tchnprgrmr Posted July 4, 2015 Report Share Posted July 4, 2015 I finally got around to installing this, it worked perfectly with the mazdaspeed3 caliper. Just needed the 2 bolts switched to the mazda thread pattern. Link to comment Share on other sites More sharing options...
ashvolvo Posted July 8, 2015 Report Share Posted July 8, 2015 Awesome.I'm glad that you've got it all together too. Mazda are M12x1.25 whereas Volvo/Ford are M12x1.75.They're now available from ViVA too.See -http://www.vivaperformance.com/320mm-front-brake-upgrade-volvo-850-s-c-v70/ Link to comment Share on other sites More sharing options...
RobT5M Posted July 8, 2015 Report Share Posted July 8, 2015 Wow that is a crazy price for those calipers. Must be a 300% mark up on the calipers alone. Maybe I should buy all my 320mm mazda calipers from work and sell them myself. Ash I need to hit you up for the bolt like Jeremy got. Going to try to pull the trigger and finally install the fronts sometime in the near future. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted July 8, 2015 Report Share Posted July 8, 2015 Reman brake calipers at a decent price.... LH & RH Link to comment Share on other sites More sharing options...
Piston Slapper Posted July 8, 2015 Report Share Posted July 8, 2015 Reman brake calipers at a decent price.... LH & RHSame thing but even cheaper:http://www.amazon.com/Cardone-19-B3272-Brake-Caliper-Bracket/dp/B007ETC9H2http://www.amazon.com/Cardone-19-B3273-Brake-Caliper-Bracket/dp/B007ETC9Y0 Link to comment Share on other sites More sharing options...
RobT5M Posted July 8, 2015 Report Share Posted July 8, 2015 Same thing but even cheaper:http://www.amazon.com/Cardone-19-B3272-Brake-Caliper-Bracket/dp/B007ETC9H2http://www.amazon.com/Cardone-19-B3273-Brake-Caliper-Bracket/dp/B007ETC9Y0Really a great price right there. Its awesome they dont charge a core or anything. Going to see if I can beat that price with the mazda calipers after shipping. Link to comment Share on other sites More sharing options...
Fran9690 Posted July 8, 2015 Report Share Posted July 8, 2015 I tried sifting through the thread to find my answer, maybe it's there and I missed it, but I skimmed through the 26 pages with no luck. Has it been confirmed whether you can use the 320mm rotors off the S60 for this upgrade, or do you need to get the S40 rotors and either machine them larger or get hubcentric rings to get them to fit? Thanks in advance. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted July 8, 2015 Report Share Posted July 8, 2015 Another source for cheap calipershttp://autoplicity.com/3708383-a1-cardone-19-b3272http://autoplicity.com/3708383-a1-cardone-19-b3272 Link to comment Share on other sites More sharing options...
Piston Slapper Posted July 9, 2015 Report Share Posted July 9, 2015 I tried sifting through the thread to find my answer, maybe it's there and I missed it, but I skimmed through the 26 pages with no luck. Has it been confirmed whether you can use the 320mm rotors off the S60 for this upgrade, or do you need to get the S40 rotors and either machine them larger or get hubcentric rings to get them to fit? Thanks in advance.I don't think the P2 S60 has a 320mm option, and the P3s have the smaller hub bore like the P1s. So you're going to have to bore out some rotors. Rings work to fit wider things on smaller hubs, this can't be done with a ring. Link to comment Share on other sites More sharing options...
Blockpartie Posted July 9, 2015 Report Share Posted July 9, 2015 There is a 320mm brake kit for the P2 cars. I had talked to Will about adapting the whole brake (caliper and everything) but nothing came of it. But it's possible.I don't think you can mix the P2 brake disc with P1 calipers. Link to comment Share on other sites More sharing options...
ashvolvo Posted July 9, 2015 Report Share Posted July 9, 2015 Ash I need to hit you up for the bolt like Jeremy got. Going to try to pull the trigger and finally install the fronts sometime in the near future. No problem. Let me know when you're ready.For the Mazda caliper? M12x1.25?I tried sifting through the thread to find my answer, maybe it's there and I missed it, but I skimmed through the 26 pages with no luck. Has it been confirmed whether you can use the 320mm rotors off the S60 for this upgrade, or do you need to get the S40 rotors and either machine them larger or get hubcentric rings to get them to fit? Thanks in advance.Definitely needs to be from a P1 car - Volvo S40/V50T5 AWD or Ford Focus XR5/ST LS-LV models. The S60 rotor will not work unfortunately.Its a bit frustrating that the P2 rotor couldnt be used. The need to machine the rotor centrebore, while it is quite inexpensive, its the most annoying part of it all. Link to comment Share on other sites More sharing options...
Martijn_B Posted July 21, 2015 Author Report Share Posted July 21, 2015 Funny how this became such a big thing in 2 years time. Happy to see that many enthousiasts are benefitting from this upgrade! Link to comment Share on other sites More sharing options...
Volvo5.0 Posted July 21, 2015 Report Share Posted July 21, 2015 Funny how this became such a big thing in 2 years time. Happy to see that many enthousiasts are benefitting from this upgrade!See what your started Martijn! Link to comment Share on other sites More sharing options...
Martijn_B Posted July 23, 2015 Author Report Share Posted July 23, 2015 Well.. I need to give credit where its due: officially all the credit goes to Sebastiaan, a fellow Dutch Volvo driver who created the set for me Link to comment Share on other sites More sharing options...
ashvolvo Posted July 24, 2015 Report Share Posted July 24, 2015 Hilariously, we were working on it for a while (having not been particularly active on VS) while Martijn was without even knowing.I still think for what it costs, it really is very hard to beat. Link to comment Share on other sites More sharing options...
