g96nt Posted February 4, 2011 Report Share Posted February 4, 2011 so... when you guys had the SAS CEL, did the car still run normally? or... did it cause the ecu to run open-loop? Quote Link to comment Share on other sites More sharing options...
Dick Dastardly Posted February 4, 2011 Report Share Posted February 4, 2011 I get 442 or 445 regularly. I just keep erasing them. I passed emissions because the s70 is on the list of "problematic readiness" cars in Ohio so I had the option to forgo OBDII testing and take a tailpipe and pressure test. I passed fine. Quote Link to comment Share on other sites More sharing options...
crc1021 Posted February 4, 2011 Report Share Posted February 4, 2011 Haha, it's pretty simple man. I know because I have a new air pump and check valve installed, the Genuine parts bill was very salty. Keep updating as you put more miles down, if this is a true way to get rid of the SAS I'm def. going this route. I just don't want to go through the hassle until I've seen a few K miles logged with no issues. I have had my delete on my LPT ECU in for approximately 1000 miles with no CEL. I now have a T5 ECU with no CEL and I am at 600 miles. I have already removed all of the components that I could from the PCV system and have no problems there either. I have the LPT ECU laying around with the delete already done, if you want to borrow it. If you decide you want it done, send me yours and I will do it for you. I just need mine back before I send out the new one to IPD for my upgrade. I am not doing that till the summer though. Have to save $$$. Quote Link to comment Share on other sites More sharing options...
Spanky Posted February 4, 2011 Report Share Posted February 4, 2011 Nice work guys!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Dick Dastardly Posted February 5, 2011 Report Share Posted February 5, 2011 I get 442 or 445 regularly. I just keep erasing them. I passed emissions because the s70 is on the list of "problematic readiness" cars in Ohio so I had the option to forgo OBDII testing and take a tailpipe and pressure test. I passed fine. To anyone considering this (and who doesn't already know)...these codes are evap leaks and not related to the SAS system..that post was in response to an earlier one... 1 Quote Link to comment Share on other sites More sharing options...
Ruhl98t5wag Posted February 5, 2011 Report Share Posted February 5, 2011 Soldered the ECU, easy as described, pulled SAS components, nice big hole in that corner and all the hose clutter gone. Anyone know the bung size for blocking the DP. Thanks-Phil Quote Link to comment Share on other sites More sharing options...
cheapwagon Posted February 6, 2011 Report Share Posted February 6, 2011 Soldered the ECU, easy as described, pulled SAS components, nice big hole in that corner and all the hose clutter gone. Anyone know the bung size for blocking the DP. Thanks-Phil Pretty sure it is 16mm Quote Link to comment Share on other sites More sharing options...
Ipd Posted February 6, 2011 Report Share Posted February 6, 2011 yup, 16 x 1.50 Quote Link to comment Share on other sites More sharing options...
T5power Posted February 8, 2011 Report Share Posted February 8, 2011 just did the delete on my T5A and T5M ECU's. thanks so much for posting this up!! hopefully everything went well. did everything as posted. :) Quote Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 8, 2011 Report Share Posted February 8, 2011 To anyone considering this (and who doesn't already know)...these codes are evap leaks and not related to the SAS system..that post was in response to an earlier one... it is an evap leak code, but it being thrown because of the absence of all the sas hardware. never had a problem before the sas was removed with a p0455. to anyone that is wondering, if you delete it, it will come back in about a week, that should be okay for emissions testing (obd2) Quote Link to comment Share on other sites More sharing options...
Volvo5.0 Posted February 9, 2011 Author Report Share Posted February 9, 2011 it is an evap leak code, but it being thrown because of the absence of all the sas hardware. never had a problem before the sas was removed with a p0455. to anyone that is wondering, if you delete it, it will come back in about a week, that should be okay for emissions testing (obd2) SAS and Evap are two entirely different systems. Removing SAS components won't cause the car to set an Evap code. Quote Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 9, 2011 Report Share Posted February 9, 2011 why would after the sas removal and diode install, the evap code comes on, not just for me but at least 3 other people (that mentioned it)?? just a coincidence? Quote Link to comment Share on other sites More sharing options...
Volvo5.0 Posted February 9, 2011 Author Report Share Posted February 9, 2011 why would after the sas removal and diode install, the evap code comes on, not just for me but at least 3 other people (that mentioned it)?? just a coincidence? Possibly a coincidence. I can tell you that by far Evap codes account for most of the CEL's that I see :lol: Quote Link to comment Share on other sites More sharing options...
Keaton85 Posted February 9, 2011 Report Share Posted February 9, 2011 Idono, I just pulled a gross leak code form my parents XC today. although that was after idling for about 20mintues, with almost no fuel and very cold outside. A good time for an evap code. Also I have evap codes on both my other converts, but It's safe to say that the systems are shot so probably just a coincidence. 1 1 Quote Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted February 9, 2011 Report Share Posted February 9, 2011 I'm just going to toss this one out there... I've had a re-occuring 445 code despite the fact I can't find any line leaks. And all that time, I've had the 410 code as well. Ever since I did the delete, no 445 (yet?) Coincidence? Probably. But sure is interesting how many of us have 410 AND 445. Maybe something involved beyond what we know? Edit: I originally said 455, but I meant 445 Quote Link to comment Share on other sites More sharing options...
