claymore Posted January 16, 2011 Author Report Share Posted January 16, 2011 Any more pictures of how you mounted the supercharger? When I was thinking about how I could do a supercharger I thought putting it where you did, where the PS pump goes, and then instead of the spark plug cover. This is so cool As prommised, I hope you can make out how it's mounted Link to comment Share on other sites More sharing options...
dublin14 Posted January 16, 2011 Report Share Posted January 16, 2011 I had an RX7 Turbo II with top mount intercooler. It had the hood scoop to get all that cold air on it. Not sure if you want to got that route, but you might have too? Link to comment Share on other sites More sharing options...
Migilla Posted January 16, 2011 Report Share Posted January 16, 2011 What about modding the hood like a cowl injection hood? Just enough to give you clearance and fesh air? Link to comment Share on other sites More sharing options...
claymore Posted January 16, 2011 Author Report Share Posted January 16, 2011 What about modding the hood like a cowl injection hood? Just enough to give you clearance and fesh air? Do you have any pictures of what you have in mind? I'm not entirely sure how I'm going to tackle the hood yet. Link to comment Share on other sites More sharing options...
Migilla Posted January 17, 2011 Report Share Posted January 17, 2011 Do you have any pictures of what you have in mind? I'm not entirely sure how I'm going to tackle the hood yet. Cowl hood This one's on a mustang but the same idea. Link to comment Share on other sites More sharing options...
claymore Posted January 17, 2011 Author Report Share Posted January 17, 2011 I'm not sure if I will section this one. Link to comment Share on other sites More sharing options...
Falcone Posted January 17, 2011 Report Share Posted January 17, 2011 please don't. Just cut a hole, and if you need air induction, weld a little scoop on. Or angle the back section up a bit. (I bent the bondo'd part inward a bit, the inverted bit ofmetal on the underside diverts rain/snow to the downpipe) Cowls don't fit 850's imo no matter what you try. Also you can bend the hinges outward (or use washers), and it lifts the hood up 1.5 inches at the windshield. Also, cut the metal under the plastic wiper cover, just above the firewall. Leave the vin though hahah, helps out big time with getting hot out. rear hood tilt And I can see my windshield with my hood closed. My cam cover is cold to the touch and coolant temps never go higher than 18o, with no cooling fan. Link to comment Share on other sites More sharing options...
claymore Posted January 17, 2011 Author Report Share Posted January 17, 2011 I think I agree,I might just have the top mount pocking through the hood by half an inch. Link to comment Share on other sites More sharing options...
Falcone Posted January 17, 2011 Report Share Posted January 17, 2011 how tall does the top mount sit off the engine. I can measure my room. Its got a sh!t load on top, in the last pic, the inverted piece of metal is blocking the rest of the windshield. You can raise the rear of the hood quite a bit on these cars with little modification. Link to comment Share on other sites More sharing options...
claymore Posted January 17, 2011 Author Report Share Posted January 17, 2011 Iv got plenty of room at the back, it's just the front that it just kisses the hood even with the bracing removed. Link to comment Share on other sites More sharing options...
Falcone Posted January 17, 2011 Report Share Posted January 17, 2011 just replicate the top mount with 2x4's, and slam the hood, ala eclipse bubble hahah Have you raised the hood yet? Try the rear,and you can even bring the hinge lockers on the front up a bit. I bet you can fit it in there. Link to comment Share on other sites More sharing options...
claymore Posted January 19, 2011 Author Report Share Posted January 19, 2011 I'v now got all the pipe fittings I need, so did a bit of plumbing today. So, I'v decided what look I'm going for with the Hood I'v cut about an inch off the hight and got rid of the front bit, I may go lower yet. Link to comment Share on other sites More sharing options...
Kevin. Posted January 19, 2011 Report Share Posted January 19, 2011 :tup: keep it up Link to comment Share on other sites More sharing options...
NJGreenBudd Posted January 19, 2011 Report Share Posted January 19, 2011 Yeah refer to the TMIC as an "interheater" in the RX7 community due to the extreme heatsoak they see mounted like this, should be worse on a setup like this with the turbo right under there too. Still interested to see what happens with all this, never seen a setup like this on here before now. Good luck, NJGB Link to comment Share on other sites More sharing options...
Prezman26 Posted January 19, 2011 Report Share Posted January 19, 2011 I like this. Wish they had some kind of intake like this for an NA. Link to comment Share on other sites More sharing options...
