rmorse Posted April 3, 2013 Report Share Posted April 3, 2013 Sup sup! So, I installed my IPD track sways a couple weeks ago on my 96 855R. I've been hearing a clunking noise in the rear, and finally crawled under to look. My buddy who did the alignment told me that the rear sway was close to the (stock) exhaust....well, that was an understatement lol. I don't think it's actually touching, but it's like half a mm away. I'm pretty positive that that's what's causing my rear clunk, because I didn't have one before. Anyway, I want to replace my exhaust with an OBX so I'm not too worried about it. I do, however, want to make sure that it isn't installed incorrectly or anything. Is this normal that it's that close to the muffler?Oh yea, I guess I should add that I have IPD blue springs and koni yellows. Link to comment Share on other sites More sharing options...
boxpin Posted April 3, 2013 Report Share Posted April 3, 2013 Picture Link to comment Share on other sites More sharing options...
rmorse Posted April 3, 2013 Author Report Share Posted April 3, 2013 Damn it. Ok, I'll try and grab one later. Link to comment Share on other sites More sharing options...
troyhyde Posted April 3, 2013 Report Share Posted April 3, 2013 The blue rear sway? Sounds a little close but in the realm of normal.. The only thing that changes the pitch of the exhaust components would be the condition of the hydraulic mounts. If yours have sagged where the bump stop hits the subframe (above the transmission), the exhaust will be a little funky. I've got that bar on a couple of cars and I have about 1/2" of clearance to the bar. The stocker has a kink where the muffler is, now you know why..... Link to comment Share on other sites More sharing options...
rmorse Posted April 3, 2013 Author Report Share Posted April 3, 2013 The blue rear sway? Sounds a little close but in the realm of normal.. The only thing that changes the pitch of the exhaust components would be the condition of the hydraulic mounts. If yours have sagged where the bump stop hits the subframe (above the transmission), the exhaust will be a little funky. I've got that bar on a couple of cars and I have about 1/2" of clearance to the bar. The stocker has a kink where the muffler is, now you know why..... To my knowledge, mounts have never been changed. Link to comment Share on other sites More sharing options...
icerockt Posted April 3, 2013 Report Share Posted April 3, 2013 My older black IPD rear sway hit the stock muffler and was wedged against the OBX. I had to get both shortened to avoid vibrations and clunks. (This is on the 94 855 T5m) Link to comment Share on other sites More sharing options...
caanglin Posted April 3, 2013 Report Share Posted April 3, 2013 My 25mm ipd rear bar clears a 3" exhaust and also cleared the OBX exhaust. Link to comment Share on other sites More sharing options...
atefitty Posted April 3, 2013 Report Share Posted April 3, 2013 Take a crow bar to that suitcase.. Link to comment Share on other sites More sharing options...
JVC Posted April 3, 2013 Report Share Posted April 3, 2013 Check your exhaust hangers. One might be torn. And then just take a hammer to the suitcase and clearance it. Link to comment Share on other sites More sharing options...
marco bolduc Posted April 3, 2013 Report Share Posted April 3, 2013 Are you sure your car is "straight"/ was not involved in a major accident!? You had problems with the front sways hitting your control arm, now your rear sway hitting the muffler! Seems really weird! Link to comment Share on other sites More sharing options...
Brad850 Posted April 3, 2013 Report Share Posted April 3, 2013 My ipd rear hits my custom exhaust. For now I just put the old bushing from my brothers front sway on the ipd sway. The rear view mirror vibrates a little in drive lol. Doesn't make contact in park or neutral. Gonna hammer it out when I have the time. Link to comment Share on other sites More sharing options...
rmorse Posted April 4, 2013 Author Report Share Posted April 4, 2013 Are you sure your car is "straight"/ was not involved in a major accident!? You had problems with the front sways hitting your control arm, now your rear sway hitting the muffler! Seems really weird! Yea, as close to 100% sure as possible. Link to comment Share on other sites More sharing options...
brownry44021 Posted April 4, 2013 Report Share Posted April 4, 2013 just installed frtont/rear ipd 25mm sways on a 98 s70 with ipd turbo back exhaust and more clearence then between here and the moon? you must have a issue with structure somewhere Link to comment Share on other sites More sharing options...
BurgerBob Posted April 4, 2013 Report Share Posted April 4, 2013 I was talking to Two-Turtles about this, and we agreed that - aside from the fact that this further proves just how shitty Volvos are - you should look into a muffler delete. Mufflers are just so prone to problems. If anything, try and find a way to manually muffle the engine. Maybe route the exhaust so that you can use your spare hand as a muffler? Link to comment Share on other sites More sharing options...
brownry44021 Posted April 4, 2013 Report Share Posted April 4, 2013 and while you are at it, get ahold of fred flinstone and grab that template for the foot brake cutout Link to comment Share on other sites More sharing options...
