Volvo5.0 Posted June 6, 2012 Report Share Posted June 6, 2012 in my 2011a i can only change it in the advance tab, what version you running? I checked a few cars today, and it appears that some years are done in the advanced tab like you said. The DRL on the '01 and '02 V70's that I checked were both turned off in the "programmed values" tab. I also checked an '05 V70 and I had to go to the "advanced tab" to find it, and turn them off.... Link to comment Share on other sites More sharing options...
ARD - Lucky Posted June 6, 2012 Report Share Posted June 6, 2012 VIDA 2011D is compatible with the latest WIN7 x64 x32 systems so I would recommend using that. No need for an older system. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted June 7, 2012 Author Report Share Posted June 7, 2012 thanks lucky....now i need to search for 2011d Link to comment Share on other sites More sharing options...
ARD - Lucky Posted June 7, 2012 Report Share Posted June 7, 2012 I can post it up on my server if you guys would like.... Link to comment Share on other sites More sharing options...
TxS70 Posted June 7, 2012 Report Share Posted June 7, 2012 I was under the assumption that 02's had to have the software changed, this is good news! Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 7, 2012 Report Share Posted June 7, 2012 To whom it may concern, changing headlight settings on P1 vehicles (s40, v50, c30, c70) requires a software download. Tried to program the SO's 07 C70 headlights and it would not let me without a specific software package. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted June 7, 2012 Author Report Share Posted June 7, 2012 I can post it up on my server if you guys would like.... i like..let me hit that when you ready I checked a few cars today, and it appears that some years are done in the advanced tab like you said. The DRL on the '01 and '02 V70's that I checked were both turned off in the "programmed values" tab. I also checked an '05 V70 and I had to go to the "advanced tab" to find it, and turn them off.... confirmed i am not nuts LOL, i confirmed this too for 25 minutes when i got home last night! Link to comment Share on other sites More sharing options...
BlackT5 Posted June 7, 2012 Report Share Posted June 7, 2012 I can post it up on my server if you guys would like.... i like..let me hit that when you ready Wouldn't mind hittin it also. Ordered a 2011a unit from OP link yesterday. Link to comment Share on other sites More sharing options...
Dan A Posted June 7, 2012 Report Share Posted June 7, 2012 VIDA 2011D is compatible with the latest WIN7 x64 x32 systems so I would recommend using that. No need for an older system. Yeah, but not with any of the Win7 Home versions which was my problem. Link to comment Share on other sites More sharing options...
sconeman Posted June 7, 2012 Report Share Posted June 7, 2012 I can post it up on my server if you guys would like.... would very much like as I have a W7 64 laptop. is there any compatibility issue with VIVA 2011d and Dice 2011a? need to get this setup it would make my life so much easier. Link to comment Share on other sites More sharing options...
Dan A Posted June 7, 2012 Report Share Posted June 7, 2012 DiCE is not "2011A";, that's probably just the version of VIDA that was packaged with your DiCE hardware. I've not heard of problems of upgrading VIDA versions. However, Volvo released a new firmware for DiCE for use with VIDA 2012B. Not sure if this firmware works on the cloned hardware - I'm not going to try. But I would think you shouldn't have any problems with a newer 2011 version. If so, it's easy enough to revert back the software. Link to comment Share on other sites More sharing options...
sconeman Posted June 8, 2012 Report Share Posted June 8, 2012 gothca thanks for the explanation. Although if only one version is compatible with Win7 64 then I wouldn't be able to revert if there was a compatibility problem. Since I have no experience with VIDA I have noob questions. Link to comment Share on other sites More sharing options...
TxS70 Posted June 9, 2012 Report Share Posted June 9, 2012 Confirmed: DRLs shut off on 02 s60. Thanks! Link to comment Share on other sites More sharing options...
ARD - Lucky Posted June 9, 2012 Report Share Posted June 9, 2012 I'm a bit buried right now, but I can post up the torrent if that's easier... Link to comment Share on other sites More sharing options...
Dan A Posted June 10, 2012 Report Share Posted June 10, 2012 <p><br /> Although if only one version is compatible with Win7 64 then I wouldn't be able to revert if there was a compatibility problem. Haha, this is quite true. Link to comment Share on other sites More sharing options...
