Ghettobird Posted May 7, 2013 Report Share Posted May 7, 2013 I want to drift a 240, but don't know what the best year to get it had anyone been involved in any performance B230F Builds or anything? Cheers! Link to comment Share on other sites More sharing options...
BEJinFBK Posted May 7, 2013 Report Share Posted May 7, 2013 Find one with a nice clean body and pretty paint. Any year will do. Then get a small block V-8. Done. Link to comment Share on other sites More sharing options...
okoye Posted May 7, 2013 Report Share Posted May 7, 2013 Get any body year 240 they're all nice just check for rust. As far as getting a good motor for it you can get a b230ft from a 91+ i believe turbo motor with the thicker 13mm rods. You can find these in 940 turbos, 960 turbo not sure if they have those in your market. Link to comment Share on other sites More sharing options...
blkaplan Posted May 7, 2013 Report Share Posted May 7, 2013 setting up a Drifting 240 is pretty easy, You just need to get it setup correctly, I have supplied many drift 240s with their setups and the owners have been really happy. This is Cody Woods wagon, you can find his build thread here ->http://forums.turbobricks.com/showthread.php?t=126475 You will want a lot of torque and good throttle response. So if you take a 90+ block with the thicker rods and high compression (9.8:1) pistons and install a smallish turbo (td04hl) you should have the response and torque to get it done. That will be a good starter motor. If you want to be really fast and competitive you will need to build a motor because the good drift cars are all making above 350 hp usually.http://jalopnik.com/5968213/the-v8lvo-battle-wagon-drift-missile-is-back http://www.youtube.com/watch?v=zTzxh9uD938&feature=player_embedded Link to comment Share on other sites More sharing options...
Foxdc199 Posted June 6, 2013 Report Share Posted June 6, 2013 Nothing pretty but looks like a hell of a fun time! Link to comment Share on other sites More sharing options...
bassguy Posted June 20, 2013 Report Share Posted June 20, 2013 Get any body year 240 they're all nice just check for rust. As far as getting a good motor for it you can get a b230ft from a 91+ i believe turbo motor with the thicker 13mm rods. You can find these in 940 turbos, 960 turbo not sure if they have those in your market. "960 Turbo" in NA is called the 940SE. It's actually VIN'd a 960, though. Link to comment Share on other sites More sharing options...
okoye Posted June 22, 2013 Report Share Posted June 22, 2013 I'm aware of that as i've personally owned one. it is vin'd as a 960. He's in austrailia so it would be reffered to as a 960 turbo most likely. Link to comment Share on other sites More sharing options...
James A Sousa Posted June 29, 2013 Report Share Posted June 29, 2013 I suggest that you get a 744 TI. With a set of snow tires, I could drift our stock '90 744 TI around a 1/4 mile rotary on a dry road. It had 230K on it at the time. Link to comment Share on other sites More sharing options...
blkaplan Posted July 5, 2013 Report Share Posted July 5, 2013 I suggest that you get a 744 TI. With a set of snow tires, I could drift our stock '90 744 TI around a 1/4 mile rotary on a dry road. It had 230K on it at the time. Sure you can slide around pretty easily if you put a set of crappy tires on. If you care about being competitive in teh drift game you need lots of speed. The people who do it right are sliding with big sticky tires and have tons of corner speed and grip... even though they are in the middle of a drift. 740s aren't as cheap or easy to setup for drifting as a 240 is Link to comment Share on other sites More sharing options...
AdirondackVolvo Posted July 14, 2013 Report Share Posted July 14, 2013 Im Sliding a 92 245 with a 93 B230F with a B cam. Does quite well for our small drift courses at school. I'd like to go +T soon though to hit up driftindy events, or Drift Movement events back home in New York. Link to comment Share on other sites More sharing options...
D s50r Posted July 22, 2013 Report Share Posted July 22, 2013 id like to do the same ive been looking for a good body 240 or 740 for a ls swap, does anyone have a link to whats need for a v8 swap? im not on turbo bricks yet, Link to comment Share on other sites More sharing options...
blkaplan Posted July 24, 2013 Report Share Posted July 24, 2013 Not much is needed, just engine and trans mounts and the obvious stuff like an ECU to run the LS. Heres a thread detailing a LSX install http://forums.turbobricks.com/showthread.php?t=106802 Link to comment Share on other sites More sharing options...
