SnapCracklePop Posted February 23, 2012 Report Share Posted February 23, 2012 I CAN NOT get the last screw which so happens to be the screw to hold the heater hoses back in my new heater core! I've been at it for a few hours now and it's only this one screw. Why isn't it going back in? It's almost as if the screw isn't long enough. I know it's the right screw because it screws in the threads with the hoses pulled out. I'm getting extremely frustrated, especially since it seems no body else on the planet has had this problem. Link to comment Share on other sites More sharing options...
SlapShot Posted February 23, 2012 Report Share Posted February 23, 2012 You are putting the torx screw in the hole between where the two lines go in (facing firewall) right? IIRC there is a hole on the opposite side (facing drivers seat) which it should not go in. If you can contort yourself to take a peek, make sure its not cocked and the holes are lined up. Link to comment Share on other sites More sharing options...
SnapCracklePop Posted February 23, 2012 Author Report Share Posted February 23, 2012 yes i'm putting it in between where the two lines go in. I've tried turning the lines this way and that way. and it will not grab the threads and go in there. I even tried putting the old O rings on thinking the new ones were too thick. Still nothing. Link to comment Share on other sites More sharing options...
SnapCracklePop Posted February 23, 2012 Author Report Share Posted February 23, 2012 seriously starting to panic. I just can't figure this out. I've checked and double checked and triple checked that everything is lined up and it's just not going together. no matter how hard I push or pull those hoses in and try and screw in at the same time. Link to comment Share on other sites More sharing options...
831t5r Posted February 23, 2012 Report Share Posted February 23, 2012 Do you have the o-rings lubricated and are they seating into the heater core? Link to comment Share on other sites More sharing options...
SnapCracklePop Posted February 23, 2012 Author Report Share Posted February 23, 2012 mother f%&%^.....the screw I needed had fell back towards the gear shifter behind the panels where I couldnt see it....got it in. Link to comment Share on other sites More sharing options...
