NZRED850R Posted September 11, 2011 Report Share Posted September 11, 2011 Hi I just had a go at getting my 142 going and seems the timing is out ??? It is a b18 block with a b20 injected head on it, It runs but back fires through the carbs the green book say to put the distributor in the hole and turn the shaft a little and will slip in then start the car and if it doesn't turn the distributor untill it does the put on the timing light and set ??? Is there some where i can get static timing info and distributor placement thanks Bruce Link to comment Share on other sites More sharing options...
gdizzle Posted September 12, 2011 Report Share Posted September 12, 2011 Best bet is to ask on turbobricks.com or brickboard.com Link to comment Share on other sites More sharing options...
550 Posted September 14, 2011 Report Share Posted September 14, 2011 Have you hit it with a timing light as it is? You should get a decent one with a dial indicator so you can tell where the timing is. Not sure if your 142 is that same as the 242 or not, but you have to pull the vac line off the vac advance pod on the distributor. And then you can check the base timing. It should be in the green books, I think. Link to comment Share on other sites More sharing options...
DVolvoguy850T5 Posted November 20, 2011 Report Share Posted November 20, 2011 You need to ensure the off set key is lined up correctly with the oil pump drive shaft. This alignment is imperative to setting up the timing correctly. The old Climer manual is the best book to use to get this accomplished. Also insure the timing marks on the crank and camshaft are aligned up and all should be ok. Link to comment Share on other sites More sharing options...
brick-a-brac Posted December 27, 2011 Report Share Posted December 27, 2011 It doesn't hurt to make certain the distributor isn't off 180 degrees, as it will also drop in at that point as well. Check to see if the rotor is pointing to number one when you're at TDC. Once that's established, timing should be set around 10 to 15 degrees before TDC, if I remember correctly. Link to comment Share on other sites More sharing options...
ThePOWERtoRULE Posted December 29, 2011 Report Share Posted December 29, 2011 I think you're barking up the wrong tree, honestly. If it runs, when does it backfire through carb? Under load? What kind of carb do you have? Check for vacuum leaks as well. If it runs then you should be close enough to time it with a timing light. If not, then we're looking at another issue. Link to comment Share on other sites More sharing options...
