JVC Posted May 5, 2011 Report Share Posted May 5, 2011 Figured I'd throw it up here since I have officially no idea. It seemed to start randomly... I don't recall when I first heard it but when I did I know that I had never heard it before. It almost seems like a very quiet supercharger with a slightly deeper tone. It only seems to happen in lower rpm's but that could also be because I cannot hear it when I get into higher RPM's. It definitely is dependent on load and rpm though since with a bit higher rpm it changes tone and when sitting still or revving not under load it does not make the sound at all. I recently replaced the drivers side axle and it appears fine. I know the passenger side outer cv boot is torn and will be getting replaced soon along with the passenger side wheel bearing that is making a bit of grinding sound (not the sound I'm worried about though). I FAINTLY remember reading someone mention that it could be the inner cv boot on the passenger axle, which could be it but I was just wondering if you have any ideas about this one. -John Heres a link to a video that you can kinda hear the sound in. http://s17.photobucket.com/albums/b72/north_shore_racer/?action=view¤t=VID_20110427_213136.mp4 Link to comment Share on other sites More sharing options...
Dick Dastardly Posted May 5, 2011 Report Share Posted May 5, 2011 umm..i forget is your car manual? Link to comment Share on other sites More sharing options...
Vagabond Posted May 5, 2011 Report Share Posted May 5, 2011 I have had tight engine belts do that in other rides. Stresses the pulley bearings. Link to comment Share on other sites More sharing options...
JVC Posted May 5, 2011 Author Report Share Posted May 5, 2011 umm..i forget is your car manual? No sir... I'll check belt tension... i'm guessing most the time its the auxiliary belt? I'll see if it seems tight and maybe loosen the tensioner and then let it go back to tight and see if that does anything or see if i can visibly see anything out of place... Link to comment Share on other sites More sharing options...
Jesus Posted May 5, 2011 Report Share Posted May 5, 2011 Is the whining coming from between the seat and the steering wheel? Link to comment Share on other sites More sharing options...
JVC Posted May 5, 2011 Author Report Share Posted May 5, 2011 Is the whining coming from between the seat and the steering wheel? I hate you... haha. No it is not. Link to comment Share on other sites More sharing options...
greekone Posted May 5, 2011 Report Share Posted May 5, 2011 My silver T5M does this too, I haven't had the chance to look into it. Link to comment Share on other sites More sharing options...
JVC Posted May 5, 2011 Author Report Share Posted May 5, 2011 http://s17.photobucket.com/albums/b72/north_shore_racer/?action=view¤t=VID_20110504_233952.mp4 theres another video... It sounds like its coming from the accessory belt area... I checked my power steering fluid and it was just about the C mark when hot... I think that MAY be the culprit and I'm gonna go any buy some more power steering fluid tomorrow and top it off. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted May 5, 2011 Report Share Posted May 5, 2011 could be the idler pulley bearing or the tensioner for the accessory belt...remove belt and start car. if noise is gone... Link to comment Share on other sites More sharing options...
Mesoam Posted May 5, 2011 Report Share Posted May 5, 2011 couldn't really jack the volume up at work but that sure sounded like a PS pump on its way out Link to comment Share on other sites More sharing options...
JVC Posted May 6, 2011 Author Report Share Posted May 6, 2011 adding fluid didn't stop the problem... it definitely seems to be coming from right below the power steering resivoir... somewhere right down there. Any ideas on easy ways to check if its the PS pump, alternator, etc? Link to comment Share on other sites More sharing options...
BoostedSwede Posted May 6, 2011 Report Share Posted May 6, 2011 The clutch on my A/C compressor is gone, so it makes a soft gravelly-scraping noise all the time, but also makes a whining noise like that in the same situations you describe. Mine sounded like the alternator, the p/s pump, adn the idler/tensioner pulleys. Except those are all brand new...so it's just the A/C compressor. Also keep in mind that when under load, the timing belt setups in these cars do make a faint whining noise, even with all new parts. Could be that too. Link to comment Share on other sites More sharing options...
WayAway Posted May 6, 2011 Report Share Posted May 6, 2011 P/S pump id say. Same exact noise I had on my Saffron. Link to comment Share on other sites More sharing options...
AlecW81 Posted May 7, 2011 Report Share Posted May 7, 2011 I hope you didn't use PS Fluid... should be ATF. Link to comment Share on other sites More sharing options...
JVC Posted May 7, 2011 Author Report Share Posted May 7, 2011 The clutch on my A/C compressor is gone, so it makes a soft gravelly-scraping noise all the time, but also makes a whining noise like that in the same situations you describe. Mine sounded like the alternator, the p/s pump, adn the idler/tensioner pulleys. Except those are all brand new...so it's just the A/C compressor. Also keep in mind that when under load, the timing belt setups in these cars do make a faint whining noise, even with all new parts. Could be that too. It COULD be the AC compressor but I currently don't have a condenser in there and never actually use the AC since I know it wont get me anything with the system wide open. P/S pump id say. Same exact noise I had on my Saffron. how hard of a fix was that? big pain in the ass or what? I hope you didn't use PS Fluid... should be ATF. I didn't top it up at all actually... seemed low but then once it got actually warm it read on point, so i didn't throw anymore in there. It doesn't seem to make any more noise when turning or anything but it sure is loud now. haha I think i'm in the market for a power steering pump... off to VADIS to see how big of a pain in the ass this is gonna be. Link to comment Share on other sites More sharing options...
