O_0 Posted February 5, 2011 Report Share Posted February 5, 2011 For a 1997 850 wagon, does anyone know where a good switched 12V wire would be located in the engine compartment near the driver side strut tower area and another one somewhere near the steering column in side car that's easy access? Thanks. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 5, 2011 Report Share Posted February 5, 2011 For a 1997 850 wagon, does anyone know where a good switched 12V wire would be located in the engine compartment near the driver side strut tower area and another one somewhere near the steering column in side car that's easy access? Thanks. Any of the marker lights and the cig lighter Link to comment Share on other sites More sharing options...
O_0 Posted February 5, 2011 Author Report Share Posted February 5, 2011 Thanks, and it's a non energized circuit correct? I know when I lock the doors the turn signals flash. Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 5, 2011 Report Share Posted February 5, 2011 For a 1997 850 wagon, does anyone know where a good switched 12V wire would be located in the engine compartment near the driver side strut tower area and another one somewhere near the steering column in side car that's easy access? Thanks. You've got the fuse box under the hood right there. If you don't have a fully optioned car, there may easily be an open fuse or cuircuit breaker location that will work for you. If that's not an available option, there's a connector for aftermarket accessories located under the dash, just to the left of the steering column. You can pick up switched there and run it through existing grommets to the bay. Here's the info on the Accessory Connector: 96 850 Acc Conn diagram.pdf 96 850 Acc Conn Component Locations.pdf What are you installing? Link to comment Share on other sites More sharing options...
O_0 Posted February 5, 2011 Author Report Share Posted February 5, 2011 Nice, I will probably use the engine bay area since what I am running will be in that area. I like to keep my grounds short as possible. Link to comment Share on other sites More sharing options...
maksevrod Posted March 11, 2011 Report Share Posted March 11, 2011 I can't read PDF-file. What can i do? ----------- business china Link to comment Share on other sites More sharing options...
BEJinFBK Posted March 12, 2011 Report Share Posted March 12, 2011 I can't read PDF-file. What can i do? ----------- business china Download Acrobat Reader? I'm not sure what you mean... Link to comment Share on other sites More sharing options...
