ausura Posted May 19, 2013 Report Share Posted May 19, 2013 Hey, what do i need to change a prv v6 to a b230ft/fk engine. i know its lh2.2 in it, do i need to custom make engine mounts or does the ones from a 760 fit? what else do i need to get everything working ? thanks in advance Link to comment Share on other sites More sharing options...
blkaplan Posted May 20, 2013 Report Share Posted May 20, 2013 all the motormounts from a turbo donor car should work. you will want to swap the ecu and harness as well. Link to comment Share on other sites More sharing options...
ausura Posted May 23, 2013 Author Report Share Posted May 23, 2013 all the motormounts from a turbo donor car should work. you will want to swap the ecu and harness as well. Thank you for reply, have you done a swap like this in a 760 or 780 before? Anything else i might need to change? i want to use m90 with the engine. Link to comment Share on other sites More sharing options...
blkaplan Posted June 2, 2013 Report Share Posted June 2, 2013 I have not personally done this swap. As long as you get a redblock m90 it should be pretty easy. Just source a pedal set from any manual 700.900 car. Link to comment Share on other sites More sharing options...
bassguy Posted June 20, 2013 Report Share Posted June 20, 2013 Isn't the engine crossmember different? And the front swaybar? Link to comment Share on other sites More sharing options...
bassguy Posted July 13, 2013 Report Share Posted July 13, 2013 I would almost say you'd be better off finding a whole donor car than trying to find the individual pieces. Link to comment Share on other sites More sharing options...
WayAway Posted July 30, 2013 Report Share Posted July 30, 2013 All new gaskets, fluids, Misc parts that break, hoses, intercooler, Rad? exhaust, throttle cable, wiring harness, motor mounts, all the correct coolant lines, ignition items, misc vac lines, ecu, and im sure much more. donor car is the way to go, seeing as their relatively cheap, and would save you BUNCH of time. Then just scrap the rest of the car when your done Link to comment Share on other sites More sharing options...
