dneu Posted July 25, 2012 Report Share Posted July 25, 2012 I am trying to solve my friend's 240 sw odd problem. The brake failure light is ON. I have checked all brakes - pads and rotors are Ok, no frozen calipers. Only when brake is applied a short hissing like sound comes from the brake booster. But brake booster works. When I disconnect the brake sensor on the distribution box (it is a ground switch), the failure light goes off and up-shift arrow lits on. Any idea what might might be wrong? thanks Link to comment Share on other sites More sharing options...
dneu Posted July 25, 2012 Author Report Share Posted July 25, 2012 actually, because it is a car with At, the arrow must be an overdrive indicator. Link to comment Share on other sites More sharing options...
DevenlnNY Posted July 28, 2012 Report Share Posted July 28, 2012 I've found this in some of the older Volvo's, there is a relay that controls the brake lights and when they fail, all kinds of neat things happen...including the light failure sign showing up. Link to comment Share on other sites More sharing options...
dneu Posted July 31, 2012 Author Report Share Posted July 31, 2012 Yes, I corrected it, but it did not show up. Problem is not with brake lights but with "brake failure light" and OD indicator light. The wiring diagram I was able to download does not show any connction between the two warning lights. Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted August 13, 2012 Report Share Posted August 13, 2012 Regardless of the shift arrow + bulb failure issue, the fault is most likely that the brake failure switch has been triggered and doesn't want to reset itself. This can be triggered during brake bleeding operations, or possibly when changing brake pads where you push the cylinders back into the calipers, but otherwise indicates an pressure imbalance between the two brake circuits. See: Link to comment Share on other sites More sharing options...
