Zappo Posted July 5, 2011 Report Share Posted July 5, 2011 I ended up breaking mine on removal also. Link to comment Share on other sites More sharing options...
B Mac Posted July 5, 2011 Report Share Posted July 5, 2011 I ended up breaking mine on removal also. I vaporized mine with Jim's laser gun. Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted July 5, 2011 Report Share Posted July 5, 2011 Maybe this is a dumb question, but how the hell do you remove the old cable??? I tried pulling, prying, comparing it to the new cable, but all I got was the electrical plug section separating from the black plastic clip-looking piece that's still attached to the firewall!!! From the inside, all I see is the black/gray insulation. Any nifty tricks to getting this old cable to release from the firewall??? Push with a small screwdriver the four plastic clips, they are behind the rubber grommet by the firewall if you want to save the cable!! You never know......... Link to comment Share on other sites More sharing options...
sconeman Posted July 5, 2011 Report Share Posted July 5, 2011 Push with a small screwdriver the four plastic clips, they are behind the rubber grommet by the firewall if you want to save the cable!! You never know......... exactly.. I actually left the white clip behind but I could pull it right out with my fingers. It's literally a 10-15 min job and FCP has the OEM verision in stock. Change in pedal feel is unbelievable. (just did this) thanks for the prompting! Link to comment Share on other sites More sharing options...
Fake-R Posted July 5, 2011 Author Report Share Posted July 5, 2011 exactly.. I actually left the white clip behind but I could pull it right out with my fingers. It's literally a 10-15 min job and FCP has the OEM verision in stock. Change in pedal feel is unbelievable. (just did this) thanks for the prompting! No problem! Happy to help. :tup: Link to comment Share on other sites More sharing options...
NChoy Posted July 6, 2011 Report Share Posted July 6, 2011 Push with a small screwdriver the four plastic clips, they are behind the rubber grommet by the firewall if you want to save the cable!! You never know......... LOL... tried that. Got frustrated, pulled hard and CRACK! The entire thing split in half. Then I had to use the screwdriver to dig out the part that was still clipped to the firewall. Ended up in two pieces, and went right in the trash. New cable installed so easily. Too bad I'm doing other stuff to the car, otherwise I'd take her out for a spin! Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted July 8, 2011 Report Share Posted July 8, 2011 LOL... tried that. Got frustrated, pulled hard and CRACK! The entire thing split in half. Then I had to use the screwdriver to dig out the part that was still clipped to the firewall. Ended up in two pieces, and went right in the trash. New cable installed so easily. Too bad I'm doing other stuff to the car, otherwise I'd take her out for a spin! If is been a long time you don't drive the car you may not get the real difference!!! Drive somebody else car stock and then jump in yours............is gonna be a long yaaaaaaaaaaaaaaaahhhhhhhhhooooooooo Link to comment Share on other sites More sharing options...
atefitty Posted March 11, 2012 Report Share Posted March 11, 2012 I came across this today also...The auto cable has an electical connection as you can see in the pic Here is a pic of the manual cable,,No electrical connertor here. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted March 11, 2012 Report Share Posted March 11, 2012 Yeah thats for the kickdown on the auto. You leave it unplugged on the manual with no ill effects. Link to comment Share on other sites More sharing options...
atefitty Posted March 11, 2012 Report Share Posted March 11, 2012 I have some manual swap questions if anyone know the answers please reply.. 1. Should the plastic piece on the back of the shift fork be replaced with a new one? It sits on a ball there on the tranny and allows the fork to pivot back and forth. 2. What do I lube the shaft that the throw out bearing sits on? 3. Is this swap really woth all the work? Link to comment Share on other sites More sharing options...
lookforjoe Posted March 12, 2012 Report Share Posted March 12, 2012 If that ball cap is worn, then yes, you should replace it. The shaft is not lubricated. Read this.... Link to comment Share on other sites More sharing options...
atefitty Posted March 12, 2012 Report Share Posted March 12, 2012 Yeah thats for the kickdown on the auto. You leave it unplugged on the manual with no ill effects. Thanks for the input If that ball cap is worn, then yes, you should replace it. The shaft is not lubricated. Read this.... Wow, nice bit of info there, thanks for the reply. Yeah thats for the kickdown on the auto. You leave it unplugged on the manual with no ill effects. Not sure what that would mean unless your talking about the cruise control, as it being a kickdown for the cruise control. Link to comment Share on other sites More sharing options...
matt b Posted March 12, 2012 Report Share Posted March 12, 2012 I think you're over-thinking a fairly simple change on your car. As Paul said, the kick down switch won't affect anything by being unplugged, mine has been that way for well over a year. You will lose your cruise control, but I added information in the manual swap thread on which relay to change to get it back. I've had mine working for 2+ years, it's a quick fix. Link to comment Share on other sites More sharing options...
bergmjs Posted March 12, 2012 Report Share Posted March 12, 2012 I think you're over-thinking a fairly simple change on your car. As Paul said, the kick down switch won't affect anything by being unplugged, mine has been that way for well over a year. You will lose your cruise control, but I added information in the manual swap thread on which relay to change to get it back. I've had mine working for 2+ years, it's a quick fix. Link please? Link to comment Share on other sites More sharing options...
matt b Posted March 13, 2012 Report Share Posted March 13, 2012 Pinned at the very top of the Performance section. Here is the link to the actual thread. Link to comment Share on other sites More sharing options...
