854TGA+ Posted August 3, 2012 Report Share Posted August 3, 2012 FYI, oven cleaner & a tooth brush will make those pistons look like new. Make sure you wash them with hot water & soap right after using oven cleaner & oil them down. Safety glasses are good thing also! Seeing is believing / cleaned & not cleaned Link to comment Share on other sites More sharing options...
FINN Posted August 3, 2012 Report Share Posted August 3, 2012 Sand blasting works wonders cleaning up those pistons and block as well. Link to comment Share on other sites More sharing options...
850wagonT5 Posted August 3, 2012 Report Share Posted August 3, 2012 Hm.. I should figure out a way to log timing then as i do not have OBD II. The OBD port will still give you ignition timing on the 94-95 turbos. The resolution isn't the greatest, but I use Torque for Android. You can log any parameter you wish with it. Link to comment Share on other sites More sharing options...
Martijn_B Posted August 3, 2012 Author Report Share Posted August 3, 2012 Thanks for the tips! I'll have the pistons Cleaned at the machine shop, they will do it for free so hey why not Now I still have to figure out those bearings, shouldn't I be able to measure something? Link to comment Share on other sites More sharing options...
FINN Posted August 3, 2012 Report Share Posted August 3, 2012 Volvo sizes their factory bearings by the stampings on the block and crank. Are you ordering OEM bearings? Lots of us are using Toga bearings. Hussein being the first that I know of. Much cheaper than OEM. Link to comment Share on other sites More sharing options...
Martijn_B Posted August 3, 2012 Author Report Share Posted August 3, 2012 I was going to re-use the old ones as they look perfect as the machine shop said. We measured them today with a micrometer but they are all of the exact same thickness. Link to comment Share on other sites More sharing options...
Martijn_B Posted August 4, 2012 Author Report Share Posted August 4, 2012 I purchased something today: And I like it!! Link to comment Share on other sites More sharing options...
FINN Posted August 5, 2012 Report Share Posted August 5, 2012 That certainly did the trick. What solution? Link to comment Share on other sites More sharing options...
Martijn_B Posted August 6, 2012 Author Report Share Posted August 6, 2012 I used Tickopur R33 universal cleaning liquid, 5% solution. I'm wondering if I can also clean my valves in the Ultrasound cleaner? Furthermore, I have started tuning with the Turbo Tuner yesterday. As a basemap I used a map of a friend of mine, which is tuned for a 19T with 440cc injectors. I run a K24 with greens, and our setup is very similar except for me having both intake and exhaust '93 N/A cams. (set on turbo cams timing). The tune was way too rich, around 10,4 AFR at WOT. So when trying to lean it out towards 12,7 the engine started to disagree around 11,3 AFR. It started to misfire/backfire (made a "popping" sound). Any idea what this could be? If it runs richer then there's no problem, but as soon as i pass 11,3 AFR the trouble begins. I installed my other ECU on the way back home, and found out it also pops (but only once at 5000rpm). Never used to do that before. Ignition system failure? (plugs?) Link to comment Share on other sites More sharing options...
850wagonT5 Posted August 7, 2012 Report Share Posted August 7, 2012 You can do valves in there, yes...though, bead blasting is faster and yields better results. Link to comment Share on other sites More sharing options...
Martijn_B Posted August 7, 2012 Author Report Share Posted August 7, 2012 Yeah but I don't have a bead blaster. Found out my girlfriend put octane 95 in the car this weekend, so will add two bottles of octane booster and try again tonight. Anyone has a good address for subframe bushes? Might as well renew those when the Engine is out. Poly or stock Volvo, any good deals out there? Link to comment Share on other sites More sharing options...
Martijn_B Posted August 7, 2012 Author Report Share Posted August 7, 2012 Theres a sale going on on the Hahn Racecraft 16G 10cm2 turbo. They now sell at just $549. Looking for experiences with this turbo, wondering if it can bring me 400hp at the crank? Link to comment Share on other sites More sharing options...
850wagonT5 Posted August 8, 2012 Report Share Posted August 8, 2012 Theres a sale going on on the Hahn Racecraft 16G 10cm2 turbo. They now sell at just $549. Looking for experiences with this turbo, wondering if it can bring me 400hp at the crank? No, you'll want something larger. Link to comment Share on other sites More sharing options...
lookforjoe Posted August 8, 2012 Report Share Posted August 8, 2012 Yeah but I don't have a bead blaster. Found out my girlfriend put octane 95 in the car this weekend, so will add two bottles of octane booster and try again tonight. Anyone has a good address for subframe bushes? Might as well renew those when the Engine is out. Poly or stock Volvo, any good deals out there? Delrin bushings are nice. Link to comment Share on other sites More sharing options...
lookforjoe Posted August 8, 2012 Report Share Posted August 8, 2012 Theres a sale going on on the Hahn Racecraft 16G 10cm2 turbo. They now sell at just $549. Looking for experiences with this turbo, wondering if it can bring me 400hp at the crank? HRC 20g could do it, not the 16g Link to comment Share on other sites More sharing options...
