Guest Guest_highhighs_* Posted January 13, 2005 Report Share Posted January 13, 2005 when i connect the amp in 3 channel configuration the fron speakers(connected directly to HU) do not emit sound(not low, no signal at all) the rear speakers work ok. if i dissconnect the rear speakers from the amp the sound commes again. can anybody explain this. the HU has 1 preamp output (2 channels) but im using a Y addapter to connect it to the amp. Link to comment Share on other sites More sharing options...
Ivanfbi Posted January 13, 2005 Report Share Posted January 13, 2005 Maybe a C4 will help. Link to comment Share on other sites More sharing options...
Guest Guest_highhighs_* Posted January 13, 2005 Report Share Posted January 13, 2005 Maybe a C4 will help.←??? Link to comment Share on other sites More sharing options...
bogelo Posted January 13, 2005 Report Share Posted January 13, 2005 when i connect the amp in 3 channel configuration the fron speakers(connected directly to HU) do not emit sound(not low, no signal at all) the rear speakers work ok. if i dissconnect the rear speakers from the amp the sound commes again. can anybody explain this. the HU has 1 preamp output (2 channels) but im using a Y addapter to connect it to the amp.←Actually, I don't know what are you talking about. Do you have any Diagram what are you trying to do? Link to comment Share on other sites More sharing options...
highhighs Posted January 13, 2005 Report Share Posted January 13, 2005 in my avatar you can see the schematic. i connected teh sub into bridges mode like it appears on the bottom of the image and the rear speakers in stero mode, but when i do this the front speakers dont work anymore if iu remove the rear speakers the front work again. and i said that my HeadUnit has only 2 RCA channels out(left,right) but im using a Y RCA adaptor to connect them into the 4Channel input of the amp. the amp can be selected to have 2 or 4 channel inputs . Link to comment Share on other sites More sharing options...
bogelo Posted January 13, 2005 Report Share Posted January 13, 2005 in my avatar you can see the schematic. i connected teh sub into bridges mode like it appears on the bottom of the image and the rear speakers in stero mode, but when i do this the front speakers dont work anymore if iu remove the rear speakers the front work again. and i said that my HeadUnit has only 2 RCA channels out(left,right) but im using a Y RCA adaptor to connect them into the 4Channel input of the amp. the amp can be selected to have 2 or 4 channel inputs .←Can't see your pics, its just too small. Link to comment Share on other sites More sharing options...
highhighs Posted January 13, 2005 Report Share Posted January 13, 2005 click on it it will open in a new window. or can anybody give me some free place where i can upload pics? thank you Link to comment Share on other sites More sharing options...
theunderlord Posted January 13, 2005 Report Share Posted January 13, 2005 click on it it will open in a new window. or can anybody give me some free place where i can upload pics? thank you←photodump read the FAQ that's pinned in the show room forum. Link to comment Share on other sites More sharing options...
highhighs Posted January 13, 2005 Report Share Posted January 13, 2005 http://img.photobucket.com/albums/v249/highhighs/amppic.jpg Link to comment Share on other sites More sharing options...
highhighs Posted January 13, 2005 Report Share Posted January 13, 2005 i connected teh sub into bridges mode like it appears on the bottom of the image and the rear speakers in stero mode, but when i do this the front speakers dont work anymore if iu remove the rear speakers the front work again. and i said that my HeadUnit has only 2 RCA channels out(left,right) but im using a Y RCA adaptor to connect them into the 4Channel input of the amp. the amp can be selected to have 2 or 4 channel inputs .sorry for the fuss and thank you Link to comment Share on other sites More sharing options...
bogelo Posted January 13, 2005 Report Share Posted January 13, 2005 i connected teh sub into bridges mode like it appears on the bottom of the image and the rear speakers in stero mode, but when i do this the front speakers dont work anymore if iu remove the rear speakers the front work again. and i said that my HeadUnit has only 2 RCA channels out(left,right) but im using a Y RCA adaptor to connect them into the 4Channel input of the amp. the amp can be selected to have 2 or 4 channel inputs .sorry for the fuss and thank you←You need at least a 5-ch amp to power up front, rear and sub speakers. Coupling the RCA output is no problem BUT You CAN'T use RCA (low-level) output and speaker (high-level) output from your Headunit at the same time. There is a way for your setup but I dont guarantee it'll be good.You need to connect the left side (front & rear) together, as well as the right side (front & rear). In case of tweeter, you can connect it altogether but you need to remember they are separated by left or right side, not front or rear. Link to comment Share on other sites More sharing options...
theunderlord Posted January 13, 2005 Report Share Posted January 13, 2005 MSPAINT PWNS Nice graphic.. :D Link to comment Share on other sites More sharing options...
Guest bing_0 at work Posted January 13, 2005 Report Share Posted January 13, 2005 just follow bogelo's diagram and you will be fine, assuming of course this is a four channel amp, turn the amp to 2 chn input, and away you go, make sure you follow that diagram (precisionly drawn as it is ) exactly...b Link to comment Share on other sites More sharing options...
highhighs Posted January 13, 2005 Report Share Posted January 13, 2005 so its is mandatory to connect both front and rear speakers to the amp. i cannot run the fron speakers from teh head unit. but i should note that the subwoofer runs with the speakers when they are all connected to the HU.anyways Thank you all, i'll see to it tomorow and nice drawing by the way :) Link to comment Share on other sites More sharing options...
BenW Posted January 13, 2005 Report Share Posted January 13, 2005 hey Bogelo,Ever considered an art degree :D Link to comment Share on other sites More sharing options...
