Thanks Sam, really appreciate it. I'm going to be back in December for winter break, and then I should be around for the summer (May to August)
Its alright, there will be plenty more in the spring.  Sucks about the tethy, what are your plans for it?
  • 1 month later...
Lookin great dude! When are you back in RI?
Got back to RI today.
Now that school is finished for the semester, I had some time to mess around with my D3100 a bit.
And messed around in photoshop a bit
  • Upvote 1
Made a couple GIFs
Will look forward to pics/comments on your IC pipe routing.
Finally had some time to work on my FMIC piping. IC in/out is 2.5", I went with 2.25" to make sure I could fit everything. Still waiting on a couple straight pipes and hoses to come in, so you'll notice those are missing......
First step was to do the for easier access to the ETM and more space for piping
Here's a quick drawing of my planned routing
Some pictures of the hot side in progress....up and across the engine bay
And straight down by the fan shroud...
and around to the IC
Blue painters tape is temporary until I get those seams welded up
And now the cold side:
Still need to cut a few pieces (hence the paper...) and drill the holes for the factory boost pressure and temperature sensors--if anyone has any input on the best way to do that, I'm all ears.
2.25"-->3" 90* elbow into the TB. The elbow just clears the dipstick and starter. I might trim it a bit so it clears the dipstick a bit more, we'll see.
  • Upvote 1
Thanks H, I was more than a bit inspired by all your drawings when I was doing that sketch
Pras, I did have to cut the plastic rails out for my Pioneer to fit in the stock opening. You can see the rails were removed in the first photo in the how-to I wrote.
For the bezel, I bought a piece of 1/16" black ABS plastic from Amazon and cut the internal opening out by hand with a ruler and Exacto knife first, then trimmed it to fit the dash a bit at a time. If I had been at school when I did the install, I would have laser-cut the bezel for a slightly better fit. The fit right now is pretty good, but there is always room for improvement. My old Pioneer unit came with a bezel that had a pre-cut opening for the unit, and I had to trim it to fit the dash opening.
Nice work Andy! I was stumped by the sensors too. Other then Doe88 style. You could just epoxy the sensors into the pipe for a permanent installation.
I'm trying to do a RIP since I've got the drop in intercooler. I had thought of trying to use a P2 plastic throttle pipe from the throttle pipe. I know the s80 T6 plastic pipe won't work but maybe with the fan trick it could...
I had given some serious thought about re-using just the section of the stock intake where the sensors are
Just use straight silicone hoses to join that section in-line with the aluminum piping. That's probably the easiest way to do it, but I'm stubborn and want to find a way to accomplish it without cutting up a stock intake pipe
This is the "do88.se" method Neu is referring to:
  • 1 month later...
I let my friend drive my car last night, and he slid in the snow and accidentally hit a concrete light post. Winter Storm Nemo 1, Andy 0.
The bumper and the hood don't look so great, but its not the end of the world. My friend is ok, no airbags deployed, no major damage to the car, and it still runs fine. He's paying for parts, I'm doing the work, and I don't depend on my car while I'm at school, so I'm not too upset about it. Shit happens, just gotta fix it and move on.
I started to pull parts off this afternoon to get a handle on what needs replacing, and a short while later, I was sick of working outside
After pulling everything off, it looks like the radiator support,hood, and bumper beam need replacing. The passenger bumper mount bracket needs some straightening, but the frame rail looks pretty good, and I'm not sure if I'll replace the hood right now, or wait till it is warmer out.
I'm going to get the parts I need from one of Semir's (D S50 R) parts cars tomorrow , and this is how it sits now. Bonus points to whomever IDs what beer I was drinking
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
