Andy's 1999 V70 R
Thanks for the kind words guys!
Towing was fine, I pulled it ~3 hours home on a combo of backroads and highways with plenty of hills for good measure. On that trip, my wagon was loaded up with 3 passengers, a couple hundred pounds of tools/spares, and towing a car. I got 18 MPG (calculated by mileage driven/fuel consumed) and I was pretty happy with that, given I'm AWD, and have sticky 235s adding to the rolling resistance.
The biggest concern I had going into the trip was stopping power. My wagon had 302s with fairly well worn and unknown pads at the time, and while stopping took some effort and definitely a good ways more than normal, I never felt any fade or was in danger of brake failure. I gave myself tons of space to stop, and kept the trans locked in the lowest gear possible to take advantage of any engine braking I could. The trans was fine, no issues whatsoever.
  • 1 month later...
Unfortunately, M66 couldn't happen before Carlisle due to time constraints.  So as a "consolation prize" I threw some CX Racing coilovers at it to replace my factory (182,xxx miles) struts.  They're a huge improvement, and I really haven't spent much time to dial them in yet.  A more-in depth list of my thoughts and impressions can be found here: http://volvospeed.com/vs_forum/topic/168003-cxracing-coilover-kit-install/?do=findComment&comment=2378238
14BD5DFE-99F6-4260-A43B-CAA382332C54_zps
Fresh paint on the (formerly gold) STI wheels:
7D6786F4-79CE-43B7-8770-1E5898058C0A_zps
R-bumper and Tomcat lip back on
2EB18EBD-3ED8-4DEE-AB5D-0E838CD6BEA9_zps
How it sat at Carlisle
D2399D41-F463-4A40-BAFD-0D2C0DC67565_zps
Front wheels are nearly flush at et34 with 235s
M66 sits, waiting.  The swap getting delayed allowed time for my PDV upgraded collar gear to be delivered.  That is good news, because I won't have to deal with swapping collar gears in the car, instead I can install it before the trans goes in.  Before the manual swap happens I'm rebuilding a spare cylinder head to deal with leaky front cam seals and worn valve stem seals so I know the car is 100% ready for Stevo to tune.
9F6D9877-9133-411F-9316-F54D9B284F3A_zps
  • Upvote 4
  • 1 month later...
When I bought the car 3+ years ago, the front intake cam seal was seeping a little bit and it smoked on a cold start because the exhaust valve stem seals were leaking oil into the exhaust ports.  Plus, cylinder 2 had a pretty good exhaust leak between the head and manifold.  I had no desire to deal with fixing any of these on the car, so I rebuilt a spare cylinder head I got from Ian Carr a couple years ago and installed it a few weeks ago.
With the exception of having a machine shop glass-bead and hot-tank the head to clean the oil sludge out, I'm proud to say I did all the work on this job.  It was somewhat intimidating beforehand but now that I've done it, it really wasn't too bad.  I did all the teardown/re-assembly in my living room
9DC1429E-1F31-4C67-83A5-66AA974B38E8_zps
F5B0C200-8FED-47DB-97EA-E52BCC738B62_zps
Old head on the way out:
272B1588-A762-4D80-8D50-35297E865AA6_zps
322B50EC-615F-4F69-BDFF-F87A9BBE0083_zps
Cleaning the pistons and mating surfaces
3271F084-8407-4E55-A7D5-F25887F0A4C5_zps
CC286ED5-419F-495F-8BE1-B72D62BC33E7_zps
Installed an R-manifold I picked up from Semir a while back
C6442BBC-711A-4FD8-AEF2-949A1748B198_zps
And slapped a Forge CBV (thanks Tommy!) on while the turbo was out
7DF8AA80-E007-49C9-8924-6E3DACFC6B49_zps
Took this opportunity to make my life a bit easier and install a Xemodex ETM while the intake manifold was off the car
E26886C6-66E3-4103-BB63-FAB085FDB0C2_zps
New OEM HG with the early style coolant ports.  Neither of my 99 B5234T heads had any cracks around the spark plugs
BED8A179-D8A0-4BB1-965C-4D85B7F79753_zps
Both the factory head I took off the car and the rebuilt head are hydraulic lifter heads with 7mm valve stems, as is to be expected from an early RN head
412C1510-E2E8-454D-A414-1806ACA42786_zps
Finished product looking good.
7EA1ED09-9E14-4227-AF7E-460FC901CFFD_zps
Put everything back on, and the car fired right up, no leaks or issues related to the head swap so the M66 is up next! :D
Edit: forgot to add the results from the compression test after I replaced the head:
1 - 173
2 - 165
3 - 167
4 - 170
5 - 171
Less than a 5% difference - not bad for a motor with 185,000 miles it. I am ecstatic with those numbers.
  • Upvote 8
Started the M66 swap over the weekend.
One perk of having a lift - simply pick the car up off the motor, transmission, and subframe :D
Removed the angle gear, auto trans, flexplate/torque converter, etc.
8CE8AC20-3945-4508-B1C5-ED2F40AB3479_zps
New OEM RMS installed - a 4" PVC drain grate from Home Depot worked perfectly as a drift.
CCB7385D-A095-4FEC-8442-BA7A56B0771F_zps
I'm using a single mass flywheel, Sachs SD-693 clutch and an 850 R pressure plate.
71631617-EB40-4009-B5A8-42FC7BB68FDA_zps
And started getting the M66 ready to go back in.
Shaved the webbing to allow easier removal of the drives axle
2DAB7096-0A7A-460D-AB8D-1B7501F77E93_zps
Got the original collar gear removed.  It was not easy.  4+ hours of work and countless failed attempts with all manner of tools.  I ended up cutting a hole through the gear with a cutoff wheel, then used an air hammer to drive it out while heating the collar with a torch and pulling with a pair of vice grips.  A huge thank you to Semir (d s50r) for helping me with this.
0D39281C-D297-470E-817A-E67010736857_zps
Cleaned the splines on the transmission output gear.
6222F0E4-05BB-4842-9A1F-CCD9B8738F81_zps
A few months back I bought a PDV high strength collar gear.  It comes with all the necessary seals and grease needed to install it.  I started the gear with a rubber mallet, then used a press to drive it the rest of the way.
BD482B48-D6DC-4B9E-A5D5-7805E7A29230_zps
91EDA07C-AF35-4285-BC5D-91AEDD98DA26_zps
Went to install the trans bracket Hussein made, but found a slight modification will be needed - P2 M66s this boss is not tapped, but on a P1 M66, it comes tapped to M12x1.75 and I have to enlarge the bolt hole on the bracket.  I didn't have the correct drill bit with me last night, so that's the first thing I'll take care of tonight.
0151BECE-10E7-4B24-A6D4-5B0A6F39F0D2_zps
I don't have pictures, but the brake/clutch pedal, shift cables, and clutch master cylinder are installed too.  Dash has been trimmed for the shifter, I just need to grab some different bolts to secure that in place.
  • Upvote 2
Jay & Lucas, thanks  for the kind words.  I'm having Stevo tune the car - he's tuned his old S60 R, his S70 T5, Tom Long's 00 R, Bmac's S60 T5, Timo's S60 R, etc.
was there a 'felt side' on that RMS you used?  if so it is supposed to be on the outside
I second this!
Shit.  There was a felt outside to the one I removed, but I honestly don't remember if there was felt on the seal I installed.  I'd rather not re-do this in the future, so I guess I'm gonna go buy another seal at the dealership ($40) after work today
Guest
Reply to this topic...
  Only 75 emoji are allowed.
