'93 Dave Posted October 20, 2011 Report Share Posted October 20, 2011 only on cold starts does this occur. should i be looking at lines or a new pump? or both ? fluids are good so its not empty making that loud sound from the reservoir. 99 s70 glt, 190k http://s88.photobuck...nt=MVI_0754.mp4 Link to comment Share on other sites More sharing options...
FCP Euro Posted October 21, 2011 Report Share Posted October 21, 2011 Could be a couple of things, like a failing pump, or fluid that is to think. Did you just change the fluid? Id so, what kind did you use? Link to comment Share on other sites More sharing options...
'93 Dave Posted October 21, 2011 Author Report Share Posted October 21, 2011 duno anything about the fluids in it. the rack was replaced about 70k miles ago so thats the last time i guess it would have been changed. tom told me to get this for the replacement fluids http://www.amazon.com/Pentosin-CHF-11S-Hydraulic-Liter/dp/B0006Q16YM?tag=vglnk-c789-20 Link to comment Share on other sites More sharing options...
'93 Dave Posted October 31, 2011 Author Report Share Posted October 31, 2011 now this started happening . happens more when i hit full lock turning the wheel counterclockwise also fluid is starting to seep out. its not overfilled just under TONS of pressure it seems Link to comment Share on other sites More sharing options...
'93 Dave Posted November 1, 2011 Author Report Share Posted November 1, 2011 found out the rubbing noise. i just need to lube up the rubber area where the steering column goes thru the firewall. as far as the howling from cold start ups and the excess fluids all over it? do the seals on the p/s pump reservior just go bad? i feel tho like its building excess pressure. i just duuno where to start that diagnostic? Link to comment Share on other sites More sharing options...
