rmorse Posted March 8, 2012 Report Share Posted March 8, 2012 So, I had a transmission leak, coming from passenger side of the transmission, right where the axle slides in. No biggie, figured it was the seal. However, I changed out the seal this weekend and it's still leaking. Ideas? Maybe I didn't push the seal in far enough? I pushed it to where the old one was....flush with the tranny. I was also very careful not to score the tranny when I was taking the seal out. Any ideas? Not terribly concerned about it, since I plan on doing a manual swap this summer/next summer. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted March 8, 2012 Report Share Posted March 8, 2012 OE seal? Did seal possibly get tweaked a little when you pushed it in? Maybe in a little crooked.. Link to comment Share on other sites More sharing options...
rmorse Posted March 8, 2012 Author Report Share Posted March 8, 2012 Yes OE seal, and yes, it did get tweaked....I pushed it in a side at a time. I guess I shouldn't have done that.... Can I redo it, using the same seal? Link to comment Share on other sites More sharing options...
aggarcia Posted March 8, 2012 Report Share Posted March 8, 2012 It the leak where the seal meets the axle shaft or the seal sits in the transmission casing? I replaced a seal and it leaked because I pushed the seal too part in. You could take the seal out, inspect for damage. If it is ok, then re-install in another slightly different location. You need to install the seal evenly. I used a big socket to press it in. Good Luck. AG Link to comment Share on other sites More sharing options...
Dick Dastardly Posted March 9, 2012 Report Share Posted March 9, 2012 Yes OE seal, and yes, it did get tweaked....I pushed it in a side at a time. I guess I shouldn't have done that.... Can I redo it, using the same seal? I would honestly buy a new one and press it evenly..If you bend them they no longer fit correctly and you will never bend it back perfectly. Link to comment Share on other sites More sharing options...
rmorse Posted March 9, 2012 Author Report Share Posted March 9, 2012 Weak..... Le sigh. Thanks guys. Link to comment Share on other sites More sharing options...
