012 Report Share Posted June 16, 2012 nevermind!! re-read the thread and found the purple line going to the back of the engine. Quote Link to comment Share on other sites More sharing options...
ct98saffv70r Posted June 16, 2012 Report Share Posted June 16, 2012 in case this helps anyone else: I dropped down the splash guard on the driver's side with a 10mm wrench and pried open the air pump with a flat screwdriver.. there are 3 tabs to do this on: I then removed and taped off the power wires that you see here. After that, i put it all back together and then pulled the ECU box apart to get to the harness, and wire tapped the diode into place like so: After putting that back together, i found the purple vacuum line, disconnected it, then put vacuum tube caps over the nipple.. the size i had was a bit too big, so i zip tied it to the solenoid here: in case this helps anyone else: I dropped down the splash guard on the driver's side with a 10mm wrench and pried open the air pump with a flat screwdriver.. there are 3 tabs to do this on: I then removed and taped off the power wires that you see here. After that, i put it all back together and then pulled the ECU box apart to get to the harness, and wire tapped the diode into place like so: After putting that back together, i found the purple vacuum line, disconnected it, then put vacuum tube caps over the nipple.. the size i had was a bit too big, so i zip tied it to the solenoid here: 2 Quote Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted June 16, 2012 Report Share Posted June 16, 2012 FYI, there is a connector just in front of the battery, behind the headlight. It is light gray, fairly large, and is much easier to disconnect than prying the pump apart. Not really sure why you would want to do this either? Unless you are in CA and very concerned about a SMOG check? Also, while modifying the harness is apparently a way to accomplish your goal, I'd argue that its much safer in terms of avoiding catastrophic hard-to-reverse damage to modify the ECU as described in this thread. Quote Link to comment Share on other sites More sharing options...
TaskMule Posted June 23, 2012 Report Share Posted June 23, 2012 Anyone have a nice tidy way to block the hole in the airbox, or am I just throwing my cone/shield in there now? Quote Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted June 23, 2012 Report Share Posted June 23, 2012 You can try to junk-yard an airbox from a model that didn't have SAS. It won't have the elbow. Quote Link to comment Share on other sites More sharing options...
DeleteMyAccount Posted June 23, 2012 Report Share Posted June 23, 2012 FYI, there is a connector just in front of the battery, behind the headlight. It is light gray, fairly large, and is much easier to disconnect than prying the pump apart. Not really sure why you would want to do this either? Unless you are in CA and very concerned about a SMOG check? Are you talking about this wiring harness? Quote Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted June 23, 2012 Report Share Posted June 23, 2012 Yes, the gray connector, and IIRC, it is bolted or snapped on to the frame somehow, so be careful about that. You just unplug it and you can remove the air pump. Quote Link to comment Share on other sites More sharing options...
TaskMule Posted June 24, 2012 Report Share Posted June 24, 2012 You can try to junk-yard an airbox from a model that didn't have SAS. It won't have the elbow. Stealthy! Thanks. Quote Link to comment Share on other sites More sharing options...
DeleteMyAccount Posted June 24, 2012 Report Share Posted June 24, 2012 Yes, the gray connector, and IIRC, it is bolted or snapped on to the frame somehow, so be careful about that. You just unplug it and you can remove the air pump. Yes, it is attached to the frame. I used a screwdriver to push down on the locking tab to disconnect it. Thanks. Quote Link to comment Share on other sites More sharing options...
DeleteMyAccount Posted July 27, 2012 Report Share Posted July 27, 2012 This mod works! No more CEL. Left everything in place, just disconnected the airpump connector. Quote Link to comment Share on other sites More sharing options...
Garth R. Posted August 21, 2012 Report Share Posted August 21, 2012 Anyone have a nice tidy way to block the hole in the airbox, or am I just throwing my cone/shield in there now? Part numer 9180870 - $2.37 1 Quote Link to comment Share on other sites More sharing options...
