'93 Dave Posted January 15, 2012 Report Share Posted January 15, 2012 i wonder if theres enough clearence to put a small solar panel or somesort under the sunroof not blocking the entire section just a small portion. have it so the sunroon can fully fuction normally. id wire the panel down the pillar into the engine bay to a trickler charger system into the battery. the solar panel im looking at doesnt need to be powerfull at all . just something to know there will always be a good start on a cold morning. the panel would be somehow attached to the plexiglass (or whatever material the sunroof is) problem number one is snow. then light doesnt get to it. i was then thinking of adding a defroster grid to the sunroof somehow if thats possibe (wouldnt that be a first) this is what i had first looked at as far as panels goes http://www.radioshac...oductId=4218512 if its took bulky then well. he he he please give me your thoughts opions everythings welcomed ! edit: and yes i said sunroof. dangit >< Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted January 15, 2012 Report Share Posted January 15, 2012 I remember the A8 Audi have as optional a fancy system, but with the cooling purpose during summer(was running a small fan to cool the car inside). search a bit around for more efficient panels R-shack are crappy. Link to comment Share on other sites More sharing options...
BurgerBob Posted January 16, 2012 Report Share Posted January 16, 2012 Faulty should be able to write a book about this. Link to comment Share on other sites More sharing options...
Vagabond Posted January 16, 2012 Report Share Posted January 16, 2012 Mount it to the sunshade track. Then it would be conviently out of the way. Link to comment Share on other sites More sharing options...
survolvo Posted January 16, 2012 Report Share Posted January 16, 2012 I think a flexable panel would fit better,They are not as bulky. I have one that I use, I just roll it out in the back window though. Like this Link to comment Share on other sites More sharing options...
Stormtrooper1 Posted January 16, 2012 Report Share Posted January 16, 2012 I remember the A8 Audi have as optional a fancy system, but with the cooling purpose during summer(was running a small fan to cool the car inside). search a bit around for more efficient panels R-shack are crappy. the 2010 prius has this option as well for cooling. it uses the solar energy to run the fans while the car is parked to cool the cabin, avoiding the oven car effect. Link to comment Share on other sites More sharing options...
azatoglu Posted January 16, 2012 Report Share Posted January 16, 2012 I was on the same topic last month and I just purchased a 5w solar panel thinking to mount under sunroof but first it has an aliminium casing that limits the clerance in the sunroof area, second a 5w solar panel can charge a 74amp battery in 18 days(thinking that you have 10 hours sun straight) or 0.4amps a day.So I turned to a more powerful solar panel.I will be buying a 20w panel and charge the battery while I am in a picnic or at seaside but the panel itself will be a big one and it will be hard to carry in the trunk. Link to comment Share on other sites More sharing options...
bunce1260 Posted January 20, 2012 Report Share Posted January 20, 2012 I need this too. I love in the city and only drivw on weekends. Does anyone have a tried and tested setup they can share? Link to comment Share on other sites More sharing options...
'93 Dave Posted January 21, 2012 Author Report Share Posted January 21, 2012 I was on the same topic last month and I just purchased a 5w solar panel thinking to mount under sunroof but first it has an aliminium casing that limits the clerance in the sunroof area, second a 5w solar panel can charge a 74amp battery in 18 days(thinking that you have 10 hours sun straight) or 0.4amps a day.So I turned to a more powerful solar panel.I will be buying a 20w panel and charge the battery while I am in a picnic or at seaside but the panel itself will be a big one and it will be hard to carry in the trunk. i wouldnt want it to charge a dead battery, just one that would keep my battery fresh at ~12.5v. its my dd so it never sits longer than a day or two. I think a flexable panel would fit better,They are not as bulky. I have one that I use, I just roll it out in the back window though. Like this good idea, thanks! i just need a winter (wait is it actually winter outside its way to warm) project to keep me busy and id like to install something more permanent. Link to comment Share on other sites More sharing options...
burnout8488 Posted January 22, 2012 Report Share Posted January 22, 2012 Wouldn't a high quality, fresh new battery solve this problem? Link to comment Share on other sites More sharing options...
'93 Dave Posted January 22, 2012 Author Report Share Posted January 22, 2012 Wouldn't a high quality, fresh new battery solve this problem? i have a high quality spankin fresh battery. i like projects to work on Link to comment Share on other sites More sharing options...
TRACStar Posted January 22, 2012 Report Share Posted January 22, 2012 i have a high quality spankin fresh battery. i like projects to work on Plus being able to tell people you have a solar trickle charger in your car is baller :lol: Link to comment Share on other sites More sharing options...
'93 Dave Posted January 24, 2012 Author Report Share Posted January 24, 2012 Plus being able to tell people you have a solar trickle charger in your car is baller instead of turbo charged id get a sticker that says trickle charged i could say my car has a twin charger setup ------ on a serious note the 12watt series comes with two panels. id put one on front window and one on back? why you say? why not? give me greater surface area and being on two sides of the car would give me better coverage from apt., home , comercial buildings shadows. i dont want to have a solar panel dictate how i park!! granted if its considered overkill then consider it overkill. if its worth doing its worth over doing for the trickle system or whatever ill just take apart my black n decker light that has its own 12v trickle system. ill see what voltage it settles at. i have a spare battery in my room that i can test it on and see if it works. if it works ill install and best of all do a write up Link to comment Share on other sites More sharing options...
bunce1260 Posted January 25, 2012 Report Share Posted January 25, 2012 Looking forward to it. Have you seen the kits on amazon? Link to comment Share on other sites More sharing options...
boosted_brick Posted January 25, 2012 Report Share Posted January 25, 2012 buy a real solar panel and swap it in for your moon roof Link to comment Share on other sites More sharing options...
