volvoguy23 Posted March 31, 2015 Report Share Posted March 31, 2015 Yea me too, I'm worried more about the stock brakes and transmission. Andy would you recommend using a tow dolly on a stock fwd turbo wagon to tow other fwd Volvo's? Quote Link to comment Share on other sites More sharing options...
andyb5 Posted April 1, 2015 Author Report Share Posted April 1, 2015 Thanks for the kind words guys! Towing was fine, I pulled it ~3 hours home on a combo of backroads and highways with plenty of hills for good measure. On that trip, my wagon was loaded up with 3 passengers, a couple hundred pounds of tools/spares, and towing a car. I got 18 MPG (calculated by mileage driven/fuel consumed) and I was pretty happy with that, given I'm AWD, and have sticky 235s adding to the rolling resistance. The biggest concern I had going into the trip was stopping power. My wagon had 302s with fairly well worn and unknown pads at the time, and while stopping took some effort and definitely a good ways more than normal, I never felt any fade or was in danger of brake failure. I gave myself tons of space to stop, and kept the trans locked in the lowest gear possible to take advantage of any engine braking I could. The trans was fine, no issues whatsoever. Quote Link to comment Share on other sites More sharing options...
andyb5 Posted May 26, 2015 Author Report Share Posted May 26, 2015 Unfortunately, M66 couldn't happen before Carlisle due to time constraints. So as a "consolation prize" I threw some CX Racing coilovers at it to replace my factory (182,xxx miles) struts. They're a huge improvement, and I really haven't spent much time to dial them in yet. A more-in depth list of my thoughts and impressions can be found here: http://volvospeed.com/vs_forum/topic/168003-cxracing-coilover-kit-install/?do=findComment&comment=2378238Fresh paint on the (formerly gold) STI wheels: R-bumper and Tomcat lip back onHow it sat at CarlisleFront wheels are nearly flush at et34 with 235sM66 sits, waiting. The swap getting delayed allowed time for my PDV upgraded collar gear to be delivered. That is good news, because I won't have to deal with swapping collar gears in the car, instead I can install it before the trans goes in. Before the manual swap happens I'm rebuilding a spare cylinder head to deal with leaky front cam seals and worn valve stem seals so I know the car is 100% ready for Stevo to tune. 4 Quote Link to comment Share on other sites More sharing options...
apeacock Posted May 26, 2015 Report Share Posted May 26, 2015 When are you planning to get it done? Quote Link to comment Share on other sites More sharing options...
Commander Riker Posted May 26, 2015 Report Share Posted May 26, 2015 Nice work! It's going to be even more fun to drive. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 26, 2015 Report Share Posted May 26, 2015 Nice to have a stronger bevel gear collar - I wasn't aware of that product. I would consider it an essential part for a performance build, for sure. 1 Quote Link to comment Share on other sites More sharing options...
andyb5 Posted July 15, 2015 Author Report Share Posted July 15, 2015 When I bought the car 3+ years ago, the front intake cam seal was seeping a little bit and it smoked on a cold start because the exhaust valve stem seals were leaking oil into the exhaust ports. Plus, cylinder 2 had a pretty good exhaust leak between the head and manifold. I had no desire to deal with fixing any of these on the car, so I rebuilt a spare cylinder head I got from Ian Carr a couple years ago and installed it a few weeks ago. With the exception of having a machine shop glass-bead and hot-tank the head to clean the oil sludge out, I'm proud to say I did all the work on this job. It was somewhat intimidating beforehand but now that I've done it, it really wasn't too bad. I did all the teardown/re-assembly in my living room Old head on the way out: Cleaning the pistons and mating surfaces Installed an R-manifold I picked up from Semir a while back And slapped a Forge CBV (thanks Tommy!) on while the turbo was out Took this opportunity to make my life a bit easier and install a Xemodex ETM while the intake manifold was off the car New OEM HG with the early style coolant ports. Neither of my 99 B5234T heads had any cracks around the spark plugs Both the factory head I took off the car and the rebuilt head are hydraulic lifter heads with 7mm valve stems, as is to be expected from an early RN head Finished product looking good. Put everything back on, and the car fired right up, no leaks or issues related to the head swap so the M66 is up next! Edit: forgot to add the results from the compression test after I replaced the head: 1 - 173 2 - 165 3 - 167 4 - 170 5 - 171 Less than a 5% difference - not bad for a motor with 185,000 miles it. I am ecstatic with those numbers. 8 Quote Link to comment Share on other sites More sharing options...
Tommy. Posted July 15, 2015 Report Share Posted July 15, 2015 (edited) Looking good Andy! Hope the forge treats you well! Edited July 15, 2015 by Tommy. 1 Quote Link to comment Share on other sites More sharing options...
H0lD mY d6InK Posted July 16, 2015 Report Share Posted July 16, 2015 That is awesome. Ha, that is a great idea because I need to do the same thing.Can't argue when everything comes together and just works, great job! Quote Link to comment Share on other sites More sharing options...
andyb5 Posted July 20, 2015 Author Report Share Posted July 20, 2015 Started the M66 swap over the weekend. One perk of having a lift - simply pick the car up off the motor, transmission, and subframe Removed the angle gear, auto trans, flexplate/torque converter, etc.New OEM RMS installed - a 4" PVC drain grate from Home Depot worked perfectly as a drift. I'm using a single mass flywheel, Sachs SD-693 clutch and an 850 R pressure plate. And started getting the M66 ready to go back in. Shaved the webbing to allow easier removal of the drives axleGot the original collar gear removed. It was not easy. 4+ hours of work and countless failed attempts with all manner of tools. I ended up cutting a hole through the gear with a cutoff wheel, then used an air hammer to drive it out while heating the collar with a torch and pulling with a pair of vice grips. A huge thank you to Semir (d s50r) for helping me with this.Cleaned the splines on the transmission output gear.A few months back I bought a PDV high strength collar gear. It comes with all the necessary seals and grease needed to install it. I started the gear with a rubber mallet, then used a press to drive it the rest of the way.Went to install the trans bracket Hussein made, but found a slight modification will be needed - P2 M66s this boss is not tapped, but on a P1 M66, it comes tapped to M12x1.75 and I have to enlarge the bolt hole on the bracket. I didn't have the correct drill bit with me last night, so that's the first thing I'll take care of tonight.I don't have pictures, but the brake/clutch pedal, shift cables, and clutch master cylinder are installed too. Dash has been trimmed for the shifter, I just need to grab some different bolts to secure that in place. 2 Quote Link to comment Share on other sites More sharing options...
Modman Posted July 20, 2015 Report Share Posted July 20, 2015 Coming along nicely Andy. Quote Link to comment Share on other sites More sharing options...
phunktified Posted July 20, 2015 Report Share Posted July 20, 2015 was there a 'felt side' on that RMS you used? if so it is supposed to be on the outside Quote Link to comment Share on other sites More sharing options...
Commander Riker Posted July 20, 2015 Report Share Posted July 20, 2015 This is awesome! Grats on the 6 speed swap. I started a turbo swap last weekend, and have decided it's just time to do the manual as well. What are you doing for tuning? 1 Quote Link to comment Share on other sites More sharing options...
Tommy. Posted July 20, 2015 Report Share Posted July 20, 2015 was there a 'felt side' on that RMS you used? if so it is supposed to be on the outside I second this! Quote Link to comment Share on other sites More sharing options...
andyb5 Posted July 20, 2015 Author Report Share Posted July 20, 2015 Jay & Lucas, thanks for the kind words. I'm having Stevo tune the car - he's tuned his old S60 R, his S70 T5, Tom Long's 00 R, Bmac's S60 T5, Timo's S60 R, etc. was there a 'felt side' on that RMS you used? if so it is supposed to be on the outside I second this!Shit. There was a felt outside to the one I removed, but I honestly don't remember if there was felt on the seal I installed. I'd rather not re-do this in the future, so I guess I'm gonna go buy another seal at the dealership ($40) after work today Quote Link to comment Share on other sites More sharing options...
