This finally happened:
Finally got around to installing the Kenwood DDX-470 that I have had for several months. It was a chore figuring out how to make it work with the SC-901 wiring, but I (with some assistance) got it done over the weekend. Wow! Just Wow!! I love this thing! It is easy to use and sounds better than the stock SC-901 even using the same speakers and no amp. Ghost shadow was totally right, compared to this, the SC-901 sucks. I would never go back!
  • 3 months later...
Haven't done much to this car since the last update. Just washing it and driving it. Maybe I'll do an exhaust next spring...
Anyways, I was following the wife the other day and was able to get a couple decent rollers..
That's all.
yea ive got a similar model and night and day difference! amazing radio
Indeed, it's amazing how much difference just a modern head unit can make. I don't know what I'd do without my pioneer, SC-816s make me want to strangle puppies.
The only gripe I have with the head unit is that I have too much music on my USB drive and it will only play up to a certain number of folders.. I think this cuts off my music somewhere in the "R"s. Not really an issue as I just divide the alphabet in half and put it on 2 sticks and rotate them occasionally. that and I have a "strictly best of everything" USB stick with only my absolute favorites on it.
Just rename all the songs that start with R and beyond to begin with an A...problem solved. :ph34r:
  • 1 month later...
Car is now in storage for the winter.
There are a few things I will have to tinker with when it gets out in the spring, but shouldn't be too much.
-Taillights are still having issues. I suspect that the circuit boards are bad because fiddling with them fixed the problems for a short time before they come back. I'll try to track down new boards over the winter.
-Steering wheel is nasty, I'd like to track down a wheel with the wood inlay. the very dark walnut? I think? Idk.
-Need to hook up a sub/amp.
-Needs an exhaust soon.
-Other Misc piddly crap..
Either way, It's cozy now and out of the weather for the winter.
  • 4 months later...
Posted (edited)
Brought it home from storage (about 10 min drive). I miss driving this car!
Seeing it's first light since November...
And here it sits at home being prepped for summer:
Done so far:
-Plates/tags updated
-All fluids checked, topped off as needed
-Taillight circuit boards changed
Still to do before summer:
-Pull intake manifold and upgrade PCV hose per MVS
-Replace worn out steering wheel (have one coming)
-roll rear fenders slightly
-Maybe screw with trying to fix headlight wipers..
-Maybe add sub and amp I have in the basement... Maybe...
Edited by tuner4life
  • Upvote 1
Got the intake manifold off to upgrade the pcv line to 5/8 heater hose and found that any rubber in the system that was from URO was cracked and broken.. It was only 2 years old.. WTF!?!? It's ok, most of it is going in the trash.. Also found an injector o-ring that was leaking and the intake flex tube was cracked..
Lots to do...
Don't have any pictures, but got the pcv hose upgraded to the 5/8 hose, but I am still having smoke from the dipstick after long trips.. Not very much, and there isn't much pressure, but I thought that the 5/8 hose would make it go away.. Any Ideas?
On a slightly different note, that intake looks great and it runs awesome now! I wonder how long my old intake hose had been split..
  • 2 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
