Jardim Posted March 18, 2012 Report Share Posted March 18, 2012 Its funny how your building a BMW with a Volvo powertrain and maciek is doing the exact same thing in a different order lol. Link to comment Share on other sites More sharing options...
maciekb2002 Posted March 31, 2012 Author Report Share Posted March 31, 2012 I got T6 engine yesterday finally at the correct shop. New In the mid time I will begin fitting turbos on it. Diff is still not done I had very busy 2 weekends in the row :( Link to comment Share on other sites More sharing options...
adamdrives Posted April 1, 2012 Report Share Posted April 1, 2012 Keep it goin man! Awesome stuff! Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 4, 2012 Author Report Share Posted April 4, 2012 This is one of the ideas for intakes 4'' in to 2x2.25'' . I will have to cut off front turbo inlets . 2 vband clamps on each end and perfect fit . that should give me no vacuum leaks , But to finish that part I have to have turbos mounted So I slowly started fitting mercedes manifold in to volvo flange . I need one more volvo flange give it a nice cut and we have 2x3 cyl manifolds. Today I did some research about how to tig weld iron castings . It went super smooth. I machined plug ,then it was installed in to the hole where factory flex pipe was connected . Quick tig weld and this is what I got . Weld was a little to hot but I am happy with results I will connect volvo with merc flanges using 1.5'' long pipes weld it all together Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 5, 2012 Author Report Share Posted April 5, 2012 So It looks like I will use this belt. It is a 850 AC eliminating set up. I am not sure if Alternator can spin other way . If someone tried that before let me know please if it works And this is front turbo placed like it is going to sit in the car . Manifold will have flex connection between Link to comment Share on other sites More sharing options...
lookforjoe Posted April 5, 2012 Report Share Posted April 5, 2012 Nice! Alternator can run backwards just fine. That belt routing is not good though - you need to get a much longer belt with an idler where the AC was, & route belt around the alt pulley.... Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 5, 2012 Author Report Share Posted April 5, 2012 Nice! Alternator can run backwards just fine. That belt routing is not good though - you need to get a much longer belt with an idler where the AC was, & route belt around the alt pulley.... I don't think that will be an issue . RX7 have problems with water pumps and there fix is an aftermarket bigger pulley . My bend is about double what they run. Also I have bracket and pulley that eliminates ac compressor from european market . If I have to I use that Link to comment Share on other sites More sharing options...
Gideon35T Posted April 5, 2012 Report Share Posted April 5, 2012 Why not angle the turbos? Most inline twin turbo setups I've seen will run the turbos at an angle so that routing the lines, exhaust, and induction piping (in and out) is easier and there's room to play with. As it sits right now I don't really see it working unless the exhaust ports out of the turbos at opposite ends of the motor. If I'm just not seeing what you're planning please let me know. Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 6, 2012 Author Report Share Posted April 6, 2012 this is a high resolution image what I am trying to fabricate Link to comment Share on other sites More sharing options...
Tommy. Posted April 6, 2012 Report Share Posted April 6, 2012 LOL high resolution Love the project though! Keep up the amazing work! :tup: Link to comment Share on other sites More sharing options...
Vagabond Posted April 6, 2012 Report Share Posted April 6, 2012 This thread does not suck! Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 7, 2012 Author Report Share Posted April 7, 2012 I took off timing cover today , Just to discover this. I think in this condition It will make maybe 2 revolutions and fall apart. Yes this is why you should change your T-belt and tensioner around 80k Link to comment Share on other sites More sharing options...
project_850 Posted April 7, 2012 Report Share Posted April 7, 2012 HAHA! Love that high res pic ;) Link to comment Share on other sites More sharing options...
andyb5 Posted April 7, 2012 Report Share Posted April 7, 2012 This is an awesome project, can't wait to see how this plays out! Link to comment Share on other sites More sharing options...
maciekb2002 Posted April 11, 2012 Author Report Share Posted April 11, 2012 This how its going to be install . Two little twins. I also found bracket for the AC eliminator kit It fits Link to comment Share on other sites More sharing options...
