Tomuch5oost Posted March 26, 2012 Report Share Posted March 26, 2012 Hi I am new to volvo and I am looking for a rear wheel drive manual transmission that works with the s70 t5 motor ( B5234T3 ). any idea if the 740 modle has a manual or 240 would work? im running a stock motor and turbo and want the feel of a clutch but hate FWD ... any seggestions? Link to comment Share on other sites More sharing options...
Tomuch5oost Posted March 26, 2012 Author Report Share Posted March 26, 2012 I have also read that the s70 can be maited to the t5 trans out of the ford mustang ... with an adapter plate what is the best route to go if I wanted to put a B5234T3 into a 240? two door ... Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted March 26, 2012 Report Share Posted March 26, 2012 Ask over on turbobricks.com, they know the RWD scene quite a bit better then us. I do know what you are talking about is possible though. Link to comment Share on other sites More sharing options...
okoye Posted March 26, 2012 Report Share Posted March 26, 2012 depends on what rwd volvo you're attempting to do it in. there are a few guys that are using t6 from the s80's in the 960's as they use the same mounts. as far as the 250 and 740 go with the t5 motor you'd need custom mounts. as for the t5 mustang trans you'll need an adapter plate, throw out bearing and i forgot the last thing. Link to comment Share on other sites More sharing options...
JRL Posted March 26, 2012 Report Share Posted March 26, 2012 That's not going to happen PERIOD Link to comment Share on other sites More sharing options...
greekone Posted March 26, 2012 Report Share Posted March 26, 2012 That's not going to happen PERIOD It's been done...... Link to comment Share on other sites More sharing options...
andyb5 Posted March 27, 2012 Report Share Posted March 27, 2012 Hi I am new to volvo and I am looking for a rear wheel drive manual transmission that works with the s70 t5 motor ( B5234T3 ). any idea if the 740 modle has a manual or 240 would work? im running a stock motor and turbo and want the feel of a clutch but hate FWD ... any seggestions? Users "Karl Buchka" and "Captain Bondo" on here have done whiteblock swaps into RWD Volvos. Karl and his brother swapped at T5 into a 242, and Captain Bondo had a T6 in his 245 "Homer" is in the process of swapping a T5 into his 244. Link to comment Share on other sites More sharing options...
bassguy Posted March 30, 2012 Report Share Posted March 30, 2012 M90 out of a European market 960? Link to comment Share on other sites More sharing options...
okoye Posted March 31, 2012 Report Share Posted March 31, 2012 m90 can work but are extremely expensive, counting in shipping and the actual cost of parts. not to mention when something goes wrong. Link to comment Share on other sites More sharing options...
bassguy Posted March 31, 2012 Report Share Posted March 31, 2012 I only mentioned it because it sits behind a RWD whiteblock motor. So for "stock" options, it's the only one, unless you want the weak crap (>250hp) M46 or M47 Link to comment Share on other sites More sharing options...
Kevin. Posted March 31, 2012 Report Share Posted March 31, 2012 Not to mention Robbie is putting a Whiteblock into an E30. There's also a member on here in the middle of a RWD swap on an 850. He's using a BMW transmission and a E39 rear end I believe Link to comment Share on other sites More sharing options...
bassguy Posted March 31, 2012 Report Share Posted March 31, 2012 Who's doing the RWD 850? Link?Also, is the BMW trans a Getrag 265? Link to comment Share on other sites More sharing options...
Kevin. Posted March 31, 2012 Report Share Posted March 31, 2012 Link to comment Share on other sites More sharing options...
Jazzy_J Posted March 31, 2012 Report Share Posted March 31, 2012 2 people on turbo bricks are about to finish t5 swaps. one is into a 700 series the other into a 240. Have to modify the pan for the 240 not sure on the 700 series. Link to comment Share on other sites More sharing options...
Tomuch5oost Posted April 13, 2012 Author Report Share Posted April 13, 2012 "Also, is the BMW trans a Getrag 265" true or false this trans can work? if so what is different that is needed? and Do I need to custom fab up motor mounts from my sub-frame to the motor? B5234T3 is that a red or white block still not shure on that, and Im tryin to stuff that motor with a manule trans into an e30 BMW .... tryin to make a monster :D any other seggestions much appreciated -J Link to comment Share on other sites More sharing options...
