corivus Posted September 19, 2011 Report Share Posted September 19, 2011 So in the process of putting in the new engine we discovered that the seals on the transmission need to be replaced, we pulled them and showing that they are Manufactured by NOK? the part number on the seal is bh4575e trying to order the part for the Output seal for the transmission and not seeing anything. Any help is appreciated, otherwise I'll try calling fcp or ipd on Monday. in case the info on my sig isn't cleared 1994 Volvo 850 Turbo Automatic transmissionI'm thinking its this one? http://www.fcpgroton.com/product-exec/product_id/16195/nm/1994-1997+Volvo+850+Turbo+Drive+Axle+Seal-Automatic+Transmission Link to comment Share on other sites More sharing options...
heat391 Posted September 19, 2011 Report Share Posted September 19, 2011 This is the seal that goes where the axle shaft enters the transmission. You'll need one for each side, so order 2. If the transmission is not installed yet, you might want to replace the input shaft seal http://www.fcpgroton...category_id/104 This seal goes behind the torque converter Link to comment Share on other sites More sharing options...
bergmjs Posted September 19, 2011 Report Share Posted September 19, 2011 As said, replace the input shaft seal! Its really easy if the trans is already out, but makes for a major headache if it starts leaking badly up on the highway. My girlfriend's input shaft seal took a dump halfway to Acadia and we had to turn around and try to make it home refilling the transmission every 30 miles. Most of the ride was a huge smoke show since it got on the pass axle which slung it up onto the exhaust. Almost made it home, then got towed. But yea, moral of the story, replace it before it quits on you. Link to comment Share on other sites More sharing options...
corivus Posted September 19, 2011 Author Report Share Posted September 19, 2011 already have the input seal(x2), just wanted to make sure the output seal(x2) was the correct onethanks for the info guys :) Link to comment Share on other sites More sharing options...
erikv11 Posted September 19, 2011 Report Share Posted September 19, 2011 already have the input seal(x2) ... There's only one input shaft seal. Link to comment Share on other sites More sharing options...
corivus Posted September 19, 2011 Author Report Share Posted September 19, 2011 Yup, already got corrected on that by the person who is doing the seals on the transmission right now. Link to comment Share on other sites More sharing options...
