Account_Deleted_T5M Posted January 12, 2011 Report Share Posted January 12, 2011 Just pulled apart the 850 T5 i just purchased, am doing PCV and noticed how much of a pain the EGR is. Can i throw a 96 manifold on there and a 96+ 850 T5 ecu i have laying around and call it a day? Link to comment Share on other sites More sharing options...
Ipd Posted January 12, 2011 Report Share Posted January 12, 2011 Yup, that's what I did! Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted January 12, 2011 Author Report Share Posted January 12, 2011 Yup, that's what I did! Sweet, did not really want to put that god awful EGR back in. Link to comment Share on other sites More sharing options...
Falcone Posted January 13, 2011 Report Share Posted January 13, 2011 I just left it attached to the stock exhaust manifold, installed the intake mani without egr, and plugged my egr back in. Ran perfectly fine (long time ago) when I didn't have a 96+ ecu. Link to comment Share on other sites More sharing options...
bergmjs Posted January 13, 2011 Report Share Posted January 13, 2011 If you don't get the new ECU i hear soldering a 1k ohm resistor in place of the EGR temp sensor will prevent a CEL. Link to comment Share on other sites More sharing options...
johnloves850's Posted January 13, 2011 Report Share Posted January 13, 2011 If you don't get the new ECU i hear soldering a 1k ohm resistor in place of the EGR temp sensor will prevent a CEL. +1. Link to comment Share on other sites More sharing options...
Guest 240gator Posted March 20, 2011 Report Share Posted March 20, 2011 I have 1995 T5 with no need for EGR. I disconnected temperature sensor wires and put 1k ohm resistor between them. I got CEL with P1417 - EGR temperature sensor signal Low. What might I have done wrong? Link to comment Share on other sites More sharing options...
bergmjs Posted March 20, 2011 Report Share Posted March 20, 2011 I have 1995 T5 with no need for EGR. I disconnected temperature sensor wires and put 1k ohm resistor between them. I got CEL with P1417 - EGR temperature sensor signal Low. What might I have done wrong? What wattage resistor did you use? Link to comment Share on other sites More sharing options...
240gator Posted March 20, 2011 Report Share Posted March 20, 2011 What wattage resistor did you use? Just used one I had laying around. Do you think I should replace it with one known to be 1/4 watt? Link to comment Share on other sites More sharing options...
bergmjs Posted March 20, 2011 Report Share Posted March 20, 2011 Just used one I had laying around. Do you think I should replace it with one known to be 1/4 watt? Well, I accidentally bought 1/2 watt ones and put it in anyways and I still have a code. Haven't gotten around to getting a 1/4w one yet, but I'm suspecting that's the reason. The power dissipation must be within the range that the ECU is looking for and I think 1/2w might be too much. Link to comment Share on other sites More sharing options...
Guest Mark Posted October 2, 2011 Report Share Posted October 2, 2011 Well, I accidentally bought 1/2 watt ones and put it in anyways and I still have a code. Haven't gotten around to getting a 1/4w one yet, but I'm suspecting that's the reason. The power dissipation must be within the range that the ECU is looking for and I think 1/2w might be too much. Curious to find out if the 1/4 watt resistor worked? Link to comment Share on other sites More sharing options...
bergmjs Posted October 2, 2011 Report Share Posted October 2, 2011 I just got a tune with EGR deleted before I was able to go get a 1/4w one, sorry. Link to comment Share on other sites More sharing options...
