BlackBrick Posted January 24, 2012 Report Share Posted January 24, 2012 isn't revving an engine with low oil similar to revving an engine that's cold? white smoke? That's water. I get that a lot in the winter...condensation in the exhaust. Link to comment Share on other sites More sharing options...
Keaton85 Posted January 24, 2012 Report Share Posted January 24, 2012 isn't revving an engine with low oil similar to revving an engine that's cold? Oil pressure is oil pressure... When cold you are worried about flow and rapid expansion of metal. When low on oil you are more worried about the pick-up tube not getting any oil in turn dropping your oil pressure to the main and rod bearings. In this case, he did not have an oil light meaning there was just enough oil for the pick-up to have oil... Link to comment Share on other sites More sharing options...
bum2kev Posted January 25, 2012 Report Share Posted January 25, 2012 Oooo, ok. So that would cause both the smoke and peanut butter? yes, fix that ASAP. may take a few days for the problem to clear up completely Link to comment Share on other sites More sharing options...
AlvinL Posted January 25, 2012 Report Share Posted January 25, 2012 Replace the o-ring on the dipstick. A tight seal is needed so cold moist air isn't sucked in making 'peanut better'. Link to comment Share on other sites More sharing options...
